Question about Samsung DVDR120 DVD Recorder
Samsung dvd door will not open, stuck in loading mode
    Problem Solver:
  • 14 Answers
Ah. Its your mechanical loading belt that is weak.
Posted on Aug 03, 2010
  • 23442344 Aug 28, 2010
    I have the same problem with my samsung dvd-vr300. dvd door will not open. How do i change the mechanical loading belt?
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Curtis DVD player - Stuck
Do the following
Unplug power cord.
Wait two minutes and plug it back.
Keep repeatedly pressing the eject button while you start the unit, before it starts reading cd inside. Do this a couple of times.
If you cannot eject the disk in this way you will need to take unit apart.
Unit won't start until the disk is inside, as it tries to read the disk , disk is faulty and unit get stuck.
Posted on Aug 26, 2008
  • 13 Answers
SOURCE: We have a DVD stuck in our Phillips DVD/hard disc
Dear helen, I don know if this is possible with your machine but I have removed dvds by either; turning the power off to the machine then turning it back on then trying the remote again or the facia control. I f that dosen't work try unplugging it and using a knife to gently prise the door open then manualy pulling the cradle out. I have done this also without any damage.
Posted on Oct 09, 2011
Why doesn't the open/close button on DVD player of DVD/VCR combo work?
Assuming there is not a forgotten tape stuck in the VCR side, the mode selection logic has gotten all confused. On the VCR side, a tape is grabbed and loaded to be played. There probably is an EJECT button that is enabled for later use. The DVD side is disabled so no buttons work. On the DVD side, the open/close button is enabled (if no VCR-side problem is detected), allowing you to place a DVD in the tray and close it to play. The VCR side is disabled so no buttons work. That's the theory. From your description a sensor on the VCR side may have failed or been damaged, causing the player to keep reverting to VCR and preventing use of the DVD side.
Sep 21, 2015 | Emerson EWD2204 DVD Player/VCR
Dvd door will not open on my Samsung dvd model R155
The gears are jammed, or the timing gear is out sync, or a bad loading belt, plus in rare cases, the gears crack or break.
May 08, 2012 | Samsung DVD-R155
DVD door will not open and eject DVD. It says it's opening on the screen but it does not open. DVD is stuck in there
Hello
Either its loading belt in the DVD mechanism, or its loading motor has damaged. It is common that the loading belt will get loos of break. Loading belt is a small belt fasted between loadin motor to loading gear mechanism. Replace the same first. You have to open your TV and pull out the DVD mechanism outside for repair. If replacement of loading belt doesn't help, loading motror is faulty, and should be replaced. OK.
Apr 24, 2011 | RCA 20F510TD 20 in. TV/DVD Combo
POWER UP, BOTH DVD &HDD BUTTONS LIGHT, LOADING DOES NOT APPEAR...NO RESPONSE VIA ANY MODE OF COMMUNICATION.
turn off and unplug from power outlet, let sit a few minutes....then plug in power up, check JVC home page on net to see if they have problems with these, could be a disc stuck in unit....if door will not open, take back to where you bought it....I have a Pioneer but I did take the cover off and a DVD was stuck in side, I managed to carefully remove it....it is a slow process as everything is made from plastic
Mar 06, 2010 | JVC DR-MH30S DVD Recorder
Samsung ht-ds610 wont work at all
Loading mechanism is stuck some where in loading or unloading process.
Unplug unit form AC outlet for couple of minutes and replug back in, power up and check.
Feb 11, 2009 | Samsung HT-DS610 System
Stuck in safe mode
There is a botton on the remote (Lock) that puts in safe mode and off.
Dec 03, 2008 | GoVideo VR3845 DVD Recorder/VCR
Stuck in Standby
FOr the MVDP1102 Memorex 10.2 portable DVD Player:
I had the same problem. If you open the disc door there is suppose to be a plastic arm underneath the right side of the lid which when you close the lid, with the movie disc in, this arm will press through to a switch inside the machine and that will set the player in load/play mode. Memorex did not have parts for this player, so I unscrewed the bottom and one black screw inside where the lazer light is. This will allow you to handle the bottom back side and see underneath where the screen is you will find the switch. I rigged up a pin wire and did some small drilling. I was successful, but it wasn't easy. Most times I just fail and toss. I thing my son just open the disc door too much and that's how the piece was broken.
Apr 05, 2008 | Memorex MVD2042 DVD Player
Dv-c503 pioneer dvd player
the magic eye on the door opener in been obtruated by something .. like a small object stuck on a cd or someone might just open the door and let something in it .. stuck on the slidetrack ..and interfer with the sensor .. maybe kids???
Dec 30, 2007 | Pioneer DV-C503 Multi-disc DVD Player
Samsung DVDR120 DVD Recorder Logo
404 people viewed this question
Jerry Greenberg
Jerry Greenberg
