Question about Whirlpool Dryers
My whirpool dryer is runnung but does not get hot? I cleaned the filter and checked the outlet to the wool,,
  • Whirlpool Master
  • 1,527 Answers
Hello see if theres a reset button at the back of the dryer if not .1 of the heat sensor could be faulty there may be 2 of them if so change them both these sensor usually sit at the back of the dyer good luck
regards
shaun
Posted on Aug 03, 2010
Flashing check filter I have and cleaned all filter, but the dryer is still not drying.
Have you cleaned your outlet vent tubing? Cleaning filters is just one part of really cleaning your dryer. You have to clean your dryer vent from the back of your dryer. Disconnect the vent from behind your dryer and use a shop vac to suck out any lint that mite be built up. Blocked lint tubes are #1 cause of dryer fires.
Hope this helps
Jun 29, 2015 | Dryers
Dryer gets really hot but clothes are still wet
Sounds like the vent is plugged up, that's a fire hazard take it apart and clean it out..
Apr 05, 2014 | Whirlpool Whirpool 3.5cu ft Top Load...
Fuse was replaced and ran for one cycle and now won't turn on.
what fuse the thermal fuse?if so did you clean out the dryer?the fuse usually pops because the dryer is runnung to hot,you need to clean out the duct that the lint filter slides into,blow out and vac the motor and the cabinet area where the motor is and clean out the vent line and the outside vent,if the vent lint is long use a leaf blower to clean it out.all a dryer does is move air,if the air can't move your gonna have problems,if it's gas you should do this once a year,electric every two years
Aug 07, 2010 | Dryers
My fridgidaire dryer model FDR336RDS2 seems to run too hot
Over heating in a dryer is almost always due to an air flow problem. Typically it is in the venting.
- Check the vent from the dryer to the wall by removing it and cleaning out, make sure there are no kinks or tears in it.
- Run the dryer once it is connected and feel outside to see if you are getting the same airflow outside as you can at the outlet of the dryer, if the air flow feels weaker outside your vent is restricted and you need to have it cleaned.
- If these are ok check your lint filter, softener residue can plug up the screen so air has trouble flowing trough it, you can wash it out with a brush and hot water
- With the lint screen out take a flashlight and look down the chute, if you see lint in there take a brush and vacuum and clean good
Apr 22, 2010 | Frigidaire GLER341A Electric Dryer
Electric Whirpool Dryer doesn't stay hot
Check the vent for obstructions if all is clear do an ohm reading on your heating element. For video instructions go to www.appliancehelponline.com/servicemanual.html
Feb 26, 2010 | Whirlpool Dryers
Dryer does not stop. Does not stay hot during the
Check and make sure your exhaust vent is clean and clear of any blockage.
Oct 10, 2009 | Amana NDG2330AW Gas Dryer
NO Heat
Replace the timer,the spot on the timer is burned out.
Oct 01, 2009 | Whirlpool LER5636P Electric Dryer
My whirpool le688 had a clogged vent, it got hot and now there is no power
remove the back from the dryer at the bottom near the blower housing you will see a small white fuse you will need to replace it make sure you clean the vent good then check and make sure you have good air flow
Sep 06, 2009 | Dryers
Kenmore electric dryer no heat. heating element? or temp. dial? timer goes to 0 dryer still runs
SOUNDS LIKE HEATING ELEMENT NEEDS REPLACED BUT BEFOR YOU DO THAT TRY CLEANNING YOUR OLD ONE WITH STILL WOOL FIRST THEN RUNNING THE DRYER
Mar 09, 2009 | Dryers
Frigidaire washer won't spin, belt seems to be ok. What else can I look for ?, Thank you. e-mail , OSUOWNSFOOTBALL@YAHOO.COM
Check your outlet filters, clean out. The machine will not spin if the filter is blocked. Also check your inlet into the machine. Clean screens on both ends of the pipes. Refit carefully. If you have manual, check for filter cleaning.
Dec 02, 2007 | Frigidaire GLTF2940ES Front Load Washer
Dryers Logo
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
