Question about Microsoft Windows XP Professional for PC
Pc problem My Pc is not running most of the programs the open with window opens for every application and asks 'Choose the program you want to use to open this file'
  • 4 more comments
  • sidspyker Apr 25, 2008
    Pls help fast
  • sidspyker Apr 26, 2008
    The problem is now fixed i repaired Xp and it's now working fine and i formatted all the other drives and now it's running ok anyway
    thanks
  • Anonymous Apr 26, 2008
    drive can not oen by double clik or by right clik.
  • sidspyker Apr 27, 2008
    My problem is solved thanks no more posts please
  • Serwen Bagadiong
    Serwen Bagadiong May 11, 2010
    Good for you. atthaullah is correct a virus might have been the cause of this probem, or you may accidentally change the program that open this type of file or deleted the program that open this file. Tell us if you have any more problem.
  • Serwen Bagadiong
    What type of file are you opening? Try right clicking the file you want to open then go to properties and then tell us what file type it is.
  • 54 Answers
This may be due to virus the virus scanner will remove the program files which contain virus so the file may be missing
you can try to restore the system which can be find in
Start-Program-accessories-system tool-system restore
select a day in which system worked fine
Hope this may slove your problem
Posted on Apr 25, 2008
Codes of c++
Microsoft Visual C++ 6.0 is an integrated development environment, or IDE, released by Microsoft in 1998. An IDE allows the user to create a computer application by using pre-designed functions, tools and other resources. Microsoft Visual C++ 6.0 features a source code editor, a compiler, a debugger and graphical user interface.
Install Microsoft Visual C++ 6.0 on your computer. The installation process is fairly simple. Just follow the prompts. Run the program. A window will appear asking you to create a new application. On the "Project" tab, choose "Win32 Console Application." This means that you will create an application with an EXE file extension that can work with 32-bit Windows operating systems after compiling the project. Also, specify the project's name and the location where it will be saved. Click "OK." Click"OK" in the dialog box that will appear next. You will choose to start an open project. Double-click on the form in the center of the screen. Type: #include <iostream.h> int main() { cout <<"This is my first project!!! Hello everybody! \n" return 0; } Press "F5." This will build and run the project. Microsoft Visual C++ 6.0 will compile your project into an EXE file. Then it will open this file. You will see a new window open in which you'll see your greeting, " This is my first project!!! Hello everybody!" Press any key to exit the application. http://elvis.rowan.edu/~kay/cpp/vc6_tutorial/ http://msdn.microsoft.com/en-us/visualc/ee340952.aspx
Feb 03, 2013 | Microsoft Visual Basic 6.0 for PC
FTP Connection using Windows 7 64 bit
Individual applications that transfer files using FTP may have their own methods for monitoring transfer speed. But for a single method that works across all applications, consider an external bandwidth monitor. Windows no longer tracks bandwidth usage, but several free third-party tools display your upload and download speed. Close other Internet programs besides your FTP transfer tool, and check the bandwidth monitor to determine your transfer rate.
Net Speed Monitor
If your computer uses the 32-bit version of Windows 7, download Net Speed Monitor 2.5.4.0 for Windows. If your computer instead uses the 64-bit Windows 7 version, download Net Speed Monitor 2.5.4.0 for Windows (msi, x64). (See Link Below.) http://www.floriangilles.com/software/netspeedmonitor/download/ Run the installation program. The license agreement will open. Accept the agreement. Click "Next." Further options will open. Click "Next." Click "Install." A dialog box will ask whether you want your task bar to display the "NetSpeedMonitor toolbar." Click "Yes." Another dialog box will open. Click "Save." Run your FTP transfer. Check the transfer rate from the task bar. Bandwidth Meter b> Download the Bandwidth Meter installation program. (See Link Below.) http://www.bandwidth-meter.net/freedown.htm Run the program. Click "Next" through the options. Choose "Install" when the final step prompts you to. Run your FTP transfer. Check the transfer rate from the task bar. Hope this helps.
b>
Dec 17, 2012 | Esker TUN Plus 11.5 Upgrade Version for PC
How can fix microsoft visual c++ runtime library
Which program is it?
This is what I did.
1. Turn On PC as normal
2. Wait for prompt error to show up
3. When it appears, Run Task Manager (here you can see the task running the Error Prompt)
4. Right Click on the task and Choose > Go To Process (will take you to processes Tab)
5. See the highlighted Process, Right Click and Choose Open File Location
6. Windows Explorer will appear and you can see the Application Folder (name of application)
In my case, a 'browser toolbar application' was trying to auto initiate itself
7. Open Uninstall Programs > Search for Application Name > Uninstall (NOTE: PLEASE DO NOT UINSTALL IF THE PROGRAM IS A CORE FILE like Windows related program)..
8. Restart PC.....its gone :)
Another alternative:
Do a system restore. Click start > program > accessories > system tools > system restore.
Restore it to a known good date when your computer was fine.
I hope this helps.
Carlo
Nov 28, 2012 | Computers & Internet
Program to stop running on my PC screen
Try opening the task manager and ending the program from there: press control and alt together and then press delete. Choose to open the task manager. On the applications tab, highlight the program you want to stop and click end task. If you get a window saying the program is not responding, click; end now. After this go to the start menu and type msconfig into the search field and return. Open the tab that says startup programs, find the HP program and uncheck the box. Restart the machine. You can then go to the control panel, choose remove a program, highlight the HP program and click uninstall.
Mar 28, 2012 | Computers & Internet
If i try to download something,like a video,it says connect media to save destination
You do not have a default program for your video viewing or that particular video requires a specific program to be used. Ensure that your computer has a video player such as Windows Media Player if you are using a Windows OS or that you have Quick Time if you are using a Mac OS. If these programs are already installed, then you may want to ensure that they are set to be the default program for that particular video.
Download the video, then right click the video and click the option that says "Properties". When the box appears, click open with and select either Quick Time or Windows Media Player. To avoid doing this for every video, follow the instructions below:
WINDOWS OPERATION SYSTEM
  • Open Windows Explorer by right-clicking the Start button, and then click Explore.
  • Click a folder that contains a file of the type that you want Windows to open in a program that you select.
  • Right-click the file and, depending on the programs installed on your computer, complete one of the following steps:
    • Click Open With to choose the program that you want.
    • Point to Open With, and then click Choose Program to choose the program that you want.
  • The Open With dialog box is displayed. Use one of the following methods to select the program that you want to use for this file type:
    • In the Programs list, click the program that you want to use.
    • Click Browse, locate and then click the program that you want to use, and then click Open.
    • Click Look for the appropriate program on the Web to browse the Internet for the program that you want to use.
  • Click to select the Always use the selected program to open this kind of file check box if it is not selected.
  • Click OK.
  • MAC OS
    1. 1quick-change-files-default-application-1.1-120x120.jpg Select the File to Make the Default Application Change
      In an open Finder window, select the file you wish to make the default application change to.
    2. 2quick-change-files-default-application-1.2-120x120.jpg The Contextual Menu for the File
      Right-click your mouse or use a "Ctrl-Click" with the keyboard to bring up the contextual menu for the file.
    3. 3quick-change-files-default-application-1.3-120x120.jpg Clicking the "Option" Key Changes the Menu Item to "Always Open WIth."
      Press the "option" key on your keyboard and you will notice that the "Open With" menu item in the contextual menu will change to "Always Open With." Select the "Always Open With" option in the contextual menu.
    4. 4quick-change-files-default-application-1.4-120x120.jpg Select the Application from the "Always Open With" Menu
      Select the Application from the "Always Open With" menu to make your changes to the file, and the newly selected application will become
    Nov 29, 2010 | Computers & Internet
    My itunes just stopped working one day and now i can not reinstall it on my computer
    Learn how to completely uninstall iTunes, QuickTime, and other essential software components from your Windows XP PC.
    How ToFor Windows Vista or Windows 7, see this article.
    Expand All Sections | Collapse All Sections
    In some rare instances, it may be necessary to remove all traces of iTunes, QuickTime, and related software components from your computer before reinstalling iTunes.
    Use the Control Panel to uninstall iTunes and related software components in the following order:
    1. iTunes
    2. QuickTime
    3. Apple Software Update
    4. Apple Mobile Device Support
    5. Bonjour
    6. Apple Application Support (iTunes 9 or later)
    Important: You may see various alert messages if you uninstall these applications in a different order or only uninstall certain components.
    For detailed steps on removing and reinstalling iTunes and related components on Windows XP, refer to the following steps:
    Removing iTunes Note: iTunes Store purchases or songs imported from CDs are saved in your My Music folder by default and are not deleted by removing iTunes.
    1. Quit iTunes.
    2. From the Start menu, choose Control Panel.
    3. In Control Panel, open Add or Remove Programs.
    4. Select iTunes from the list of currently installed programs, then click Remove.
    5. When asked if you would like to remove iTunes, select Yes.
    6. After the uninstallation is complete, do not restart your computer if you are prompted to.
    7. If other program entries were listed for iTunes in Add or Remove Programs, remove those as well.
    8. In Add or Remove Programs, remove any iPod Updater applications that are listed in the same fashion as iTunes was removed.
    Removing QuickTime
    1. Quit QuickTime Player.
    4. Select QuickTime from the list of currently installed programs, then click Uninstall.
    5. When asked if you would like to remove QuickTime, click Yes.
    7. If other program entries were listed for QuickTime in Add or Remove Programs, remove those as well.
    Removing Apple Software Update
    1. Quit Apple Software Update.
    4. Select Apple Software Update from the list of currently installed programs, then click Uninstall.
    5. When asked if you would like to remove Apple Software Update, click Yes.
    7. If other program entries were listed for Apple Software Update in Add or Remove Programs, remove those as well.
    Removing Apple Mobile Device Support
    1. From the Start menu, choose Control Panel.
    2. In Control Panel, open Add or Remove Programs.
    3. Select Apple Mobile Device Support from the list of currently installed programs, then click Uninstall.
    4. When asked if you would like to remove Apple Mobile Device Support, click Yes.
    5. After the uninstallation is complete, do not restart your computer if you are prompted to.
    Notes: Do not manually delete the Mobile Device Support folder located at C:Program FilesCommon FilesApple. Use Add or Remove Programs as described in the steps above.
    Removing Bonjour
    2. In Control Panel click "Add or Remove Programs."
    3. Select Bonjour from the list of currently installed programs then click Uninstall.
    4. When asked if you would like to remove Bonjour click Yes.
    5. After the uninstallation is complete do not restart your computer if you are prompted to.
    Removing Apple Application Support (iTunes 9 or later)
    3. Select Apple Application Support from the list of currently installed programs, then click Uninstall.
    4. When asked if you would like to remove Apple Application Support, click Yes.
    Verify iTunes and related components are completely uninstalled
    1. Restart your computer.
    2. After the computer restarts, open Local Disk (C:) located in Computer or whichever hard disk your programs are installed on.
    3. Open the Program Files folder.
    4. Right-click the iTunes folder, choose Delete, and choose Yes when asked to confirm the deletion. Note: This folder may have already been deleted if iTunes was successfully removed.
    5. Right-click the iPod folder, choose Delete, and choose Yes when asked to confirm the deletion. Click Continue if Windows needs confirmation or permission to continue.
    6. Right-click the QuickTime folder (if it exists), choose Delete, and choose Yes when asked to confirm the deletion. Click Continue if Windows needs confirmation or permission to continue.
    7. Right-click the Bonjour folder (if it exists), choose Delete, and choose Yes when asked to confirm the deletion. Click Continue if Windows needs confirmation or permission to continue.
    8. Open the Common Files folder.
    9. Right-click the Apple folder (if it exists), choose Delete, and choose Yes when asked to confirm the deletion. Click Continue if Windows needs confirmation or permission to continue.
    10. Open Local Disk (C:) located in Computer or whichever hard disk your operating system is installed on.
    11. Open the Windows folder.
    12. Open the System32 folder.
    13. Right-click the QuickTime file (if it exists), choose Delete, and choose Yes when asked to confirm the deletion. Click Continue if Windows needs confirmation or permission to continue.
    14. Right-click the QuickTimeVR file (if it exists), choose Delete, and choose Yes when asked to confirm the deletion. Click Continue if Windows needs confirmation or permission to continue.
    15. Right-click the Recycle Bin and choose Empty Recycle Bin
    Reinstalling iTunes and related components After verifying that iTunes is completely uninstalled, you should download and install the latest version of iTunes.
    Additional Information iPodService.exe Alert Follow these steps if the message, "Cannot delete iPodService.exe: It is being used by another person or program" appears when you try to delete the iPod folder.
    1. Make sure that iTunes and the iPod Updater utility are not open.
    2. Press and hold Control-Alt-Delete. Select Start Task Manager.
    3. Click the Processes tab.
    4. Locate "iPodService.exe" in the list.
    5. Click "iPodService.exe" and choose End Process.
    6. Quit the Task Manager.
    Aug 04, 2010 | Apple iTunes
    I bought keyboardworks v1.1 it worked fine for my old xp computer. Now I switched to windows 7 and it does not work. Any fixes?
    Since this software was designed to work with Windows XP or earlier. It may not run in windows 7 normally, but you can run this application in Compatibility mode.
    Windows 7 comes with Program Compatibility troubleshooter, using which you can run older programs in compatibility mode.
    To run the Program Compatibility troubleshooter
    1. Open the Program Compatibility troubleshooter by clicking the Start button and then clicking Control Panel.
    2. In the search box, type troubleshooter, and then click Troubleshooting.
    3. Under Programs, click Run programs made for previous versions of Windows.
    4. This would scan the computer for incompatible applications and list them, keyboardworks .
    5. Click next. this will try running in Windows XP mode.
    6. If sucessful save the setting and u should be good to go, else try installing this application in Compatibility mode.
    7. right-click choose properties on setup.exe
    8. click on compatibility tab. put a check on run this program compatibility mode for and choose windows XP
    9. put a check on run this program has administrator. cluick apply and ok and install this application.
    10. run the application, if it does not work repeat the steps 1-6.
    May 18, 2010 | Computers & Internet
    Software incompatible window 7
    Step by step instructions for Windows 7 32-bit follow:
    Insert the Panasonic CDROM.
    Don't use autorun - Cancel autorun popup.
    Right click on CDROM drive in "My Computer" and select 'Open'.
    Right click on Setup application & choose 'Troubleshoot Compatibility'.
    Select 'Troubleshoot program'.
    Select "The program worked in earlier versions of Windows but won't install or run now' & click
    the "Next" button.
    Select 'Windows Vista (Service Pack 2)' & click the "Next" button.
    Click on "Start the program..." button.
    Proceed with program installation.
    When installation finished cancel out of the 'Program Compatibility' window.
    If you have Windows 7 64-bit the instructions are:
    Insert the program CDROM.
    the "Next" button.
    Installation will start.
    VideoCam Suite will probably be flashing on the taskbar so select it.
    The window will show: 'This application does not support this 64-bit operating system. Are you
    sure you want to install?'
    !!! Click the "Yes" button !!!
    Dec 28, 2009 | Panasonic SDR-H80 Hard Drive Camcorder
    When i try to download a movie the computer asks me if i want to save this file or find a program to open it .what program do i need to open and where can i get it
    Choose "save the file", and choose a location.
    When the download is complete, double-click the file,
    to open the "which program" window. Click to access Microsoft's web-site, which will recommend which program should be used to open the file.
    Dec 27, 2009 | E-Machines eMachines T3830 PC Desktop
    System won't open programs and files
    hi. its purely a virus problem that prompts u from performing some actions in ur system. visit filehippo.com website. download AVG anti virus latest version scan ur computer. the problem wil get solved.
    Jan 20, 2009 | Toshiba Satellite A105 Notebook
    Microsoft Windows XP Professional for PC Logo
    53 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
