Question about Mitsubishi WT-46809 46" Rear Projection Television
My Mitsubishi WT-46809 blinking error code from the timer light
My Mitsubishi WT-46809 When I Push In both the menu and input botton its gives me the error code blink blink pause,blink blink pause and it does that 10 times
  • 1694 Answers
SOURCE: MItsubishi WT 46809- not staying on when turned on
One or more fuse devices open==caused by convergence IC
shorted. Solution==replace fuse(s) and STK I.C.(s).
Posted on Oct 11, 2007
MNfisherman
  • 11896 Answers
SOURCE: No picture no sound....Mitsubishi WT-46809
Your Power supply will most likely have to be replaced. Very common, the capacitor's inside these units due tend to get overheated and burn out. You can test power coming from the power supply with a voltmeter
Posted on Sep 30, 2009
SOURCE: my mitsubishi wt 46809 will not stay on.Iturn it
put it out on the curb and go buy an american tv!
Posted on Feb 08, 2010
hardrocko
  • 1476 Answers
SOURCE: I have a Mitsubishi wt 46809 with a error code of
That is error code 22 which means the unit had a momentary recovery from a reset. You should unplug it for 30 minutes, then plug in and try it again. This will reset the fault and if there are no other problems the unit will work ok. Let me know if you need more help. Thanks for using FixYa and for the generous rating.
hardrocko
Posted on May 07, 2010
SD Tech
  • 14553 Answers
SOURCE: on my mitsubishi wt-46809 the
it is short protection and means one of the fuses for the convergence circuit is blown.
I can help with this if you want.
SD TECH
Posted on Jan 14, 2011
When I turn the tv on,,it just turn off,,
do the self check this model has. When green power light goes out on the front of the set press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and then let go of both.
Power light (green) should blink a two digit code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Sep 14, 2011 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubisi wt-46809 will not turn on. i plug it in and it blinks 3 times then nothing. no error code when i hold menu and input
keep in mind if you unplug set it clears the error buffer.
Try to turn set on and if power light comes on and goes off then do the self check; menu and input for at least 5 seconds and release both buttons.
UNPLUG TV ANDTHEN PLUG BACK IN---TURNON---GREEN POWER LIGHT COMES ON FOR A MOMENT ANDGOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
Before you rate this information let me know what you find.
SD TECH
Jul 20, 2011 | Mitsubishi WT-46809 46" Rear Projection...
On my mitsubishi wt-46809 the error code is 2 blinks pause 2 blinks. What is this?
SD TECH
Jan 14, 2011 | Mitsubishi WT-46809 46" Rear Projection...
The TV was working great yesterday, but today, when you press the power button, th TV clicks on, then within 5 seconds clicks off, picture never appears but green light comes on until TV clicks off. ...
When the power light comes on and then goes out, on the front of the set press both the MENU and INPUT buttons at the same time and hold them both in for at least 5 seconds and then release both buttons.
The power light will blink a 2 digit error code and repeat it at least 5 times.
The most common error will be 2 blinks, 2 blinks- a pause and then it will repeat it for a total of at least 5 times.
To get it to repeat this--you have to unplug the set, try to turn it on again and repeat the process.
The error codes are to try to narrow down where the problem is.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
Post comment here if I can assist you further.
SD TECH
Sep 28, 2010 | Mitsubishi WT-46809 46" Rear Projection...
When the tv plugged up the power led blinks 3 times. When the power button is pressed the tv comes on for three seconds and turns back off. What could be the problem? Could this be a convergence problem?
Do the self check when power light goes out:
ON front of set (not remote) press and hold both the Menu and Input (Device) buttons at same time for 5 seconds or longer and release both buttons.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know code.
SD TECH
Sep 24, 2010 | Mitsubishi WT-46809 46" Rear Projection...
Tv WONT STAY ON
When the power light comes on and then goes off perform the self check feature the model you indicated has:
On the front of the press and hold both the MENU and INPUT (DEVICE) BUTTONS both for at least 5 seconds and release both buttons.
The green power light should blink a two digit error code--most common is 2 blinks, a pause and 2 blinks.
If this information has helped you rate this solution as I do this here for free.
SD TECH
Dec 23, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Tv turns off on its own? is the power supply going bad. Tv is now 8 years old
do the self check it should have.
when power light goes off press and hold both the MENU AND INPUT (also called DEVICE) together for 5 seconds and release both.
The power light should blink a two digit error code---like 2 blinks, a pause and 2 blinks.
If you do not get an immediate answer from me it is because it seems the Email system here is down and not working correctly right now.
If this helps you rate this solution as I do this here for free.
SD TECH
Dec 19, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Tv turns on then right off
NEXT TIME IT SHUTS DOWN: when green light goes out on THE FRONT OF THE SET: press and hold BOTH the menu and input buttons at the same time for at least 5 seconds and then release both.
This is the self check this model has---power light should blink a two digit code---for example--two blinks, a pause and two blinks and the set will repeat the error code about 10 times.
1 blinks and then 2 blinks is NO ERROR DETECTED
2 blinks and then 2 blinks is short protect
ETC.....Let me know if you get an error code and I will tell you what the problem is---hope you find 2,2 that is the most common and the most easy to repair.
SD TECH
Oct 22, 2009 | Mitsubishi WT-46809 46" Rear Projection...
When I turn on my tv it will shut off
Model number is WT-46809?
If set comes on for a moment and then goes off(green power light)
ON THE FRONT OF THE SET PRESS BOTH menu AND input at the same time and hold both buttons in for at least 5 seconds---then release both buttons.
Watch the power light---it should blink a two digit code---ERROR CODE---
The most common is 2 blinks, a pause and 2 blinks-----set will repeat the error code about 10 times.
If you find this error code let me know the blinks and I will tell you what it means and may be able to tell you what is needed to correct it.
SD TECH
Oct 20, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809 46" Rear Projection Television Logo
59 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
