Question about Danby Portable Air Conditioner
My danby silhoulette modol dpac120060 fills with water and must be emptied 3-4 times a day, very inconvenient, what can I do to fix this??? ( it has worked for half the summer with no issues and now will blow cold air for approx 5 hrs and must be emptied )
2 Suggested Answers
koolbreezes
  • 540 Answers
SOURCE: danby silhouette dpac120060, there is
Was this gradally or all of a sudden, cause the thermostat switch could be bad or it vibrated and spranged a leak!
Posted on Sep 04, 2008
Why does my Danby DPAC9006 Portable AC fill up with water so quickly all of a sudden?
ac units work by removing water vapor from the air
That accounts for the water that is getting into the collector
now if the water volume is increasing , it can be from an increase in humidity of the air
portable units have to have an opening ( window or door ) to pass out the hot air and that allows more moisture laden air into the room. Maybe the next unit you get is fixed so that all of the doors and windows can be kept closed
Jul 26, 2018 | Danby Dehumidifiers
My DPAC10061 is filling up the water bucket to soon after emptying like 20 minutes. Why?
  1. DANBY DPAC10061 MANUAL Pdf Download. - ManualsLib
    www.manualslib.com > ... > Air Conditioner > DPAC10061
    View and Download DANBY DPAC10061 manual online. DPAC10061 Air Conditioner pdf manual download.
Aug 03, 2015 | Danby Heating & Cooling
Danby portable Dishwasher advances from pre-rinse to dry and then beeps continuously and dry light continues to blink. Doesn't proceed, reset or stop cycle. Just continues to blink.
I actually found out (one of) the solution to this by accident. It could be the water source is not providing enough pressure
I purchased a Danby DDW1899W-1 and, using the connector screwed into my utility sink in the basement, I connected the water. When I tried to run a cycle, I had the same results (filled/emptied 4-5 times, beeped and went to dry cycle).
My alternate, long term plan was to put a Y-splitter (with shutoffs) on the hot water line for my washer, and have one hose go to the dishwasher when needed. I purchased a washer line hose from Home Depot and a 3/4" to Quick Connect fitting from Ace Hardware and then connected the dishwasher to this.
And, Voila! Problem solved!!!
To confirm this was the solution, after the first completed cycle, I connected back to the faucet and, once again had the fill/empty/beep/dry problem. Reverting to the split washer water feed, it was able to run the cycles properly (again!!!)
So you may just need a line that will supply more water pressure to the dishwasher.
Good luck and, hopefully, this solves the problem.
MP
Oct 18, 2014 | Danby Dishwashers
The water level will not stop filling up to the level desired. Washer will not drain out and then I need to empty it with a cup.
Your water level sensor is likely faulty. Contact your retailer, or Danby directly, for a replacement and instructions on how to do so. Note, if this is in warranty, they may require you to bring it to a service center.
Aug 27, 2010 | Danby DWM99W Top Load Washer
Danby standup aircondioner ( 3 in 1) , does not MODEL APAC9030
If you receive an answer to this I have the exact same problem... dougakers at msn dot com
Jul 13, 2010 | Danby Heating & Cooling
My Jura Impressa xs90 keeps stating fill system, even after filling the system several times for the last 3 days.
Empty the Water tank and fill it with warm water. Then keep trying for some time and the problem will get solved.
Oct 15, 2009 | Jura Capresso Impressa S9 Coffee...
Danby ddr7009ree - continuous drain won't work
I have the same Danby unit and the same problem. When you take out the water bucket look inside and find the two holes where the water drips into the bucket. These holes are approximately 5/16" and 3/8" diameter. These holes need to be plugged. Your local hardware store has an assortment of specialized parts boxes. Find the box that contains "corks" of various sizes. They sell for about 20¢ apiece. I bought 5 within that size catagory and two of them worked! Problem solved.
Aug 31, 2009 | Danby DDR6588EE Dehumidifier
Water fill light stays on all the time and compresser will not come on
water fill light stays on how can I fix this problem ?There is no water in the internal tank or the external tank.Please help
Sep 10, 2008 | Danby Heating & Cooling
Danby silhouette dpac120060, there is no longer any cold air coming out 1 year old
Sep 03, 2008 | Danby Heating & Cooling
Danby Portable Air Conditioner Logo
85 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
1STHVACMAN
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
