When i turn on my lg 42ld690 tv, the screen is v bright. like a negative image. i swith the tv on off a few times then its fine?
  • 11,361 Answers
You may have failing T-CON board. You need to do some voltage checking and visual inspection inside the TV.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Please post back what you find.
Posted on Aug 03, 2010
My lg TV of three and half years has a black screen with images flashin Intermittently. The sound is fine
What is the model number? If it is only 3 years old, I suspect you have a LCD TV with LED backlight. You quite possibly have a failed LED backlight.
Many LG TVs of this age are starting to fail due to over-worked LEDs in the backlight which create the white light that illuminates the LCD image.
The symptom is TV turns on and off ok, gets sound on the connected video inputs, but has an otherwise black screen with no video on display. You can try to operate the TV near a bright window with lots of sunlight and see if you can perceive a faint image on the screen. A flashlight is often not bright enough to be helpful.
Most of the time, an LED will fail as a short circuit and still allow power to flow through it to other LEDs that will still light up. If one of these LEDs fails as an "open circuit", or if several LEDs have failed in the same circuit, then the power supply detects a fault and shuts the TV down. If the LED is intermittent, you may have flickering. Think of having one light bulb burn out in a string of Christmas lights and having all the lights go out until the bad bulb is replaced... kind of the same thing.
Your TV circuits boards should be fine. In my opinion your TV requires a backlight repair which requires complete disassembly of the entire TV including disassembly of the panel which is a difficult process.
Nov 13, 2017 | LG Televison & Video
Toshiba 20hlv15 image turns bright colors and will sometimes disappear.
I will check what toshiba says about this problem, but in the meantime, make sure your tv is not overheating, make sure all airvents are open, you said you took it apart so I supose you cleaned all the dust and so on.
Il get back to you.
Mar 30, 2008 | Toshiba 20HLV15 TV
LG 47LB5900 TV picture blinks on and off. sound ok, does it on all menus, not just content.
T con board is responsible for the final image that appears on set. If there are anomalies or issues with it they can be traced to that board.
Aug 25, 2017 | LG Televison & Video
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Dec 20, 2015 | LG Televison & Video
LED screen comes on and goes black
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
https://www.youtube.com/watch?v=PWoz_-3OHIM
Jan 25, 2013 - Uploaded by Tampatec
Common LG LCD TV REPAIR - NO PICTURE OR BLACK SCREEN FIX ... I have a LG 42PM4700-UB plasma tv that justwent black. The red ... I had to keep turning on and off the TVseveral times for the screen to come back.
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on theScreen CLICK ... Tv was working fine when left to go to store and came back to blank picture and ... my samsung tv it turns on but its completely black and no sound at all ... LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW - Duration: ...
Dec 09, 2015 | LG 47LS4500
Why comes white vertical line on my t.v?
Horizontal scan output fault. Check the connections to the deflection yoke from the main board. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 27, 2015 | LG Televison & Video
Rainbow static on Plasma Tv
The color static, if we are talking about the same thing, is usually a digital signal interference. Check cables, and digital converter if used.
May 21, 2013 | LG 42PQ30 42 in. Plasma TV
No picture on mu LG television.
Try the old flashlight test, turn off the lights in the room. Turn on the set and flash a bright flashlight on the screen. Do you see the image or is the screen totally black?? If you see the image, then most likely you have a backlight problem. Verify that you have 24V on the power supply for the inverter
May 20, 2012 | LG 19LH2000 19 in. TV
No image on monitor
Looks like the Video card, or Video chip has bought the farm
Try hooking up to another monitor to confirm where the problem is.
Jan 30, 2009 | ViewSonic VX922 19" Monitor Flat Panel
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
108 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
