Question about Microwave Ovens
When I close the latch and try to press the buttons it will not start up. Is there a reset switch?
    Problem Solver:
  • 7 Answers
Unplugged the cord and try again. if not something wrong with key pad
Posted on Aug 03, 2010
Hi, My Bosch built in microwave won't start when I close the door unless I slam it. I suspect the switch. Think so? Can I get at ithe switch to replace without removing the whole unit from the
You will need to remove microwave to access casing, remove casing and check door micro-switch. The switch activator will need adjusting to enable door interlock to activate.
Sep 29, 2014 | Bosch 500 HMB5050 Microwave Oven
My microwave intermittently blows the downstairs sockets
If it is tripping the breaker when you just close the door, I think it might be one of the door switches that the latch activates. There are usually 3 switches behind the latch holes in the microwave. One is a safety monitor switch that is suppose to blow the internal fuse if the microwave is started and the door is not closed properly. It should blow the micro fuse before the house breaker unless you have a weak house breaker. It will do the same thing if start is pressed and it senses a problem with the door. You say the problem is intermittent so I assume you do get it to work at times so I'm guessing most of the microwave is OK. I'm pretty sure you have a door switch problem--- either out of adjustment ---or 1 of them going bad.
Apr 03, 2014 | Neff Microwave Ovens
Microwave oven will not start but the light stays on even when door is open.
One of the micro switches in the door is stuck ( faulty ) there are normally 3 switches so after removing the lid open and close the door and you will see the door latches pressing in the button of the micro switch and one of them would indicate that one of the switches is not in line with the latch to press the button in or one of the micro switches has melted inside cosign the switch to release normally open or normally closed, you need a multimeter to test the switches in that case
Oct 07, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Indicator states door is open and it is closed
One of the micro switches has gone bad take of lid open and close,the door and you will see the door latch pressing in a button on the micro switch look and see if can spot one with a button not popping out nicely like the other ones if you can't see any problem with your eyes you would need to use a multimeter to test them
Oct 04, 2013 | Microwave Ovens
Hi I have a new Kenmore microwave model 721.8503 - it is a month old and wont turn on.. I close the door and the light stays on and it wont work..the door is completely shut
It sounds like the light switch isn't being deactivated which is preventing the microwave from operating (a failsafe).
Look to see that the buttons inside the microwave (where the latches are inserted when you close the door) are actually being pressed.
They may be out of place, obstructed, or your latches on the door may be damaged.
If you don't see anything wrong, try pressing the buttons yourself (with a pen bottom) to see if the light goes off.
Dec 18, 2010 | Kenmore Microwave Ovens
Microwave will not cook/start when start button is pressed.
You can get the latch itself from either partstore .com or repairclinic .com
Apr 19, 2010 | Emerson MW8168B Microwave Oven
When I press the clock button, the microwave turns on and starts counting down from 30 seconds. The stop/clear button will not work to stop it. I have to open the door to stop it. I unplug it but it...
Hello :
It could be bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly .
good luck .
please rate !
Mar 30, 2010 | Amana ACO1520A Microwave Oven
Microwave suddenly and radomly turns off
yes ,the latch switches will need to be replaced , bad connection
Nov 06, 2008 | Sharp R-1480 Microwave Oven
Microwave Ovens Logo
22 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
