Question about Kenmore 5552 / 655529 / 55524 / 55522 Side by Side Refrigerator
How do I remove the icemaker - Kenmore 55522 side by side
I have a kenmore 55522 side by side. The ice maker has stopped working. I want to know how to remove the ice maker? The left side looks like I can press up on a tab and it will slide out of the braket. I can't find a tab to press on the right side. Is there one or do I need to unscrew the bracket? Where do I unhook the power?
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
SOURCE: Kenmore side by side frig with icemaker
The water smells funny and taste moldy/musty. Where is the filter to change it? I've looked inside and out and can't find it.
Posted on Jul 24, 2008
tech master
  • 120 Answers
SOURCE: Kenmore 106.71192101 refrigerator icemaker doesn't produce ice
ok follow these steps to trouble shoot 1st remove white cover from front of ice maker there you can now see the module of the unit .that would be part number 35 on the parts list. 2nd get a 12 gauge insulated wire about 2 inches long and stripp the ends of it . insert it in the two holes in front with letter h and t live there for about 20 seconds now look at the forks inside are they moving if yes check fill tube for a plug of ice that wont let water fill the the ice maker if no they dont move repl that part 35 you can repl your self just disconnect unit remove the three bronze philip screws and pull out ahh but first remove wire harness so it will be easy to pull out ok thanks
Posted on Oct 17, 2008
  • 11 Answers
SOURCE: No ice from icemaker of Kenmore Elite model 106
I just resolved an issue with my kenmore elite side by side refrigerator icemaker (model 106).
It was expensive because I took the long road to fixing the unit myself.
My problem: No water going up to the freezer water dispenser into the icemaker but the water in front of the door working just fine.
-first thing i tried was the simplest. The Internet is clogged with this miracle fix of using a hair dryer to melt the frozen water line going to the dispenser output. This is highly unlikely for our model since the water line is protected within the refrigerator frame.
-2nd thing I replaced my water filter (thinking that there wasn't enough water pressure to trigger the solenoid valve. $40, and still no luck.
-3rd thing was I tested for voltage going to the solenoid. No voltage going to solenoid, so I wasted $30 for a new solenoid.....still no water.
-4th thing was I ordered a new IR sensor and receiver (since the reciever end is where the relay that sends the voltage to the solenoid to turn on and allow water to go up to the dispenser).
My IR sender and receiver appeared to be working flakey.
Installed, still no water. $58 BUCKS ON EBAY (EVERYWHERE ELSE $100+)
-I finally removed the freezer front little white door, I TURNED OFF THE FREEZER SWITCH SO NO VOLTAGE WAS PRESENT, removed the release latch underneath the freezer unit and disconnected, and removed the freezer unit to inspect it further.
When I removed the protective white cover that covers the mechanical wheel, I had a few parts come flying out of it. Turns out that the wheel accessories were damaged. THERE ARE NO REPAIRABLE PARTS ON THE FREEZER UNIT. I FOUND ONE ON EBAY FOR $39 BUCKS + $9 SHIPPING! $48 BUCKS, SWAPPED THE HARNESS AND BOTTOM COVER, AND IN 20 MINUTES, I WAS BACK IN BUSINESS. STARTED MAKING ICE IN ABOUT A HALF HOUR!!!!!
when in doubt, replace the freezer unit for $48 bucks! 7 out of 10 times it will fix your problems. All techs replace the IR set at the same time too which will set you back another $58 bucks.
Good luck! ;)
Posted on Mar 16, 2009
  • 351 Answers
SOURCE: Kenmore Ice Maker Not Working
Probably need a new ice maker, whirlpoolpartssurplus.com
Posted on Jun 23, 2009
Why is my icemaker not working on Sears Kenmore 50562991
Two of my refrigerators stopped making ice because of frozen water lines going to the ice maker inside of the freezer door. I thawed the lines by unplugging the refrigerator and used a hair drier around the ice maker till all the frost was gone. After I plugged it in I heard water going to the ice maker. If you remove the ice bin you can check the ice tray to see if it has ice in it. If it is empty it is not getting water. It could also be a bad Solenoid Water Valve.
Jul 08, 2014 | Kenmore Side by Side Refrigerator
Kenmore side by side ice maker is not geting water. water is on and if I temp change electrical connectors on the silinoid and work the water arm on the door I can get water to the ice tray. What is wrong...
You have a bad water valve . Both solenoids work independently of each other . 1 for the water dispensor and one for the icemaker .The icemaker when 5 degrees and harvests , tells the valve to give it water (electronically) .
Jul 07, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice maker in a Kenmore Elite Side by side refrigerator
check the head of the icemaker and see if the gear is broken on the module
Nov 26, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker making ice
pull the water supply tube in the freezer out and see if it is frozen up,let me know more-mike
Oct 10, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Icemaker
check inside the ice maker are the forks pointing up or down if they are down them the module on front of ice maker is broken it needs to be repl, but you said is 8 years ol d so i would repl the whole ice maker since the mold might be peeling off due to age they only last like 4 years or so
Jun 11, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
KENMORE ICE MAKER STOPPED WORKING
MAKE SURE THE ICEMAKER IS ON,ON OFF BUTTON OR LEVER IN DOWN POSITION,CHECK TUBE BEHIND ICE MAKER PULL IT OUT LOOK IN IT LOOK IN FREEZER HOLE TO MAKE SURE IT'S NOT FROZE UP,CHECK WATER INLET VALVE ON LOWER BACK OF FRIG.,LOOSEN CONNECTION TO SEE IF GETTING WATER,IF WATER IS COMING OUT IT IS A BAD WATER VALVE ONLY ONE SIDE TO WATER DISPENSER IS WORKING,VALVE IS NOT OPENIBG TO ICEMAKER SIDE,THANKS-MIKE
May 29, 2008 | Kenmore 53642 / 53644 Side by Side...
Kemore coldspot no ice?
no you ice it is on a separate valve as the water in the door so the water flow don't mean a lot in this case remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
Mar 28, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Side By Side Refrigrator ICe Make Not working
Is the icemaker producing ice and it's just not coming through the door? Or is the icemaker not even producing ice???
Mar 01, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker
water valve on back of refrigerator
the water line connects to it
it is leaking a tiny amount of water and it freezes
in the inlet tube to the icemaker.
Feb 19, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 5552 / 655529 / 55524 / 55522 Side by Side Refrigerator Logo
169 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
