Question about Rheem EcoSense by 7.4 GPM Tankless Water Heater Natural Gas High Altitude
I live in area code 20912 (Takoma Park Md.). Please, suggest few Plumbers in my area that have experience installing ecosense 180DVN tankless water heater. Thank you. Marcos V.
    Problem Solver:
  • 4 Answers
75104
Posted on Aug 19, 2010
C7 error code what is the problem
Copy following link for Rheem/Richmond/ Ecosense tankless computer troubleshoot and error code resources:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
C7 might mean tankless computer motherboard has gone bad
If tankless is older than 5 years, then cut losses and replace with tank-type heater so there is less maintenance and repair expense, and homeowner or local plumber can make repairs without calling tankless computer technician:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 08, 2013 | Water Heaters
I have a ecosense tankless water heater #rtg-74pvn-2 how far can i take the vent
Feb 2013
1) Rheem/EcoSense tankless product manual does not have specifications for length. Error 11 will let you know if venting is improper.
Often, tankless are installed outside because unobstructed venting is key for combustion of the amount of gas coming out of 3/4" gas line.
2) Copy following link for Bradford White venting: Exactly same as Rheem, but more installation detail. No maximum lengths given.
For lengths greater than 5 feet, a condensate trap must be installed. Acidic water from hydrocarbon combustion will damage metal, and destroy heat exchanger inside tankless if water drips back into unit.
http://hometips.me/Tls/Venting-Bradford-White-tankless-gas.pdf
3) Copy following link for tank-type power vent tables:
Generally, the longer distance requires larger vent diameter, and there is max number of elbows and/or air-flow restrictions.
http://hometips.me/Mar/Bradford-White-Power-Vent%20-tables.pdf
4) Otherwise call Rheem/EcoSense, and add comment saying what resources they offer.
Mar 06, 2013 | Water Heaters
What does error code 13 mean?
1) Copy following links for Rheem tankless error codes
http://waterheatertimer.org/pdf/Tankless-Error-code-13.pdf
2) Maintain water heater as shown in product manual to avoid common error codes.
Dec 28, 2012 | Rheem EcoSense by 7.4 GPM Tankless Water...
Have an Ecosense Tankless Water Heater with error code C7. It then flashes to 76 degrees and gives cold water. How do we remedy?
Before calling service technician, open following links for troubleshooting resources and typical manuals.
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
Tankless water heaters require yearly maintenance.
Many causes for common error codes are covered in the yearly maintenance.
Jul 18, 2011 | Rheem EcoSense by 7.4 GPM Tankless Water...
Our water gets cold half way through our shower. we have to go to the garage and shut it off and then turn it back on. This happens almost everytime we take a bath or shower.
1) You posted under Rheem tankless
Open following link for useful troubleshooting resources:
2) Unit can have internal part failure for example PC board, and result is that you get no error code.
This would explain why re-setting the tankless works.
3) Unit could also have loose wire or loose connection.
Or maybe the heat exchanger needs to be de-limed.
Or incoming gas, or incoming air, or vent problem.
Or water pressure, or water flow.
4) Without an error code, the problem can be household plumbing problem.
http://waterheatertimer.org/pdf/No-Error-Code.pdf
5) Tankless repair is a large and developing field, and technicians train for years and still see new stuff each day.
Do-it-yourself tankless troubleshooting and repair might take equal amount of work.
First thing you want to do is read the manual several times.
Pay special attention to the word 'maintenance' and make sure you are properly maintaining water heater on yearly basis.
Next thing is to find qualified technician in your area, and put that person's number in your rolodex wallet. When technician comes over, ask that person for do-it-yourself tips and tricks.
6) Add a comment with your experience so other with same-similar problem can benefit.
7) Take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 25, 2011 | Rheem EcoSense by 4.2 GPM Tankless Water...
My ecosense 180dvn sends out an error code of 13 after 2min 30 seconds. It is always after 2:30 min. I can shut it off after 2 min and back on and it continues to run. But the water has to be shut off...
I have the exact same problem with error code 13 on my Rheem/Ecosense 180dvn . The unit ran good for at least a year, and then I started getting the same error 13 every few minutes. I called the Rheem service department, and they told me to check the vent installation as well as the gas pressure. I reinstalled the vent with new seals. I only have about 6 ft of vent, so there should be very little resistance. I checked the gas pressure, and it shows 9 in H20 pressure, which is well in the range recommended. The service center scoffed at the suggestion that it could be their circuit board. I am totally at a losss and at the verge of ripping this very expensive installation out of my attic.
Jan 30, 2011 | Rheem EcoSense by 7.4 GPM Tankless Water...
What size recomended the gas pipe for rheem ecosense by 7.4GPM oytdoor tankless water heater
1/2 inch if you are using steel pipe (which is the most hearty for outdoor installations).
Happy installation:)
Aug 22, 2010 | Rheem EcoSense by 7.4 GPM Outdoor...
My tankless eco-180dvn water heater is sending me a 12 code, what does that mean?
That is a flame failure..there are many reason for this
be sure you have gas
there could be air in the gas line
flame sensor dirty
Jun 23, 2010 | Rheem EcoSense by 7.4 GPM Tankless Water...
Rheem EcoSense by  7.4 GPM Tankless Water Heater Natural Gas High Altitude Logo
75 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
