Question about Troy Bilt Tb70ss Gas Trimmer
Have a troy built tb 70 ss weed trimmer. will not run unless choke is half closed. was like this new. only 2 months old.
  • Troy Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor. Sounds like you have gotten some trash in the cauburetor, check your fuel container to see if more trash is in it.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please do not forget to rate me,
Thanks
Good Luck,
I hope this helped
Posted on Aug 11, 2010
Troy bilt weed eater
I have a troy built 2 cycle pro-line tb90bc spring assist trimer.
its getting fuel and it wouldn't start I took out the spark plug and it was wet with fuel. pls fwd any info to ss.beepat@hotmail.com
May 06, 2013 | Troy-Bilt Tb90bc 17-inch 31cc 2-cycle Gas...
Tb70ss fuel diagram troybilt
Hi Ernie..
I think this is what your looking for
Please rate me
Bud
Oct 31, 2012 | Troy Garden
Troy-built tb80ec will only run in half choke position
Reality. Place unit in trash. Every post about this model has same gripe. After short usage it: 1) only runs on half choke. 2) won't start after getting hot 3) has inaccessible fuel adjustment other than idle.
The unit is crap.
Feb 08, 2012 | Troy Garden
TROY BILT TB 70 TRIMMER-NEW CARB KIT-NEW PLUG. NEW FILTER- NEW GAS--STARTS FINE IN CHOKE #1 POSITION- RUNS IN POSITION #2- WHEN SELECTOR IS MOVED TO POSITION #3 ENGINE DIES- ALMOST LIKE FUEL...
If you rebuilt the carb did you turn any of the screws on the carb while cleaning or take out, you might have just the low idle screw closed a little to much open half turn and see what happens. If you look at the carb where needle screws are located on the side,if you have two screws it will be stamped with an " L " and?or an " H " next to each screw. If you only have one screw then turn that one, to left to get more fuel. Good Luck...
Aug 27, 2011 | Troy Bilt Tb70ss Gas Trimmer
My troy built starts but will not speed up enough to use even after it warms up. It is 2 years old but only has 3-4 hours of use on it . Can you help me?
Is it 2 cycle or 4 cycle? Meaning, does it take plain gas, or mixed gas?
Clean the plug, clean the carb with either choke cleaner (4 cycle) or wd-40 (2 cycle) by spraying it into the choke hole after you take off the air filter.
You may also want to spray some of the choke cleaner or wd-40 into the gas tank with the gas to help clean out the whole fuel system.
Only use choke cleaner for 4-cycle regular gas units. For mixed gas, use wd-40 in place of choke cleaner.
Try to start it and then go back and forth from half choke to full choke until it starts picking up.
Jul 29, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Hard start tb475ss troy built weed wacker when i close the cold start lever it starts but its 75 degrees out its like the primer ball is inop but i see fuel moving through the lines when priming did not...
These 4 cycle trimmers need to be primed 10x before a cold start. The bulb will feel *firmer* on the last two or three depressions and you'll know that the carb is primed.
Full choke and and full throttle on first tug should see it hit once with a puff of smoke. Second start attempt should be in choke position two (half choke) and with full pressure on the throttle. Should rev to life on start attempt. Let the engine IDLE for 30 seconds, moving the choke to off at the end of the waiting period. Let engine idle to warm another full minute with no choke, then set to work!
May 02, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Troy built weed eater won't feed line
Check the size of the line,(OD), make sure you are using the correct size, sometimes cheap line will be problematic, also, you said you are re-stringing it, try a new batch of string, the old string inside the hub can get chaffed and will stick to itself...
Aug 22, 2009 | Troy Bilt Tb70ss Gas Trimmer
Fuel line size for troy built TB20CS weed eater
You probably have found the solution by now I would assume... TB won't tell you this because they want you to buy their stuff..
You probably are looking at the 0.08" diameter that's just a bit smaller than the 3/32". Hope this helps....
Jun 15, 2009 | Troy Garden
My Troy Built weed eater wont keep string going.
troy built is pure trash ill never waste money on any of thier trash agin i have a weed eater 5 months old it wont even crank pure china trash
May 09, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy Bilt Tb70ss Gas Trimmer Logo
483 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
