Question about Estate TGDX640JQ Gas Dryer
MY Estate TGDX640JQ Gas Dryer PROBLEM IS AS FOLLOWS ALL THE CLOTHING GOT BLACK SPOTS ALL OVER (DOESNT COME OUT ) SOMEONE SAID ITS FROM THE DRUM! ANY ADVICE?
    President:
  • 3,773 Answers
It could be your washer leaking oil into the tub
Check paddles inside dryer drum for looseness if something oily got under
the paddles it will leak onto the clothes
Check felt strip at the back (and front) of the tub if it came off it could transmit junk into your dryer
if this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 02, 2010
What is this feature-"Wringle Prevent"
What the wrikle prevent does is after cycle is done if you dont go take clothing out right away is will tumble the drum without heat for 30 seconds every 10 minutes till the door is opened so the clothing doesnt sit there and wrinkle but gets tossed around lightly so wrinkles dont set in.
Gene
Aug 08, 2011 | Estate TEDS840JQ Electric Dryer
Whirlpool Estate gas dryer dries but has a loud rattling sound when its in operation.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 11, 2010 | Estate TGDX640JQ Gas Dryer
Dryer wont stay on when i release the start button
You may have an issue with the motor. Contact an appliance service company.
Apr 14, 2010 | Estate TGDX640JQ Gas Dryer
ESTATE GAS DRYER IS NOT DRYING IT STARTS WARM
Yes replace the solenoid coils. Easy fix and cheap too. Do it yourself for under $40.
Sep 11, 2009 | Estate TGDX640JQ Gas Dryer
Dryer ran all night now no heat
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Jul 13, 2009 | Estate TGDX640JQ Gas Dryer
Timer not working on estate model TGDS840JQ1
Try first tripping the circuit breaker for ten minutes and see if this reset the board.
Here is the part: PS394424
Check also the connector:PS345626
Here all diagrams for your appliance.
Parts must be tested before replacement.
May 07, 2009 | Estate TGDX640JQ Gas Dryer
No puilot on.
U must rmove the whole front of the dryer to get to the pilot. Good luck.
Oct 17, 2008 | Estate TGDX640JQ Gas Dryer
Timer doesnt move while dryer is on
Please page me here so that i can get back to you
May 19, 2008 | Estate TGDX640JQ Gas Dryer
No heat
mcwilliams if you pull the over off the front of the dryer at the bottom you can see the gas burner assy. Put the dryer on time dry and start the dryer, you should see a glow from the ignitor, then hear a click, then the heat come on. In the auto dry mode, the timer advances along with the dryness level. No heat, No timer advancing. If you don't see a glow, there should be a thermosat on the heater can, see if it is tripped. If so if it is resetable, reset then try again. You may have a bad ignitor.
Feb 03, 2008 | Estate TGDX640JQ Gas Dryer
TGDX64OEQ1 Gas Estate Dryer
Sounds like the hi-limit temp switch is sensing too high a temperature and is shutting off the dryer. This is a safety feature and is usually tripped because the outlet air flow is restricted, and resets itself after it has cooled down. Check to see whether the rest of the vent in your house is clogged and clean it. It could also be an inlet fan or blower which introduces air into the drum. If this is not working, there will be no air flow into the dryer, causing excessive heat in the non-moving air in the dryer.
Feb 01, 2008 | Estate TGDX640JQ Gas Dryer
Estate TGDX640JQ Gas Dryer Logo
74 people viewed this question
Top Estate Dryers Experts
Tim Whalen
Mike
John Tripp
John Tripp
Are you an Estate Dryer Expert? Answer questions, earn points and help others
