Question about Philips 42PF9996 42 in. HD-Ready LCD Television
High pitch sound on my phillips 32 " flat screen tv
SOURCE: protron flat 32' tv with broke screen need to replace
i have the parts
Posted on May 21, 2008
  • 12 Answers
SOURCE: i have a phillips flat screen 47
Call Associated Electronics @ 414.281.1000 and tell them what you need. They are very good.
Posted on Mar 23, 2009
SOURCE: Soyo 32" won't turn on
The problem is the capacitors on the power supply board. There are two of them, the rating is 220uf - 250v - 105C (M). The back side of the capacitor says V9A PET. You need to remove the board, make sure the capacitor is drained, (you can do this by placing a screwdriver across the posts) Use a soldering iron and remove the capacitors. The only place that has replacement parts is at www.mouser.com, Install them, make sure the polarity is correct, re-solder them back into place. Re-connect the board and it should power back up correctly. Good Luck. Steve
Posted on Jul 27, 2009
  • 5 Answers
SOURCE: 32" philips flat crt PINK SCREEN
The set has detected a problem internally and does not "start" to precvent further damage. i would take it where you got it sweety
Posted on Sep 05, 2009
budmrtn
  • 11361 Answers
SOURCE: loud buzzing noise on vizio tv
It sound like you may have sound processor problem which is part of the main board, I would also look at the 12vdc from power supply to make sure it is clean DC.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=l37hdtv10a
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Dec 22, 2009
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
Dec 13, 2015 | Televison & Video
Had the video card replaced and 6 months later no sound only a high pitch noise. What is wrong with it?
fans bearings are going bad. lube or replace the whole fan. it also could be powersupply, they make a high pitch squeal sometimes when going bad.
Mar 24, 2011 | Vizio VP322 32 in. Plasma TV
High pitch sound after the TV warms up on my JVC 32" TV
    According to the symptom the problem is in memory IC also called EPROM, Replace the EPROM with data and your TV work fine again.
    Thanks.
Jan 09, 2010 | JVC AV-32D305 32" TV
Symphonic 32 flat panel ringing problem
that high pitched ringing is usually caused by a power leak in the high voltage section of the set. it needs to be looked at by a proffessional electronic technician before it goes out altogether.
May 09, 2008 | Televison & Video
Phillips 54 inch rear projection,no picture.
One thing that comes to mind when you say high pitched sound is the HOT ( Horizontal Output Transistor). You may be able to find one at fry's electronics. They are pretty cheap. If you are handy and know something about electronics you may be able to replace it. I am not a TV tech, I have a background in electronics and like to play with them from time to time. Not sure this will help but good luck
Mar 18, 2008 | Televison & Video
TV screen wont turn on but just a loud noise coming from the tv
I think maybe the G-board needs to be replaced. A TV shop will have to repair it. They normally start around $200.00
Jul 02, 2007 | Panasonic CT-32G23 32" TV
Philips 42PF9996 42 in. HD-Ready LCD Television Logo
177 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
