I have a Model MF 4150 , Serial No. JVM 73593 The Basic Guide that came with the purchase does not provide the necessary information. I have a phone on the same line as the fax machine (plugged into the same wall outlet) and another phone with an answering machine that is plugged into the fax machine. The answering machine is set to answer after 4 rings and the fax machine is set at five rings. When the fax machine is set to default to COPY the fax dos not pick up. When the default is set to FAX the phone that is plugged into the fax machine does not ring. Also, when I pick up the extension phone that is not plugged into the fax machine for an incoming call, the fax tone comes on and it is impossible to carry on a conversation. Would you please advise me how to fix these problems with step-by-step instructions. Thanking you in advance, Andrejs Jansons jansonsa@gmail.com (201) 944-1273
  • 13,433 Answers
I beleave the best solution would be to get Distinctive Ring Detection from your service provider and then setup the devices accordingly.
Im unable to find your products manual to find instructions on DRD and settings so at this time im unable to provide you step by step instructions on how to get DRD, enable it and set it up.
But thats the thing to get.
Posted on Apr 25, 2008
  • Ekse Apr 25, 2008
    Its Distinctive Ring Pattern Detection
    The manual nitro provided has instructions on how to enable it, and it seems he has also provided them for you so I wont bother to repost them.
    heres the link to the manual again, thanks to nitro
    http://gdlp01.c-wss.com/gds/0900006459/i...
    Page 21 or 1-8
  • Ekse Apr 25, 2008
    well I would go with DRPD nitro suggested AnsMode
    Try hes solution first. if it works, accept hes solution.
    if it doesnt try mine.
  • 589 Answers
I'm going out on a limb here, and guessing it's a Canon imageClass MF4150... If not, please disregard this solution.
The advanced manual can be viewed / downloaded / printed here, directly from Canon:
http://gdlp01.c-wss.com/gds/0900006459/imageCLASS_MF4150_Advanced_Guide_EN.pdf
To stop it from interfering with the telephone conversation:
Issue: Fax interrupts telephone conversations in answering machine mode (AnsMode)
Solution: Setting the Receive Mode - ICMF 4150
  1. Press <Additional Functions>.
  2. Use <I have a Model  - la.gif> or <ra.gif> to select [5 FAX SETTINGS], then press <OK>.
  3. Use <la.gif> or <> to select [3 RX SETTINGS], then press <OK>.
  4. > or <ra.gif> to select [3 RX MODE], then press <OK>.
  5. Use <la.gif> or <ra.gif> to select the desired receive mode, then press <OK>.
    - For [AnsMode], make sure an answering machine is connected to the machine.
    If [AnsMode], [FAX/TEL], or [DRPD] is selected, you can select some settings as below:
    [AnsMode]
    --- [AnsMode CHK TIME] (select time from 10 to 30 seconds for the answering machine to start playing outgoing message after receiving a call)
    --- [FAX DETECT TIME] (select the duration from 10 to 70 seconds for the fax to detect)
    [FAX/TEL]
    --- [RING START TIME] (select the time from 0 to 30 seconds for the phone to start ringing after receiving a call)
    --- [F/T RING TIME] (select the duration of ringing from 10 to 45 seconds)
    --- [F/T SWITCH ACTION] (select the action the machine will take after the ringing ends, Receive or Disconnect)
    [DRPD]
    --- [NORMAL RING]
    --- [DOUBLE RING]
    --- [SHORT-SHORT-LONG]
    --- [SHORT-LONG-SHORT]
    --- [OTHER RING TYPE]
  6. Press <Stop/Reset> to return to the standby display.
  • 3,037 Answers
One option is that you can set the fax machine to 'manual' (it won't answer when the phone rings) and then if you answer your phone and hear it's a fax, you just type *51 on your phone's keypad and it activates the fax machine. It works like a charm...only down side is that you can't get a fax if you're not home to manually answer the phone first, so this option isn't for you if you get many faxes.
The option you probably want is that you need to extend your "CHK TIME" to about 25sec and the "FAX DETECT TIME" to about 30sec. You should be able to find these options pretty easily on the menu on the fax machine.
About the fax tone, try the above first and we can work on that if this doesn't fix it.
thanks
  • Benjamin Patri
    Benjamin Patri Apr 29, 2008
    please don't forget to rate my solution, thank you
    Master:
  • 788 Answers
What model answering machine do you have? You most likely have to put the answering machine into a fax mode, which will let it answer but pass on the call to the fax machine if it hears a fax tone.
Serial # model 23xtr mf dt pkw206421e
Hi, Thomas I would love to help you but due to the magnitude of yesterday's solar flare the batteries in my crystal ball are dead and my mental telepathy headset circuitry was melted. I need the year, make, and model of your motorcycle please click on the word "COMMENT" below and provide this information in the box that will open and then click on the green comment box in the bottom right-hand corner after it posts I will receive an "ALERT" icon that will allow me to respond to your information. Good luck and have a nice day.
Jan 04, 2017 | Motorcycles
Please can i install my camera because i loosing the cd and the program my camera model:lw-ic100
If you registered the software after purchase the manafacturer may have this information on file, and they maybe able to provide it to you. Otherwise you may have to purchase a new serial key/ software for them.
Apr 21, 2010 | Microsoft Office 2007 Basic for PC
WINDOW VISTA ULTIMATE SERIAL KEY
This information is with the software that was received upon purchase. If you registered the software after purchase the manafacturer may have this information on file, and they maybe able to provide it to you. Otherwise you may have to purchase a new serial key/ software for them.
Apr 19, 2010 | Microsoft Windows Vista Home Basic Edition...
My canon mf 4150 would not fax. what could be the
Apr 12, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
My canon imageclass mf 4150 says toner not set but there is a cartridge in it.
my canon imageclass mf 4150 says no paper even paper loaded, kindly help to solve.
Feb 11, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
No display in canon imageclass MF 4150 can any one
if you are a technician you repear your copier power supply board chack your power supply board fuse
Jun 28, 2009 | Canon MF8180C Color Laser MFC Printer
Cleaning my Canon 4150
Steps to clean a laser printer are roughly the same for all models.
Follow the instructions on the website below.
Clean your laser printer safely with these tips.
Apr 15, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
153 people viewed this question
k24674
