Question about HP Pavilion Slimline S3123W Desktop PC - REFURBISHED
AFTER MY NEW PC IS ON the fan seems to gointo high gear and trys to cool things down or/ the power just shuts off after 30 min. of being on. Has anyone seen this before ?
    Problem Solver:
  • 4 Answers
Many PC's have BIOS settings that enable smart fan usage, when CPU reaches certain temp, the fans kick on high, when it reaches a higher temp, auto shutdown. I do not reccommend disabling these until you find out what is overheating. I had a PC that randomly shut off, something was shorting out on my mobo.
Posted on Apr 25, 2008
Dell precision T3500 unable to initialize fan controller error
Step 1:
b> WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Every computer comes with its own internal cooling system. Dell workstation desktops are no different. Your computer's cooling system consists of a heat sink and cooling fan. The function of the cooling fan is to regulate the temperature of your computer's processor. If the fan stops working your processor will overheat and cause damage to your motherboard. Fortunately, Dell desktops have a built-in alert system that tells you when your fan stops working.
Shut down your desktop computer. Disconnect the power cable from the computer's back panel. Then disconnect any external devices. Rotate the computer so the back panel is facing you. Attach an electrostatic discharge (ESD) strap to your wrist and its wire clip to the outer casing of the computer. Lay the computer tower on its left side. Press on the side panel release buttons situated on the top and bottom panels. Grasp the side panel and rotate it away from the computer until the internal contents of the computer are accessible. Locate the cooling fan duct near the center of the motherboard. Lift the duct off of the cooling fan so it is in the upright position. Disconnect the fan's power cable from the motherboard. Disengage and remove the retaining clips from each side of the cooling fan assembly. Lift the cooling fan out of the motherboard. Set it aside. Check you CPU make sure its securely seated and has thermal grease Use a clean paper towel to wipe the excess thermal grease from the processor's surface. Apply a thin coat of thermal grease to the processor's surface using a cotton swab. This is important; if you skip this step, your processor will fry as soon as you power on your computer. Place the new cooling fan over the processor. Press down on each retaining clip until the cooling fan snaps into place. Connect the fan's cable to the motherboard. Place the air duct back over the cooling fan assembly. Rotate the side access panel downward over the computer's opening. Press down on the side access panel until it snaps into place. Place the computer vertically, and then reconnect all cables and devices to the computer.
Feb 18, 2013 | Dell Precision T3500 Computer Workstation...
When I plug the unit into power, the CPU fan runs very fast but no boot, and then when I press power on the fan slows down and the PC boots normally. It shuts down in about 30 minutes with no sign of...
Sounds like you are overheating. One way to tell if it's overheating is you say it will run for about 30 minutes then shuts down. When it shuts down try rebooting to see if the boots successfully. If it fails to boot successfully right after it shut down then you are probably overheating. If you wait awhile to let it cool down for 30 minutes or so and if you reboot and it does it successfully you definitely have a overheating problem. If I remember correctly all those compaq sr series have loud and fast running fans. Computers overheat because of three reasons for the most part: 1) A fan has stopped working. 2) The Thermal Paste on the CPU and Heat Sink has dried up or is not thick enough to keep the unit cool. 3) Dust has clogged the fan vents and inside the computer. Fortunately for you desktops don't have to be completely disassembled like laptops to get to the fan, CPU and heatsink. Just pop the case and you'll see the components attached to the motherboard
Mar 18, 2012 | HEWLETT-PACKARD Compaq Presario SR5518F...
My acer computer trys to start up when i press the power button but then shuts down by itself before booting up. is this a hard drive problem or something else? thanks, bret
Your system may be running issues during it's POST (Power-On Self Test). Does the system make any beeps or noises (Sounding somewhat like Morse code) during the startup? If so, record the number and length (Short or long) of the beeps, and check with your computer manufacturer for what the computer is trying to tell you. It could be anything from bad RAM, issues with the HDD (Hard Disk Drive), or even the motherboard itself.
Another issue could be the system is overheating. When you turn the system on, do you hear the fan begin to spin? If not, you may need to replace the fan out.
Hope this helps.
Oct 20, 2010 | Acer Extensa 5420-5687 Notebook
I have a goodman cpe30-1ab we set it to cool the out side pump and fan run about 5min and shut down the power relay starts to buzz and the fan moter gets hot real hot. all three wires to the fan have 110...
This could be several things. First turn of the power and make sure the fan turns freely using a screwdriver or something else that you can reach the blades with. If they do not turn easily you may need a new fan motor. If the fan stops, head pressure on the compressor will go up until it trips the High Pressure switch. It will also make the fan work harder so that it gets extremely hot just as you describe. Let me know what you find and we can go from there.
Aug 23, 2010 | Goodman CKL30AR30 Air Conditioner
I have a ET1831 and after about 30 minutes the machine shuts off. All programs run fine. Do I have a power supply problem or a mother board problem? How best do I diagnose the problem?
It could be a Power Supply issue or Hot chip condition on the motherboard due to lack of Air Flow for cooling or a problem with the motherboard. The first things I would check for are a Virus and Air Flow. There are a couple of Viruses out there that will do this. Get a can of compressed air and open the case and clear all the air channels and blow the dust out of it. With the case open turn the computer on and make sure the Cooling fan on the CPU works and the fan in the Power supply is working. If the CPU fan is not working replace it. Same with the the power supply fan, you would have to replace the complete power supply if that one is faulty. If your Video card has a fan on it make sure that is working as well. You maybe able to replace that fan if it's not but you may have to replace the video card if it isn't working. That would present you with a situation that the Video shuts down but the rest of the computer stays running. You will also want to check your power saver options and make sure you don't have them set to shut the computer down on time. I use screen savers and Hibernate settings to protect the screen from burn in but rarely actually shut down my computers.
Aug 07, 2010 | E-Machines Computers & Internet
Turns off then will not turn on for about 30 seconds
This remarkable unit may have a working protection for the power. In the older machines, not saying anything just a comparison, when the power is on the filter capacitors take a charge and when shut off will need some time to discharge. If power is permitterd to turmn on at that moment where they did not dicharge to a certain level, that residual voltage plus the voltage of the power supply is suppling add them two and you might over power the PC and fry it. If the machine does not give you a problem stay with a blessing in discise
Aug 11, 2009 | Acer Aspire 5630 Notebook
Intel PC wont boot past startup and keeps shutting down unless I disconnect the cooling fan, let it start and then reconnect the fan
might have to get a higher wattage power supply,
the initial amperage draw plus everything else may be causing the stock power supply volts to dip past the limit
maybe download the intel active monitor and study that, or hook up a voltmeter and watch the output at startup.
good luck with your toy
Jun 26, 2009 | Intel (C25704002) CPU Fan, CPU Cooling...
My DC5000 SFF turns on okay then switches off randomly Help!!
Which fan are you referring to? As far as I know the fan in the power supply runs at the same speed at all times. So if that is the fan you are hearing it may indicate that the power supply is failing. The power supply may be over heating and shutting down. I would try a different power supply if you can get your hands on one.
Jan 18, 2009 | Compaq DC5000 PC Desktop
Alienware Aurora desktop crashes on bootup
try to change the cooling fan mayhbe its the problem that your proccessor is over heated.
Dec 25, 2008 | Alienware PC Systems Alienware Aurora High...
Poweredge 1800 trouble shooting support
Upgrade your bios or set temperture high on the management software
Jun 16, 2008 | Dell PowerEdge 1800 Server
HP Pavilion Slimline S3123W Desktop PC - REFURBISHED Logo
369 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
