A/C works but cool air only comes out of the windsheld and floor vents until the car has been driven for a while cool air doesn't come out of the mid vents but when it does start it is not blowing as hard as windsheld and floor vents
    Scholar:
  • 66 Answers
Not knowing what type of car it is... I'll take a wild stab at it. I'm assuming that your car is a luxury type car, with a climate control system. I base this on the info you've provided thus far. I may be wrong. Still...
If your system is not controlled by manual cables and levers, it is controlled by servos, vacuum diaphragms and maybe louvers too. If that is the case, any of the above mentioned may have gone bad causing your issue "A/C works but cool air only comes out of the windsheld and floor vents "
I would strongly recommend you take it to an automotive AC shop and have them take a look at it. Regardless of what you decide to do, it is going to be either expensive to repair, or a royal pain to do yourself, because most/all of those things are under/behind the dashboard. Unless things are very spacious under there, it will be a bear to do.
My guess... servos, diaphragms and louvers are jacked up. Maybe you'll be lucky and it will be a vent hose that's disconnected. But that's wishful thinking. -Ric
Posted on Aug 02, 2010
My 1999 Buick Regal climate control puts ac out defrost, mid , and floor all the time on auto or manual
There is a vacuum hose that is no longer connected to the engine intake manifold.
Aug 22, 2016 | 1999 Buick Regal
AC has barely any pressure unless on high and only getting hot air.
check the cabin air filter if equipped, Make sure that the air is not coming out of the floor vents or defrost. The door that diverts the air maybe stuck, pushing air out defrost/floor vents
Dec 18, 2013 | 2007 Toyota Corolla
2000 pontiac bonneville blows hot and cold at the same time
Sounds like the blend door motor isn't working.
Jan 20, 2013 | 2000 Pontiac Bonneville
Rear Floor Vent heat only
Sounds like your heater coolant hose door flap is broken or loose. May want to check behind the heater controls, if your components are mechanically operated. If electronically, may need to perform more troubleshooting before replacing this component.
Jun 17, 2017 | 2004 Ford Econoline
1997 cadillac sls problem...
It is air coming out of th defroster? On th windsheld? Th switch that control d vents, is digital or manual? It could be disconected from th vents inside th dash not leting th air come trought. Th blower in th pasenger side under glovebox work?
Nov 23, 2011 | Cars & Trucks
Cold air comes out the defrost vent all the time. 1994 buick le sabre. no air comes out the front registers.
The most common cause is the blend door actuator. It's the door that diverts air between the floor, vents, and defroster. Sometimes the part will get stuck in 1 position. Some cars have cable driven blend doors, others are electronic.
Jun 02, 2011 | 1994 Buick LeSabre
Air only blows to defrost
The problem is with the blower door actuator. It's vacuum driven and controls the air flow from the defrosters, vents, and floor. With the AC on, open the hood and check the lines (very skinny rubber lines) at the firewall in front of the passenger and work back ward. You're looking/listening for a vacuum leak, either a pinhole or maybe a worn end in need of repair.
Aug 06, 2009 | 1984 Mercury Grand Marquis
2003 Chevy Trailblazer Environmental Control Problem
THE AIR SELECTOR MAY BE BAD BUT THE ARMS ON THE SIDE OF THE HEATER THAT REDIRECT THE FLOW LOOSEN AND WILL NOT OPEN THE FLAPPER, THIESE ARE LOCATED ON THE DRIVERS SIDE WHERE THE AIR BLOWS OUT ONTO THE FLOOR ABOUT HALF WAY UP.
Jun 23, 2008 | 2003 Chevrolet TrailBlazer
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
