Question about GPS
My skycaddie after being on the charger all night is absolutely dead; when i first turned it on, there was a little blinking red light in the upper left corner...now nothing. i took it to the club where I bought it and they couldn't get any response either. Does it need a new battery ( or does it even have a battery?
    President:
  • 2,923 Answers
Skycaddie is a tough device and the only problem that I could see is that it has a dead battery.
Replacing the battery should make the device work. Check the links below and see which battery is compatible with your Skycaddie:
http://www.nextag.com/skycaddie-battery/products-html
http://www.batteries.com/handhelds-pdas/sky-golf/skycaddie-sg2-battery_R-411150-202592.html
Thank you and good luck!
Posted on Aug 02, 2010
SkyCaddie will not power up.When trying the screen stays on one second. When charging red light blinks up and down arrows stays on.When unpluged from charger the red light and arrows stays on.
This is not actually a camera, nor any kind of photographic equipment. Posting this in a forum dealing with sport equipment is more likely to get you the information you require.
May 29, 2017 | Cameras
Charger not working
When the red light is on it is to indicate that the charger is getting power from the wall outlet. If there is a second light that normally comes on Green when charging pay close attention to it when you first plug the charger in. See if it blinks even once then turns off. If it does that means the charger is not seeing any battery voltage at the plug that goes into the chair. If the green light does not blink at all then it usually means the charger is defective. Also most wheelchair battery chargers will not charge the batteries if the chair is to dead to even turn on.
Apr 12, 2015 | Health & Beauty
My headset doesnt turn on, when I plug the charger the red light starts blinking
Could be a combo of low battery and not yet being connected. Charge it overnight and check on it in the morning.
Check out the
Quickstart Guide
Mark
Motorola Support
Dec 31, 2014 | Motorola Mobility H270 Bluetooth Headset
My sky caddie sg5 wont charge
If you follow these instructions which I think you know how to, it will recharge. If not the rechargeable battery needs to be replaced
To charge the battery, simply follow the steps below:
  1. Gently pull back the rubber cover to gain access to the mini-USB port located at the bottom of the SkyCaddie. Insert the mini-USB connector of the supplied wall charger into the mini-USB slot.
  2. Plug the wall charger into the AC wall outlet. While charging, the charging indicator in the upper left-hand side of the SkyCaddie will show red. The charging indicator will switch to green when fully charged. You may also notice the unit's screen turn on and off periodically.
The battery will charge, even with the SkyCaddie turned off. A full battery charge may take 4 hours. Once fully charged, expect 36 holes of continuous play.
Warning!Always connect the cable to the SkyCaddie first before connecting to AC power or PC USB.
Jul 16, 2011 | GPS
My camera is a vivitar pink (MID0050609) and it wont turn on, unless i plug it it to my charger and when i do the light on the left is red and it just blinks then flash a blue screen turns on that says...
MSDC is not a problem code. It is normal, the camera is informing you that it's connected to a computer. At this point you should see a new "drive" show up in my computer to transfer pictures.
Have you tried turning the camera on when plugged into a wall charger? If it turns on using the wall charger it might need a charge over night. If the camera will still not turn on after a charge the battery is dead and needs to be replaced.
Mar 12, 2011 | Cameras
I had the same problem of the battery charger blinking...
You can fix this! If the battery is really low it won't communicate witht the charger... thus the blinking red light. Charger says - I see you are trying to use me, but I don't recognize this battery. The battery needs a little shot of charge so it can communicate with the charger. Put the battery in and take it out quickly a few times. This will give it the little boost it needs to be able to talk to the charger. Then, you will find, you can charge!
Sep 09, 2009 | Casio Exilim EX-Z57 Digital Camera
Brand new 8320 after his first night charging its not working
when you put the phone on the charger does it show a red light on the top of the phone?
if so your battery is dead, when the battery is charged the light turn green.
you may just have a bad battery. I would take it to where you got it and get another one or a new battery. also your charger could be not working
Jun 06, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
GPS Logo
76 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
