Question about Ranger TR-966 CB Radio
Ranger PPR-RBT1; when I try to link with my phone via Bluetooth it asks for a security code. What the heck???? Thank You in advance for any help. Danny
KEITH HOW DO YOU GET ZERO'S TO COME UP
Posted on Dec 30, 2011
Security code 4 the ranger bluetooth ?? 0000 . all zeros..
Posted on Sep 21, 2010
  • leudee Oct 31, 2010
    How do get the zero's to come up?
PPR RBT1
All radio's are factory set up and although you can tweak parts, this is usually at the expense of longevity or reliability.
To tweak a radio properly and ensure it remains legal, you will need the service manual, an accurate frequency counter and standard, a nice dummy load and an oscilloscope. If you turn anything inside and do not know what you are doing, you could end up stressing output components due to signal mismatching and possibly end up with spurious transmissions which can interfere with other electronic equipment.
Mar 03, 2014 | Ranger Radio Communications
Ranger PPR-RBT1
Tommy, I know why you like the radio, but I must warn you that it isn't type accepted for the amateur band. (it would be the same thing as using an amateur radio for the fire department or sheriff for emergency uses.) I have looked for the mods to change it into a 10-meter radio, and they are not to be found. My suggestion to you is to look in a recent issue of QST about building a Bluetooth (c) transceiver for your regular 10-meter radio. I had to do the same thing for my HF rig which happens to be a Yaesu FT-857D. Fire me an e-mail if you want the schematics for the box. 73 and good luck!
Mar 03, 2014 | Radio Communications
Where can i get the ranger professional bluetooth ppr -rbt1 repair?
if its still under warrentee then send it back to where it was made. If not send it to a place like Bells cb in Fl. or another reputable shop. Inquire with them before you send it to them and they will tell you how to send it.
Feb 13, 2013 | Ranger TR-966 CB Radio
I have a cobra Bluetooth model # ppr-rbt1 that will not transmit out and only picks up other people if there real close and only every now and then. When I key the mic the needle does not move. What can...
Hi michael, my name is John. Welcome to FixYa. Check your antenna system. Check your SWR they will check it for free at Radio Shack. A good antenna is a magnet mount, you can put it on your trunk or cab, as long as nothing is blocking it. Have any more problems, let me know. Thanks for choosing FixYa....John
Nov 30, 2010 | Cobra Radio Communications
How do I set the clock on my Ranger professional with Blue Tooth
Press dimmer switch 3 sec, then when first two digits (hour( of clock flashes set hour using Phone Volume switches. Press dimmer again to set minutes, then when done press Dimmer once more to activate the clock. It displays in military configuration (e.g., 1:30 PM will read as 1330 Hrs) See user manual page 8
Jul 14, 2009 | Ranger TR-966 CB Radio
Trying to connect via bluetooth adapter bu10 and the installation asks for a security code
The initial security code should be 0000, this is assuming that you've not changed it.
For any future questions or issues I'm also including the support link for your printer.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=257&modelid=14723#SupportDetailAct
May 12, 2009 | Canon Bluetooth Adapter - BU10 (9434A005)...
I can't receive any mp3 songs and pictures via bluetooth
when it ask passcode, its an security protection, u'll just have to input any number, and same as to the other phone. like 1234 and you'll input the 1234 passcode on which phone you are pairing with, try changing you setting in your message setting cause, mostly when via blue tooth it stores on your inbox.
Jan 04, 2009 | Nokia N72 Cellular Phone
I can't get my phone to connect with other peoples
I assume you are trying to connect to another phone via Bluetooth. It would help quite a bit to know what kind of phone you are trying to connect to, but here is what you need to have configured on your phone for Bluetooth file transfers:
1. Create a link between your Motorola RAZR Phone and any Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life.
2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is usually provided by the Bluetooth device manufacturer, not the RAZR (unless you are connecting to another phone). Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
4. You can now "Copy" media files to the phones nearby that you have connected to. Copy is an option while browsing through the files.
Dec 14, 2007 | Motorola Mobility RAZR V3
Can't connect with other peoples phone
Radio Communications Logo
301 people viewed this question
Top Ranger Radio Communications Experts
Jon Piercy
perdue40
TekkiDave
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
