I have a Technotherm heater but no instructions for it .an u explain how it works or advise where I can get some
Instructions for overlocker
try you tube, search elna 554
Feb 16, 2014 | Sewing Machines
Don't know how to operate storage heaters
Here is a link to a video, that will explain and show you how a storage heater works. It's really a very good instructional video. http://www.youtube.com/watch?v=bXrbk-cPWG0
I hope it helps you and thanks for choosing FixYa.
Sep 20, 2011 | Heating & Cooling
I turn on unit and it starts---Very shortly thereafter it shuts down and light indicates" Flame". There is fuel in tank , but not full. Please advise
donaldcfield.
This is a typical Reddy Heat problem. You need to see my tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains the problem, how to fix it and where to get the parts.
Thanks for using FixYa and for the great rating.
hardrocko
Feb 17, 2011 | Reddy HEATER RH125T 125,000-BTU...
I have a whirlpool washing machine with a fault code F23. Can anyone advise me what it means?
HEATER FAILURE
If the temperature increase during the first 40 minutes is less than 86°F (30°C).
1. Unplug washer or disconnect power.
2. Check connection to water heater.
3. Check resistance of heating element, if present on this model. (abnormal = infinity)
4. Check the water temperature sensor and connection to it.
Nov 27, 2010 | Washing Machines
I have a balboa 8 man spa. We shut it off to drain and clean. When we were done it would not turn back on. Tub was working fine, but now it keeps tripping the gfi. After some trouble shooting. I got it to...
YES it is the heater that is at fault.
you have 2 white water pipes that attach to heater that will need to be unscrewed (best to do with spa empty) and it depends on what control system you as to advise on heater removal. some heaters have pressure switches and others have 2x sensors or they may have both. also your heater will be held into place by brackets that are normally 8mm
Adam Mill, Canadian Spa Company, UK
May 31, 2010 | Balboa Instruments Duplex Digital Panel 2...
No hot water? How can we reset?
This happens with Nortiz heaters. They just **** out. Likely the installation is very bad, but the unit can not tolerate that and it just dies. I recommend getting a Bosch 2700 or 715. If you want great efficacy, get the C-800. But follow the instructions! If it is installed correctly and you have the CO2 levels adjusted when it is installed, you will be very happy.
Apr 11, 2010 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
Combi boiler Glow worm 24ci digital fault
refere to glowworm expert advise
Apr 03, 2009 | Water Heaters
Need an instruction Manual
Get manual at manufacturer web site.
Aug 27, 2017 | DeLonghi HS15F Mid-Size Heater
Heating & Cooling Logo
343 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
