Question about Garden
I have a Simplicity, Regent model 2690438. It has no power and will not move in reverse.
  • 677 Answers
You can use this link to check power issues.
(http://www.ridinglawnmowerrepair.net/)
but if I toggle the mowe in reverse key quickly the motor is fine and the mower will stay running and even cut in reverse."***
That is the detail that might indicate the reverse gear position switch has failed, or is stuck. If the reverse gear sensing switch is active all the time (thinks the trans is in reverse, even when it is not), that would invoke the engine shut down provision in the PTO MIR safety interlock circuitry. Find the reverse gear sensing switch and unplug it to determine if it is shorted or stuck in the active position. On machines that use a "kill engine" circuit in the No Mow In Reverse interlock wiring, the Key switch position that over rules the interlock......actually REMOVES the reverse sensing switch from the scheme (and that circuit becomes open) so the reverse sensing switch cannot ground the magneto, or the ignition module, whichever is used in the specific application. I don't have a wiring diagram that covers your Simplicity, so I don't know exactly how your machine is configured, but all NMIR systems require a sensor (a switch) that detects reverse gear. A particular OEM might use that sensor to directly kill the engine, or feed that info to a relay that will kill the engine (or at least dis-engage the PTO). If a specific wiring diagram for your tractor could be viewed, a more exact answer might be available. Model numbers and serial numbers are needed to get that kind of detail online.
Posted on Aug 02, 2010
How do you change the arbor bearings on an simplicity regent with a 50 inch cut?
You must take the blades and belt off and the well as pulley, the arbor is replaced as a unit and it unbolts with several bolts.
Jul 28, 2014 | Simplicity Regent Riding Mower 23 HP...
Why does my simplicity regent 24 hp not turn over?
For some reason your starter gear isn't coming up to meet the flywheel to turn it. That's why you hear the whineing. If you can take the starter off and take it to your local repair shop and they can fix it for you.
May 10, 2014 | Simplicity Regent 19.5/38
Tuff torq k51
https://www.tufftorqservices.com/EnvEEdefault/FlatHTML/Troubleshooting/Diagnostic_Flowchart_EN_23DEC08.pdf Hey, check out the manufacturers trouble shooting chart. This is a hydrostatic not a geared transmission right?
Apr 09, 2014 | Garden
What year is simplicity model 1693920 serial no 06613
Need the code no, One after serial No. First no. is the year.
Dec 26, 2013 | Simplicity 38in Regent 21hp Briggs
Need wiring schematic for simplicity 38"
go to simplicity web site -support- manuals - model
i got mine there no problem
Aug 16, 2013 | Simplicity 38in Regent 21hp Briggs
Simplicity Regent Starting Problem
The wrong seat switch was installed. There are black ones and gray ones. I believe you need the gray one for open circuits.
Aug 10, 2012 | Simplicity Regent 19.5/38
Garden Logo
301 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
