Question about Intermatic T104-20 Indoor Hot Water Timer
I installed a t 104 timer on my sons water heater with the wires from the panel to line terminals 1 and3 and the load to water heater to terminals 2 and 4. the ground wires to the ground screw i set the on actuator to next to the switch and after a short time it turned on. i then turned it of and set it to the correct time.my son checked it 4hrs. later and said the timer didnt move .he reset the time and checked it the next day and it still didnt move.when you flip the switch manually the load wires are hot. am i missing something or is the timer just defective i dont hear it running
  • 760 Answers
You have wired it correctly assuming this is a 230V water heater. The timer should have come with the motor connected to terminals 1 & 3. You should be able to see two small wires coming from the rear. These are the motor leads. Make sure they are on terminals 1 &3 also. Check for 230V on the 1 & 3 terminals with the load off just to be sure you didn't accidentally reverse the line and load. Check to be sure timer motor is running. GOOD LUCK!
Posted on Aug 03, 2010
Help with 12v Frontier timer
This is Intermatic PB series timer module adapted for various applications, often low-voltage AC and DC loads. Copy following links for specific wiring diagrams:
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html#fm
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#PB1
http://waterheatertimer.org/How-to-wire-TB118-TB178-timer.html#fm
Timer can be wired for numerous applications.
Power is connected to terminals 1 and 2, jumper wire is connected from terminal 1 to terminal 3.
Load wires connect to either terminal 4-5, and to terminal 2.
For loads greater than amp rating, use timer to control contactor. Add line fuse to protect timer from overampping.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 04, 2013 | Hardware & Accessories
My T 104 R has power to Line 1 and line 3 but when switched on nothing on load 2 and load 4. What am I doing wrong.
More information is needed.
How is timer being 'switched on?'
Is this new timer installation? Or timer that worked previously and stopped working?
Open following links for wiring and troubleshoot, and then add a comment with actions taken so far including how you are testing Load terminals 2 and 4, and what voltage shows when testing across terminals 1 and 3.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Jul 23, 2011 | Intermatic T104 24h 208-277v Mechanical...
What configuration do the output power wires look like. Do I connect to 3 and 4 , slots etc. What is meant by "load" in the instructions?
1) You posted under ET104C DPST (double pole single throw) 24-hour 4-ON and 4-OFF per-day selectable-voltage timer
DPST means that timer will turn off two wires going to 240Volt Load or two separate 120V Loads
Open following link for example Intermatic ET series wiring diagrams and manual:
http://waterheatertimer.org/How-to-wire-Intermatic-ET-series-timer.html
2) Load means whatever electrical device is controlled by timer. ie fan, light, motor, pump, alarm-bell, water-heater, bowling-ball-machine etc.
Line means cable coming from breaker box.
3) If you have a different timer, then add a comment with photo of inside of timer door for possible identification and complete answer.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
4) Selectable voltage means you have to choose voltage.
Timer come preset for 240Volts.
If you have 120V 208V or 277V, then follow the vague instructions shown on page 2 #2 of manual.
5) Do not apply voltage to this timer before matching selectable voltage setting with circuit breaker voltage.
6) ET104C has 6 terminals and can be wired many different ways depending on Load voltage, etc.
This timer can do a lot of different things.
If you have ET102C with 4 terminals, then add a comment and clearly explain voltage, color of wires, and what breaker you have and what Load you are controlling for best answer.
7) ASSume you have 240Volt cable coming from breaker box, and that you are controlling a single 240Volt Load like a water heater or pool pump.
240Volt cable from breaker will have 2 hot wires called Line 1 and Line 2
Line 1 black wire will attach to both terminal 1 and terminal 3 (use a jumper wire between terminal 1 and 3)
Line 2 red or white wire will attach to both terminal 2 and terminal 5 (use a jumper wire between terminal 2 and 5)
Your 240Volt Load will also have 2 wires.
Load 1 black wire will attach to terminal 4
Load 2 red or white wire will attach to terminal 6
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 23, 2011 | Intermatic INC ET104C 24 HOUR ELECTRONIC...
I have a wh21 Intermatic water heater timer. I installed the shut off and on switches. They are not working. I opened a manual and it stated to make sure the dial is pushed all the way in. I spun the dial...
You might have your Line and Load wires reversed.
Line wires come from circuit breaker.
Load wires go to water heater.
http://waterheatertimer.org/B220C.html
WH21 wiring: There are 2 Hot Line wires coming from breaker box that connect to terminals 1 and 2.
WH21 is SPST and turns off one Hot wire going to Load. So Load wires connect to terminals 2 and 3. Terminal 2 has 2 wires: 1 Line wire and 1 Load wire.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/wh21%20-%20english.ashx
Keep in mind that WH21 is 25 amp, 2Hp 240Volt timer that will work on water heaters up to 4500 watts. Look at label on side of tank to see wattage. All appliances and motors have labels.
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
Larger wattage water heaters require 30 amp water heater timers as shown following page:
http://waterheatertimer.org/Boxtype.html
Add a comment for more free help.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Feb 21, 2011 | Electric Intermatic Wh 21 Water Heater...
Hi expert: I am installing intermatic P1353me digital pool or spa mechanism and having trouble to figure out how to do this heater Firemen Switch connection. My existing pool timer is T104 and there were...
1) Fireman's switch automatically turns off heater few minutes before turning off pump.
Not all pool timers have fireman's switch.
If old timer did not have it, then don't worry about it.
P1353 has wires marked for fireman's switch, so simply don't use them if you don't want to.
http://waterheatertimer.org/pdf/Intermatic-P1353-manual.pdf
page 21 of manual shows wiring for fireman's switch.
2) T104 and P1353 comparison
Difference 1: T104 turns OFF both hot wires, while P1353 turns Off 1 hot wire.
http://waterheatertimer.org/Compare-120-and-240.html
Difference 2: T104 controls 1 240V load with 1 time schedule, while P1353 controls 3 different 240V loads, each with different time schedule.
Check that wire(s) coming from breaker can handle all 3 loads.
http://waterheatertimer.org/Color-codewire.html
3) 240Volt T104 is wired as follows:
http://waterheatertimer.org/images/T-104-240-Volt-400.jpg
Hot1 from breaker connects to T104 terminal 1
Hot2 from breaker connects to T104 terminal 3
There is constant power on terminals 1 and 3, each terminal has 120V when combined makes the 240V circuit.
Load1 wire connects to T104 terminal 2
Load2 wire connects to T104 terminal 4
Terminals 2 and 4 have power whenever timer turns ON
4) Definition:
In electric wiring, Line means power from breaker, and Load means wire going to light,fan, motor, pump.
5) Converting T104 to P1353
http://waterheatertimer.org/images/P1353-timer-350.jpg
http://waterheatertimer.org/images/P1353-terminals-566.jpg
Hot1 from breaker connects to P1353 terminal 1
Hot2 from breaker connects to P1353 terminal 2
This will power timer electronics and timer clock and switches.
Jumper wire is placed from Hot1 at terminal 1 to each Line terminals 3 5 and 7.
This will put power at the switch, and when switch turns ON, then power will flow from Line wires to Load wires and then on to the Load.
Load 1 connects to terminal 4, Load 2 connects to terminal 6, Load 3 connects to terminal 8
To complete each 240V circuit, Hot2 is connected directly to each Load.
6) You say 'salt' system connects to terminals 1 and 3 on T104, then those wires are carrying constant 240V to that device. So Salt system connects to terminals 1 and 2 on P1353
7) Get a second opinion:
I frequently contact Intermatic for various problems.
P1353 is fairly new product, and manual is long, and I might not fully understand your problem or wiring.
Intermatic answers their email.
http://www.intermatic.com/customer%20service.aspx
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 28, 2011 | Intermatic Digital 3-Circuit Timer...
How to wire a intermatic timer T104 240 v to a 120v?
T104 is 240volt timer.
Timer has terminals A 1 2 3 4
T-104 clock motor must receive 240Volts to operate.
Clock motor wires are white-colored and can be seen connected to terminals 1 and 3.
http://waterheatertimer.org/images/Back-of-WH40-2b.jpg
There are two work-arounds for using T104 for 120V.
1) Diagram 1 showing how to change wiring:
http://waterheatertimer.org/images/T-104-control-120V-Load-500.jpg
Move 240V clock motor wires to terminal 1 and A.
Connect 240V Hot leads to terminals 1 and A. This will power the 240V clock motor
Hot wire going to 120V load connects to terminal 2. This wire will be turned on each time timer turns on, and 120Volts will power the 120V load.
To complete 120V circuit, neutral wire that comes from neutral busbar in breaker box connects to 120V load.
To control additional 120Volt circuit, run jumper wire from terminal 1 to terminal 3.
Connect Hot to second load to terminal 4.
2) Second method is to change T104 timer into T103 timer:
http://waterheatertimer.org/images/T-104-control-120V-Load-2-5.jpg
Replace T104 240V clock with identical 120V clock motor from Grainger
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK1?Pid=search
Neutral wires connect to terminal A.
Hot wire from Breaker connects to terminal 1
Hot going to Load connects to terminal 2
Dec 26, 2010 | Intermatic T104 24h 208-277v Mechanical...
WH40 water heater timer: Does black wire from service box go to terminal #1 and black wire to water heater to terminal #2? Does neutral (white) from service box go to terminal #3 and neutral (white) to...
WH40 is 240Volt timer.
WH40 will not work with 120V circuit.
See WH40 wiring illustration at following link:
http://waterheatertimer.org/How-to-wire-EH40-hot-water-heater-timer.html
There are two hot wires in 240V circuit because every circuit requires two wires to complete the circuit.
Hot wires from breaker connect to terminal 1 and 3.
Notice that small white wires are also connected to terminals 1 and 3.
Small white wires power clock motor located on back of mechanism, so this says power from breaker box must arrive on terminals 1 and 3. This insures that clock motor runs continuously.
If clock motor only runs when manual override switch is clicked ON, then your Hot and Load wires are reversed.
Bare ground wire connects to green ground screw.
Wires going to Load (water heater) connect to terminals 2 and 4.
FYI: Terminal A is not used unless circuit also has a Neutral wire,
See basic water heater circuit Diagram #2:
http://waterheatertimer.org/240-v-water-heater-circuit.html
Terminal A is also used if you want to convert WH40 to 120V timer by replacing 240V clock with 120V clock.
How to convert Intermatic 240V timer to 120V timer
http://www.fixya.com/support/t7353947-intermatic_timer_wg
Dec 24, 2010 | Electric Intermatic Inc Wh40 Water Heater...
I have a Et 70115C Intermatic Timer, I want to install it on my Hot Water Heater, I have connected the 2 110V leads from my breaker to Terminals 1 & 2 and connected the two leads from the hot water...
A) 5 terminal ET70115C.
Voltage selector set to 240.
B) BUT you say you have 120Volts from breaker >>> confusing, so I'm proceeding on basis that you meant to say 240V from breaker.
Add a comment at any time.
C) Review timer:
5-terminal ET70115 timer has NO and NC terminals
NC is normally closed >> this terminal has power when timer is OFF
NO is normally open >> this terminals has power when timer turns ON
For water heater, you want NO terminal 4 so water heater turns ON when timer turns ON
D) Wire for 240Volt water heater
Two hot wires from breaker connect to terminals 1 and 2. This powers timer clock.
Jumper wire connects between terminal 2 to terminal 3. This sends power to the switch circuit.
Wires to water heater connect to terminals 1 and 4
E) 5-terminal timer turns off 1 hot wire to 240V water heater.
Turning off 1 hot wire will stop 240V circuit from working; Water heater thermostats also turn off one hot wire.
240V water heater has black and red wire.
Wire from terminal 4 should connect to Black wire on water heater.
Diagram shows two wires on terminal 1
Two wires on terminal 2
One jumper wire on terminal 3
One wire on terminal 4
Zero wires on terminal 5
Dec 03, 2010 | Intermatic ET70115C Electronic Energy...
My EH40 is not supplying power to the water heater. I hooked the power line in to posts 1 and 2 and I hooked the load out to posts 4 and 6. When I use my power checker it reads no power to posts 3,4,5,...
I have an EH 40 sitting in front of me right now.
The link above shows correct 240V water heater timer wiring for EH40
Link below shows an overview picture of EH 40 connected to 240V water heater
http://waterheatertimer.org/images/EH40-water-heater-circuit-5.jpg
EH40 has a 240V clock.
Terminals 1 and 2 send power to the 240V clock
Power to the clock terminals do not pass through timer to any other terminal
How to wire EH40 for 240V
240V line has 2 hot wires from breaker box.
Lets call these wires Hot1 and Hot2
These wire are interchangeable on 240V circuit
Hot1 connects to terminal 1 with a jumper to terminal 3 (or connect to 3 and jumper to 1)
Hot2 connects to terminal 2 with a jumper to terminal 5 (or connect to 5 and jumper to 2)
240V circuit has 2 wires going to the Load
Let's call these Load1 and Load2
These wires are interchangeable on 240V circuit
Load1 connects to terminal 4
Load2 connects to terminal 6
If the timer is still not working, go back to the breaker and test if it is delivering 240V to the circuit.
If breaker is bad on one leg, then the circuit can test with live power, but the 240V appliance will not work.
240V circuit requires both legs of 240V before circuit is complete.
Oct 24, 2010 | Intermatic EH40 - Electronic Water Heater...
After hooking up line wires to motor and load wires from water heater to load terminals,diasgram shows jumper wires from terminbal 1 to terminal 3 and terminbal 2 to tertmninal 5. voltage is 240.thank you ...
That is correct.
LINE 1 (incoming hot wire from source or circuit breaker) connects to terminal #1 then jumps over to terminal #3 using the _same_ gauge wire.
LINE 2 (other incoming hot wire from source or circuit breaker) connects to terminal #2 then jumps over to terminal #5.
The LOAD (outgoing to water heater) then connects to terminals 4 and 6.
Aug 09, 2010 | Intermatic EH40 - Electronic Water Heater...
Intermatic T104-20 Indoor Hot Water Timer Logo
57 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
