Question about KitchenAid 19.7 Cu. Ft. Side-By-Side Refrigerator with Bottom-Mount Freezer - Stainless-Steel
Changed water filter stil water not coming fast,very slow
    President:
  • 3,773 Answers
Check water pressure at wall
Check water mixer valve (bottom right in the back.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 03, 2010
Our water is coming out very slow. Please help!
Have you changed the filter?
When water filter gets old and clogged with debris it slows the water output.
Our side by side different brand's filter is on the bottom front by the grill looks like a round dial to turn and pull out.
Dec 19, 2010 | Roper RS25AEXLQ Side by Side Refrigerator
Slow water flow from the water dispenser
If it was fast at one point there are a couple of things that come to mind. Make sure your water line is not kinked at any point behind the frig. Also, when was the last time you changed your filter? Dirty water filters can cause low water pressure. Let me know if I can help further, good luck! :D
May 29, 2010 | Whirlpool GS6NBEXR Side by Side...
Water in door too slow coming out
A strainer before the inlet valve can get stopped up restricting flow. It's on the back where the water supply connects.
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see how fast the water comes out when you try the dispenser. If it's slow here there is a valve our water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Sep 20, 2009 | Refrigerators
How to increase the water flow from water dispencer on a FLSC238DSO when getting water it takes for ever to fill a glass
If your fridge has a water filter, you should change it every 3 months. An old filter can cause slow flow problems.
But it will never come out as fast as the kitchen sink. Depending on the location of your fridge, you have 10 to 25 feet of 1/4" pipe between your water glass and the high-flow plumbing, and water just won't move very fast through that.
Sep 16, 2009 | Refrigerators
Water Filter Output
Let me know what happens.
May 13, 2009 | KitchenAid Refrigerators
Amana fridge water dispenser real slow
u m,ay have to change the filter tubing as well
Mar 15, 2009 | Amana ARB8057CSL Bottom Freezer...
We have a slow water flow the water wont come out fast its just drinpping out
could be a clogged filter to the water pump.
check the filter. it is in the water pump inlet assembly.
unscrew the cover and pull the filter. it could be clogged with dirt and small particles.
tnx 4 using fixya,
drcool
Oct 19, 2008 | Kenmore Elite 45986 Front Load Washer
Slow water flow on Whirlpool Gold 25.6 cubic
The water line tap may be screwed back into the water line or you did not sufficiently poke a hole into the water line with the tap. We had the same problem. Shut off the water supply, remove the tap from the line and check the size of the hole. my bet is the hole is very small. Either drill out the hole with a drill and replace the tap (with a new rubber grommet) or add a tee into the line with the proper size compression fitting (that is what we did) and the water will flow freely..
Apr 20, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
I changed the water filter but the water still comes out soooo slow.
It may be the water valve located on the back of the fridge. The way you can tell is to pull the water valve off and take the hose off on the refrigerator side of the valve. Hold a glass under it to catch any water and have someone push the water lever in the door. If you have good bad water pressure there, it's probably in the valve. If not, your water bin, or water hose in the fresh food section may have ice in the line and may be frozen up. If that's the case, you'll have to thaw it out and it should correct the problem, but it will most likely happen again sometime in the future. Please let me know if you have any other questions on this topic.
Mar 11, 2008 | Maytag MSD2454G Side by Side Refrigerator
KitchenAid 19.7 Cu. Ft. Side-By-Side Refrigerator with Bottom-Mount Freezer - Stainless-Steel Logo
95 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
