When i have left my laptop off from around 8:20am - 4:00pm, i go to turn it on and it beeps two or three times. Sometimes it starts normal sometimes it doesn't
    Problem Solver:
  • 4 Answers
Kind of a vague problem... Many times on BIOS startup you will get an internal beep, but should not affect your computer from booting normally. When you say it sometimes doesn't start normally, what do you mean by that?
Posted on Apr 25, 2008
Make sure the switch is on REG mode. Make sure there are NO batteries in it. Turn power off at wall for a few minutes. Turn on and it should beep three times. Then put the batteries in. If it beeps more than three times, the printer is probably jammed or faulty. Make sure it can turn. Try taking the ink roller out as it sometimes gets sticky and jams the printer.
Mar 23, 2016 | Sharp XE-A101 Cash Register
So my laptop froze yesterday and I turned it off to restart it. When I restarted it it everything was normal but after the starting windows goes away it usually goes to the login page well now all it does...
Try starting it in safe mode.
When the computer is starting just after the beep or when the bios info goes away press f8 repeatedly and you will get an option to open in regular or safe mode.
Alternativly you can also hold down teh ctrl key and it should do the same.
Did you install or update and drivers recently?
Aug 25, 2011 | Compaq Computers & Internet
Hello!I would be very gratefull if you help me with the startup problem of my Acer Extensa 5630!Sometimes(recently very often)it just won't turn on.I red some complaints of other owners of the same...
Not at all, If your computer was closed normally, it will start normally.But if you closed it from the button without shutting down from the windows, it will not start normally the second time.
so, when you face such a problem, just remove the battery for 12 min. then start up using power cable, hold ESC for 10 sec (when you hear a beep) stop and close from the button then power up using your battery, it will start correctly.
Feb 01, 2010 | Acer Extensa 5630-6806 Notebook
Problem booting
Any beep code from pheonix starting with two beeps relates to ram issues. If you have treid swapping the ram and it only gives the first 2 beeps then most likely the RAM controller on the north bridge or the data channels themselves are damaged on the motherboard.
You can try running a single chip of ram in each slot at seperate attempts. If it is a data channel damaged this will bypass the problem although it will cripple the laptops performance. Either way, the only permanent and proper fix would be to replace the oBo which I doubt would be cost effective on this unit.
Jun 02, 2009 | Gateway Solo 9500 Notebook
My PC auto matically restart when turning it on
The beep you hear is your BIOS trying to alert you to an error in the POST (power on self test) routine. Without knowing the manufacturer of your motherboard one can't be certain what the beeps indicate...see this link for more info:
It's possible you have some kind of infestation, and it's possible there's something more systemic, but without knowing the make and model of your system I couldn't say.
Sometimes three beeps indicates a keyboard could try another keyboard or unplug yours and see if it will boot up "normally" without it.
Otherwise, report back with some more info and we'll take it from there.
Mar 28, 2009 | Microsoft Windows XP Home Edition
PC Hardware Troubleshoot, works slowly,IDE not detected sometimes
try go to this website download Download SeaTools for DOS now!
and run diagnostic to hdd but remember stand by floopy disk to create diagnostic disk.IF this diagnostic disk check said no error so you hdd is ok.try put the ram to different pc may be is RAM or motherboard faulty
Dec 21, 2008 | Computers & Internet
Acer aspire 7100 continually beeps while starting up
I had the same problem, I went to the keyboard and shut down the beep there is a check mark next to it and take the check mark off, the beep will stop
Nov 07, 2008 | Acer NSK8458AN Keyboard
Please help - it's possessed!
Click HERE for an explanation of beep codes
May 24, 2008 | Compaq Armada E500 Notebook
3 beeps at start
hmmm...that's not good. works fine with no battery. I suspect your motherboard may be taking a vacation from working soon.
got backup for your HP?
Feb 12, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
