Question about Compaq Presario M2000 Notebook
Compaq presario V2000 motherboard power supply chip identification
My wife inadvertently tried to plug in a printer cable to the ethernet plug and burned up the 8 pin DIP chip next to the power in socket of the power supply. The damage defaced the chip so I can not identify its numbers. Can anyone tell me what chip to buy? The chip is designated PQ44 on the board. Also, is there any outlet for a parts identifier for this older board? Thanks, Charles
  • Wadsy Apr 26, 2008
    V2000 presario, thanks, charles
  • 3,037 Answers
Check this out and let me know if it looks the same as yours because I'm pretty sure this is it
Click on the link
http://www.aosmd.com/pdfs/marking/AO4407.pdf
If so, then it is part number AO4407
which you should be able to get from that website
Let me know if you have any other questions that I didn't answer.
thanks
Posted on Apr 25, 2008
    President:
  • 1,944 Answers
Is your laptop the V2000 or the M2000?
HP Compaq Presario V2000 keyboard My Compaq Presario V2000 keyboard's left hand side Shift key and Ctrl key is not functioning. Is it possible to remove both the keys for replacement. Also, is it...
If the keys are broken, they can be replaced. It is also possible that the keyboard cable is partially unplugged from motherboard. contact +919811049801
Sep 07, 2010 | Computers & Internet
The srceen stays black
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp
Sep 06, 2010 | HP Compaq Presario V2000 Notebook
Presario v2000 Laptop dead.
Its may be the problem on ur psu or ur motherboard
Jul 28, 2010 | HP Compaq Presario V2000 Notebook
Receiving Charge will not turn on
Take out the battery and only have the ac adaptor hooked up to the laptop and then try to turn it on.
If that doesn't work, then the motherboard is faulty. Probably a short in the motherboard but the whole thing would need to be replaced.
Also make sure your using the correct adaptor as well.
Feb 10, 2009 | HP Compaq Presario V2000 Notebook
Laptop problems
Try to unplug and plug again the memory chips if you can, otherwise the M/board was faulty.
Nov 22, 2008 | HP Compaq Presario V2000 Notebook
Compaq presario v2000 amd turion64
question.....does the motherboard you use support the powersource? that is one thing i would look into and have had problems with with many pc,laptops,etc. lemme know what happens
Aug 05, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 not recognizing HD
option1:-replace your ide/ata cable and see whether it works. check your power cable also.
option2:- update your bios. download lastest bios from your motherboard manufacturer's website.
Jun 19, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 no power new dc jack
I think that this can be rated as solved. If it is not solved please let me know.
May 21, 2008 | HP Compaq Presario V2000 Notebook
No power to my compaq presario
If the power adapter is working fine and tried in another laptop, then the most likely cause is the connector in the laptop is damaged or come loose on the motherboard and will need soldering to secure the connections.
If the power supply is faulty it could be the output power lead is broken inside the cable usually near to the round plug at the end of the wire so would need replacing, but beware some power supplies are made not to come apart, and be careful. You might just as well buy a new power supply if you don't know what your doing.
If the power supply is fine and the laptop shows some sign of life then the most likely causes are the cpu is blown, or the mothebard has blown, you could try taking out the cdrom and floppy drives because if one of them is faulty it could prevent powe rup.
Regards Wayne.
Apr 04, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario v2000 Notebook problem
Hi, Take out the battery and plug in only the power adapter and see if it comes on. If it does then leave out the battery for about 15 minutes and then put it back in. Good luck!
May 25, 2007 | HP Compaq Presario V2000 Notebook
Compaq Presario M2000 Notebook Logo
263 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
