Question about Toshiba Satellite A15-S129 Notebook
Motor bussing sound system slow
Syetem locked up , had to do a system restore. couldn't get it startup right had a buzzing motor running. took it to geek squad they did the system restore. Everything opperates real slow some kinda program still running on to machine sound like a motor of some sort constantaly runing on the laptop. driving me nuts. and help/susgestions?
  • 61 Answers
Have a look at the fan on the processor if its running slow it will be making that noise so your processor is over heating and in turn making your pc run slow. replace this fan now. if your processor overheats too much it will burn out.
Posted on Apr 25, 2008
Motor attempt to start an make buss sound ,do it need bareing
high pitched sound is the bearings, if its a buzzing sound and motor doesn't come on, run capacitor may be shot
Dec 21, 2014 | Heating & Cooling
Buzzing under hood of truck but disconnect batery and it stops
The buzzing is probably coming from an electric motor that is stuck or a relay that is stuck closed. You are probably going to need an automotive electrician to run down the problem. If it is an electric motor, the motor will get hot to the touch. Does your heater motor work? Does all the electrical system operate properly? Check all your electrical system. To isolate the problem pull one fuse at a time then put it back if the buzzing doesn't stop when the buzzing stops, you have isolated the circuit. Then you can take it to a mechanic and have it fixed.
Apr 11, 2014 | 2003 Volvo S60
The locks on the kias 2007 spectra when you push the button it makes bussing sound in the drivers door also they will lock the doors on you.
Sounds like the electric motor that controls the lock arm is possibly sticking and grinding on itself causing the buzzing noise. Or it could be something inside the panel has created an issue for the arm and motor to move freely.
If you go to this site: http://www.kiatechinfo.com you may be able to find a way to remove the door panel and check out the function of the lock. I'd give it a look see before you take it to a shop, it could be something simple. Replacing the entire lock would probably get a little on the expensive side.
Jan 03, 2014 | 2004 Kia Sedona
Unit is hot all around the freezer. Items on the top two shelves of feezer are not frozen. A kind of buzzing sound when the unit is running.
I would check the condenser grill. It sounds like it is dirty and not able to disperse the compressor generated heat to the air.
Now the bussing sound, is your condenser grill fan operating? If not, then I would suspect the fan motor, or contactor-relay or the start capacitor.
Sep 08, 2011 | Kenmore Side by Side Refrigerator
My computer starts at the blue start up screen and it takes it about 10 minutes to load the log in screen. It wasn't doing this at first. I have done multiple system restores, but it hasn't helped....
hi Jamiekom.
Slow Running Computer Fix. Use MSCONFIG to improve computer's speed at startup. You can disable certain programs that auto-start at startup and spend less time waiting for your computer to fully boot. Simple tip to improve your computer's performance.
Why is computer so slow to startup? My Windows computer boots up slow. A slow Microsoft Windows boot up can be caused by a number of different issues. The following document contains various suggestions and tips that can help improve the overall speed of your computer's startup.
Why does it take so long to boot up my computer?3. Upgrade your hardware. A new computer is naturally going to start up faster because it has faster hardware, and a clean operating system. ... As we said above, computer startup is slow because you're moving information from a slow hard drive to faster RAM
Computer running slow at startup Check out this Quick Tip
computer slow on start up Google Search
Dec 07, 2017 | HEWLETT-PACKARD Black 20" TouchSmart...
My system restore couldn't run and so as all of my .exe files couldn;t open...
Please take a close look in your System restore pane are there any restore point(s). If there are no restore points you will not be able to restore your system. System restore point is an image file taken from a previous Windows state is time and is vital to restore your system.
May 17, 2011 | Microsoft Windows 7 Home Premium 64BIT...
The volume is giving me troubles. cant go up and down.
Click on it using the RIGHT button, select it there, open up properties and uncheck MUTE.
Feb 24, 2010 | Computers & Internet
My laptop is so slow and it makes a sound
SPEED UP PC BY DOING FOLLOWING
1.Removed unwanted startup entries and disable unwanted services Start > Run and type "msconfig" Start > Run and type "services.msc" 2.Defragment on regular intervals defrag volume [-a] [-f][-v] [-?] 3.Keep System Restore turned off 4.Disable disk indexing
THE SOUND COULD BE MANY THINGS HDD GETTING OLD OR CPU FAN FAULTY TAKE LAPTOP TO PC REPAIR FOER STANDARD MAINTENANCE CHECK UP
Aug 31, 2009 | Computers & Internet
My acer aspire m1640 is booting up then just freezing or it says windows failed to start then scans for a problem finds one and says it can't do it automatic help
Tapping F8 key during bootup and get the window to run in Safe mode with networking.
When you login to administartor to window destkop.
The following is the procedure for a 'clean boot'. I am assuming that you have XP. If you have a different OS, just let me know and I will send you the appropriate procedure to boot clean in that OS.
1. Click Start --> Run --> Type MSCONFIG --> Click OK 2. On the General tab, choose Selective Startup 3. Uncheck Process SYSTEM.INI file 4. Uncheck Process WIN.INI file 5. Uncheck Load Startup Items 6. Click on the Services tab 7. At the bottom, check Hide All Microsoft Services 8. Uncheck all boxes in the window or click the button labeled Disable All 6. Click OK 7. Click Restart
After restarting, reinstall the downloaded software. Next, do the following:
1. Click Start --> Run --> Type MSCONFIG--> Click OK 2. Replace checkmarks in the items that you previously removed them from. 3. On the General tab, choose Normal Startup 4. Click OK 5. Click YES, when asked to restart your computer
Hope that helps...Should you have any further questions, please feel free to post them here.
Regards,
Ellin
Oct 18, 2008 | Acer Computers & Internet
Acer Aspire 3003 Strange Problem
Uninstall AVG and then download and install Avast Free version Antivirus. It is way better than AVG and MIGHT fix the problem.
Sep 10, 2008 | Acer Aspire 3000 Notebook
Toshiba Satellite A15-S129 Notebook Logo
232 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
