Question about Goodman Heating & Cooling
The outside condenser unit will run for about 8-10 minutes then the fan will stop spinning but you can hear and feel the motor wanting to run,but also i found the other day that the drain tube for the condensation was not draing because the plastic pipe was sagging in the middle dont know if that could have caused anything
  • rkempa22 Aug 03, 2010
    is there anyway of checking the fan
    will try a new motor and see if that works thanks for your help
  • 760 Answers
Most likely they are not related. Most likely the condenser fan is shot. You should be able to replace it for less than 100.00 If it isn't starting, it could be a capacitor, but since it starts, it's probably overheating, or bearings seizing after it heats up. I'm assuming the drain tube you're referring to is on the evaporator coil in the furnace. The condensate drain should have a trap on it though so that you don't pull the condensation back into the furnace.
Posted on Aug 03, 2010
  • 4,924 Answers
Check to see if the draining work like it should ...cause if the draining is slow ...the water may accumulate inside in that interval of time you mention ...and get to a level that stops the fan from working ...and after it is actually draining the fan may get to work again ...and this to be the phenomenon....To be exact ..the water for condense do not drain itself fast enough to keep a low level inside ..and after a while the level gets to the point that causes the fan to stop..
If this isnt the reason ..than the motor may had been damaged and when it gets to a certain position ..it stops...
  • Catalin Turcu
    Catalin Turcu Aug 03, 2010
    You have to open it ..and actually take a look without the lid ..and see whats happening ...cause there can be nothing else to stop the fan ..inside..The fact that is starting and work for a while ..lead to the idea that something is accumulating in a time period ..and cause it ...cause otherwise it will have no reason to stop ...and the single thing present is water...so ..I guess the drainage is still issued..
Problem with GE PTAC-Model# AZ28E09DABM2 - Why won't condenser kick on when switching to AC from Fan. AC was working fine until today...Fan is still working...Pulled the unit out and could feel the h
Hummm. A bit difficult to solve this problem. Seems like the condenser outside is not working, I mean the fan of the condenser. Looks like you have a wall A/C and a wall A/C always have condensers outside the house and near the A/C. Have you checked if the fan is spinning? I don't think the compressor is at fault but check it anyway. You should be able to hear the compressor running either in the wall unit or in the outside condenser housing. The only heat you should feel is from the condenser itself. If you blows warm air, that means the fan is working, if not that means the fan is not working. But don't be confused with the fan not working because in winter time sometimes the fan is not working and some times it does. As I said, it's a difficult problem to solve but at least start with checking the situation with the fan in the condenser.
Jun 16, 2014 | GE Zoneline Deluxe Series Cooling &...
Condenser fan replaced one year ago, fan not turning but can hear motor
the answer to your problem is most likely the motor start capacitor. A AC motor can run in both directions. The start capacitor is used to cause the current to lag behined the voltage which determines the direction the motor will turn. Its posible the start and run capacitors are in one can. so changing one will change the other. However look for a wiring diagram. Do not asume that both capacitors are wired in properly. They may be fighting one another causeing premature failure.
Sep 18, 2012 | Carrier 38CKC036 Air Conditioner
Fan condenser unit wont run
This is usually a bad capacitor or bad fan motor. The capacitor is located inside the electrical panel on the outside unit. You can check these by using a meter that measures Mfds (Microfarads), most of the time you can visually see the capacitor swollen or blown. The fan motor can be checked by a meter that measures ohms, really high ohms are usually bad. If you can't spin the fan blade easily, then it's locked up. What usually happens, the capacitor or motor windings go bad, doesn't spin the fan blade, overheats the compressor so it kicks out on thermal protection till it cools back down, and sometimes the motor will overheat and go into thermal protection also. Just make sure you are getting the 220v to the outside unit too, but shut all power off before doing any trouble-shooting. Hope this helps, feel free to ask any questions!
Jun 30, 2012 | Heating & Cooling
My air conditioner tries to turn on, air comes out of vents but isn't cold, and outside the blades on the AC unit are not spinning. I hear a noise when it tries to turn on but they don't start...
Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor
Jun 17, 2011 | Heating & Cooling
Turned on AC was running fine. 30 minutes later began to hear a strange noise. Opened AC/Furnance closet & heard a sound best described as air letting out of a tire. It seemed to be coming from...
Hi!!
This means that the condenser fan motor (outside unit) failed, this caused to build hi pressure and either activated a safety valve to release the extra pressure or blew a line and R22 Refrigerant escaped from system.
The fix is to replace motor fan and capacitor find the leak and refill system with R22 Refrigerant Gas. It is safe to turn on the Fan Only mode on the Thermostat until a HVAC Tech arrives.
To perform this job parts and labor included will cost: about $300 -.$400. Look on the Yellow Pages for a Tech in your neighborhood.
Good Luck!! Don't forget to Rate this post!!
Aug 13, 2010 | Goodman CKL42AR42 Air Conditioner
RRUDD ACHIEVER 30, OUTSIDE FAN WON'T SPIN.
does the unit outside run at all,can you hear a humming noise or the compressor run or is it just dead.if you hear the comp. run or a humming noise then i would say it needs a new motor.but if you hear absolutely nothing out there,what i would do if you dont have a meter, is open panel on condenser and push the contacts in on the contactor when this is done its like jumpstarting the unit,it should all come on ,compressor and fan motor,if motor comes on then your contactor is bad (cost approx.$50.00) if it doesnot come on then its motor when replacing motor be sure to get a new capacitor with it (cost $80.00 to $120.00 plus cap 5mhz.$5.00 to $15.00) depends on where you get it home depo/menards/etc.high priced try granger or a local a/c distributor youll get it much cheaper.hope this helps
Sep 29, 2009 | Ruud UBHC Air Conditioner
Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
Jun 28, 2009 | Amana PTH123B25AJ Heat Pump Air...
Fan does not turn but motor seems to be running fine
Rain should not affect an outdoor unit. It is designed to be outside. The motor that you are hearing... could this just be your compressor running? If the condenser fan is not operational the compressor will run much louder. TURN THE POWER OFF! See if the fan will spin freely if it is pushed. If it doesn't replace the fan motor. If it does you need to check the power at the contactor going to the condenser fan motor. This is 220 volts BE CAREFULL.. If power is going to the motor and the motor is not running... Change the motor and capacitor. If no power is going to it it could be a bad contactor.
Good luck....
Apr 11, 2009 | Goodman CKL24AR24 Air Conditioner
C6 error code on LG art cool
Try turning the power off at the fuse box, waiting 5 minutes turning the system back on and spray some water on the vents on the side of the outside condenser. If the fan isnt spining get a twig and spin it in an anti-clockwise direction after 1 or 2 spins it should start spinning on its own. continue to hose the vents with water for another 5 minutes. Its important to have the fan spinning as it extracts the heat from the condenser box.
Jan 03, 2009 | LG LSC121PMA Split System Air Conditioner
Bad fan
The condenser fan - the fan which blows across the coils outside the fridge - should be running any time the compressor is running. If you hear the compressor but don't feel air moving under the unit, then the condenser motor is probably bad. It's not hard to replace. Find a replacement motor at a parts store or website like www.repairclinic.com . Some of the fans come with instructions, but it should be easy to figure out. Just be sure to unplug the fridge before you start.
Sep 07, 2008 | Whirlpool GD5SHAX Side by Side...
Heating & Cooling Logo
37 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
