Ok when i turn it on the tv screen all the sudden turns blackhow do u fix it
  • 11,361 Answers
LCD flat panel TV.
Please read my guide for basic understanding first.
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there are some troubleshoot you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Posted on Aug 03, 2010
Fix a vizio tv
problem with the set take it in and have a quote to fix
Feb 23, 2016 | Vizio Televison & Video
Sony tv picture goes green
HAVE IT REPLACE WITH A NEW ONE
Sep 12, 2012 | Sony Internet TV NSZGT1
Orion 27" TV; Works ok
Turn off CCTV. Or Closed Caption. Several settings in the menu for CCTV. Just be sure they are off and your box should be gone.
Jan 17, 2011 | Televison & Video
My LG HD tv screen suddenly went green. sound is
I disagree with info provided, if screen of your LG lcd tv becomes green that means inverter board is working and lcd tv does not have convergence ICs.
Please unplug tv from ac wall socket for minute to get it reset, replug back in and turn it On and check its picture.
If still showing green screen then change input source with remote, if tv shows same green screen on all inputs that means its either lcd panel problem or digital signal processor got bad loacted on main board. Local tv repairman is needed to confirm and fix it.
Thanks.
Jul 21, 2010 | LG 42LC2D 42 in. LCD HDTV
When I turned on TV, sound was ok, but there's a black screen
Same thing happened to me. I turned TV off. Then turned it back on holding down both On button & Source button & got the picture back. Doesn't fix it for good. But when it happens, I "fix" it the same way. Happened twice in last three weeks, I'd say. Better than junking it for now.
May 10, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
My Vizio 32" Flat Screen suddenly turned blue and "no Signal"
Check the cable connector. If it is OK then the turner has gone bad. Replace main board will fix it.
Feb 06, 2009 | Vizio L32 32 in. LCD HDTV
Noise
I also had that problem before but with a different brand. I got my tv checked and the problem was with the picture tube this is a problem that can only be fixed by professionals.
Jun 18, 2008 | Symphonic ST419E TV
TV powers on but NO screen pops on.
1 check remote control. 2 tv comes to stand by to protect itself 3 there might be problem in power supply section 4 & if it is ok check horizontal section. 5 call skilled tech to fix it. 6 it is not a major problem.
Sep 26, 2007 | Sony FD Trinitron KD-36XS955 36" TV
Audio ok, but Video goes from color to black.
the tv turns on fine, but after 5 - 30 min or so, "sometimes MORE " the picture all of a sudden go's black. Sound is ok it is 100% loose contact problem. 1 please check for any connector or print for loose. 2 in signal processor ic there might be loose. remember there is no component failure.
Sep 24, 2007 | JVC AV-32D305 32" TV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
