Question about Toshiba Satellite A355D-S6921 Laptops
My toshiba will only boot up in safe mode... how do i fix it
    Sergeant:
  • 298 Answers
This is not something you should do all the time. hold down your power button until your system goes off, start it again and it will give you the option if to start in safe mode or not, or you could restart the system and follow the other above proceedures instead of shutting it down wrongly, anyways one of them should work
Posted on Aug 03, 2010
A toshiba laptop..boots..when windows opens it turns white ..and can't to anything..
Try booting to safe mode and check if it does the same thing.
Here's how you can boot to safe mode with networking.
Restart you computer and tap F8. Use the arrow keys to highlight safe mode and press enter.
If you can boot to safe mode with networking, then update the drivers of your computer by going to the device manger or you can install RadarSync to scan for outdated drivers and update them .
David
Mar 30, 2013 | Computers & Internet
Fix satellite c655 toshiba laptop lcd screens
If the start up menu displays, it could be a video driver issue. Try to start in safe mode ; press F8 at start up and choose safe mode.
Mar 29, 2013 | Toshiba Computers & Internet
I restarted my Toshiba satellite a305 and now it won't boot up or go into safe mode. It comes to the start up screen that says press f2 for setup f12 for boot manager. It will let me go into setup and boot...
If it won't let you go to safe mode,then there's something that the BIOS(setup) or Boot Manager needs before starting the operating system(Windows Vista). You should have a Toshiba Recovery Disk which will fix this . The disk will not touch any of your current files and data,so don't worry about that.
Apr 12, 2011 | Toshiba Satellite A305-S6908 Laptop
Hi, I have a toshiba equium A110-233, a little elderly I know ! All was working fine until I turned it on a couple of days ago and now only get the initial toshiba screen then nothing, not even the cursor...
Hi shirley_ann1,
This problem that you have with your PC is a NO BOOT issue. After getting the startup Toshiba logo it's not booting up to your Windows. This could be a hardware or software problem depending on the result of the diagnostics that I'll be walking you through below, but definitely this issue can still be fixed.
Here's how:
1. If this is a software issue you can determine it by booting up on safe mode. To go to safe mode:
  • Shutdown the computer then turn it back on
  • The moment you turn on you PC keep on tapping F8 button until Safe Mode menu shows.
  • Then select Safe Mode, press enter.
If you'll be able to boot up on Windows using Safe Mode then you just have to reload your operating system. You will use the recovery disc that goes with your machine when you purchase it.
2. If it's a hardware issue you will not be able to boot up even on Safe Mode or even go to BIOS when you keep on tapping F2 during startup. This means your harddrive is corrupted or defetive. It needs to be reimaged or replaced.
Hope this will help you resolve your concern.
Thank you for using Fixya.
Feb 21, 2011 | Toshiba Satellite A135-S4527 Notebook
I can"t boot my Toshiba
Format and re-install the operating system with new installation disk.
Thanks
Jan 10, 2011 | Toshiba NB205-N210 Netbook
Everytime I boot up I am in safe mode. how do I get out of safe mode This is for a Toshiba Satellite: A 105-S1013
When the system boots up, click on the start button, then click on run and type msconfig and hit enter. Go to the Boot tab, look at the lower box and uncheck "safe boot" if it is checked.
Dec 06, 2009 | Toshiba Satellite A105-S1013 Notebook
Cant access laptop apart from boot menu f5 f12...keeps saying tring to fix windows but not getting anywhere...i have alot of photos on there i do not want to lose...have toshiba recovery disc but that will...
Hi There, try booting in safe mode to download your photos to a flash drive or cd. When you first turn on laptop, and see the curser upper left side of screen, keep pushing "f8" to enter safe mode boot. Select "safe mode with networking" and continue on to save pics. Good Luck...
Oct 28, 2009 | Toshiba Satellite A100-S8111TD Notebook
When I boot-up my Toshiba laptop, there are vertical, skinny lines followed by double images of the program icons on the laptop. Any suggestions to remedy the problem?
check if this problem continues in safe mode.. To go to safe mode press F8 before u see the XP splash or boot screen.... If problem is not seen in safe mode go a head and boot to normal mode and reinstal the Video drivers and also update the BIOS from the vendors[Toshiba] site.... even if still problem continues reseat the video cables of the laptop by using the service or user manul k....
Sep 20, 2009 | Toshiba Tecra 8000 Notebook
Toshiba Satellite won't boot up
While you have it in safe mode, make sure you back up all your personal data to a cd as is sounds like it is not going to last much longer. After you back up all your information....Documents, Pictures, Music...etc... Then I would reformat the machine with the original installation disc that came with the computer. That should fix the problem. Never even heard of a boot processor :)
Oct 10, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A355D-S6921 Laptops Logo
87 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
