Air conditioner turns off after five minutes - Heating & Cooling
5 Suggested Answers
  • 4 Answers
SOURCE: AIR CONDITIONER LG S18AN
The operating LED will be blinking 5 times, means that there is a
comunication error (serial comunication) between the outdoor and the indoor unit.
Posted on Jan 20, 2009
tbreeze47
  • 3083 Answers
SOURCE: Air conditioner will cool for
I would think the unit could be low on freon, overheating, shutting down...cooling down, and starting back up. Either this or the thermostat is bad. Feel the compressor to see if it's overheating, and it's not, check out the thermostat. Here's how to check the thermostat:
http://www.ehow.com/how_2167621_troubleshoot-refrigerators-thermostat.html
Good luck, and hope this helps.
Posted on Sep 25, 2010
shastalaker7
  • 1515 Answers
SOURCE: Air conditioner cool for about
Hi there, this sounds as though the compressor is shutting off on its overload. Its getting hot and overloaded. Here is what you can try, to solve this problem, unless the compressor is going bad. Lets hope not! Go out side, unplug the unit, and take your water hose and wash out the condenser coil. They get dirty and cause the head pressures in the unit to get very hot, which in turn causes the compressor to draw almost maximum amps and shut down. It will cool off after quite some time and start over again. I bet this is your problem. Be careful not to flatten the aluminum fins on the coil as this will prevent air from being released out the back of the coil. Let me know your outcome. If this works, great, please rate me on my help to you.Thank you,
Shastalaker7
A/C, Contractor
Posted on Jun 08, 2011
heatman101
  • 43501 Answers
SOURCE: The air conditioner turns on and will blow cool
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Posted on Aug 26, 2011
Hi I keep getting a ch 67 after the unit starts fine and runs for like five minutes fan on all units work during that five minutes any thoughts would be greatly appreciated
Low freon pressure switch is turning it off. As the coils cool down the pressure drops. As time goes on it will run shorter and shorter cycles. In warm weather freon 22 low pressure should be near 70 lb
410A freon about 150 on the low side
May 02, 2015 | Heating & Cooling
I have a fedders portable a/c unit and it works for five minutes and it then shuts down. The circuit braker does not trip and I plugged the unit on different locations with the same results. The unit has...
Thanks for your information that " The unit has very cold air".It's cut off by indoor coil sensor.
Reason for shut off in 5 minutes.(There are one or more reasons for the problem) Check as follows.
1. Evaporator coil,air filter and bower wheel full of dusty. Service your unit completely.
2. Check rpm of blower motor. If less rpm replace capacitor.
3.If all above is o.k and still problem means defective coil sensor. Replace it.
Hope, it's helpful?
Jan 19, 2011 | Fedders A6X05F2D Air Conditioner
UNIT TURNS ON WORKS FOR FIVE OR TEN MINUTES THEN SHUTS OFF
Check the thermostat, the sendor the control or the relay unit.
You must trace from the sensor to the control unit , check at the point of running and stop the change in voltage to confirm.
The control unit can be trigggered externally to test. If so the sensor can be the suspect.
Sep 03, 2010 | Amcor ALD12000EH Air Conditioner
Can a 12000 BTU thru the wall AC be installed as a
Yes... no problem... just need to use cardbord of something to seal off the open spaces around it...
heatman101
Jul 21, 2010 | Frigidaire FAH106N1 Wall/Window Air...
Thermostat will not go below 74 previously would go to temp set.
Once it shuts down it will stay off for about five minutes to protect the compressor...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 08, 2010 | Sharp AF-S125MX Thru-Wall/Window Air...
Blowing of cold air every 5 minutes, and it says FP on the screen
FP is the code for frost or freeze protection. The unit will automatically do this periodically to prevent any damage caused by low temperatures although it should not be running as frequently as every five minutes. If the outside temperature is not low then it could either be a problem with the exterior thermistor (not the one you see from inside your room) or the control board could be on its way out.
Feb 15, 2010 | Amana PTH123B25AJ Heat Pump Air...
Dec 28, 2008 | LG LS-K1830CL Cool Mini Split Air...
Out air compressor fan runs for about five minutes then the fan stops turning unit is about 5yrs old
if the compressor stays on for a short time after the fan stops most likly the fan motor has problems could be capactor or bearings dan
Jul 17, 2008 | Heating & Cooling
"KACHUNK?"
Either its the thermostat or the compressor itself, you need a qualified technician with this problem.
May 28, 2007 | Samsung AW1291M Air Conditioner
Heating & Cooling Logo
169 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
