I had a paper jam, after removing the paper the red light still stays on. The printer were turned down , but the problem says. While turning the printer on one can hear the motor trying to start but then it stops. Please help or direct me to a service agent. Thanks
I had the same problem and I finally solve it!
I simply took out the fuse and put it again in the cartridge, i don't know why, but it works
Riccardo
Posted on May 02, 2008
What fuse and how is it done??
Posted on Jun 22, 2008
This azzhole ricardo there is no such fuse anywhere near any side of the cartridge on the ML-2010. I would know, I took the whole printer apart destroying it in the process. I had a persistent red light, wasnt a roller, wasnt a paper jam, wasnt the cover left open. Anyways the fuse he refers to is in the power circuit (where the usb and power plug go, if you unscrew 1 screw on each side that should be able to slip off, look at the orange board, not the green one and you will find it. Before you do any of this have the power plug unplugged for 2-5 min, then gently left off the unit with a dull flat screwdriver angle it at 45 under fuse and bring to 90 degrees gently. Now the trick question is if this is not complete bs do you take the fuse out power the unit on, and put it back or do you just take it out wait 1 min and put it back and power on. My printer is destroyed good luck.
Actually, there _is_ a fuse on the toner cartridge, right where Riccardo said it was. I looked, I didn't see it, I looked again, I found it.
Thank you rigan86! Worked for me, too!
Posted on Jun 20, 2008
SOURCE: Samsung ML 2010 Laser Printer Problem
paper registration system damaged. Check all sensors in this system.
Posted on Oct 17, 2008
Feb 16, 2011 | Samsung ML 2010 Laser Printer
Oct 01, 2010 | Samsung ML 2010 Laser Printer
Jul 15, 2010 | Samsung ML 2010 Laser Printer
Jun 26, 2010 | Samsung ML 2010 Laser Printer
Feb 08, 2010 | Samsung ML 2010 Laser Printer
Aug 07, 2009 | Samsung ML 2010 Laser Printer
May 08, 2009 | Samsung ML 2010 Laser Printer
May 02, 2009 | Samsung ML 2010 Laser Printer
Oct 17, 2008 | Samsung ML 2010 Laser Printer
Jul 15, 2008 | Samsung ML 2010 Laser Printer
2,114 people viewed this question
The red light comes on and the printer does not power up properly. Some one has suggested taking out the fuse. How is that done?
Similar problem. Had a paper jam with the ML-2010. Removed jam, but the printer continues to jam--or will print with lines across the paper (drum issue?). Very annoying. Printer is a year old and has light usage.
you should take out your cartridge shake it a bit and put it back , and it works for me.
I can't see the solution proposed by rigan86. I am having the same problem, what do I do?
Never mind! I got it.
