Question about Toshiba 36HF71 36" TV
I came home from work and the picture color is odd. The skin tone of everyone is a blue tint and I can't get it back to normal.
  • Toshiba Master
  • 1,229 Answers
You have a bad ground on a color output transistor or a bad ground on a color output resistor. These are located on a board that is attached to the CRT. Also check the diodes on this same board, these may be bad as well. In worst cases the color output transistor and a diode will be bad. Thanks for asking!
Posted on Aug 02, 2010
Panasonic TC-P42U1 plasma. Lost it's vivid colors basic color is black and white and green and blue if tint color tone etc. Is turned up. However a blue ray video plays with full color. Could it be a lose...
I have an old Toshiba TV and was going to replace it with a new plasma because it has suddenly (the week of July 19, 2010) lost color. It has only green and blue tint. Changing the "tint" on the menu didn't help. The color comes and goes relative to nothing that I can measure, such as how long it is turned on, etc. Reading other complaints from owners of Plasmas, I am thinking it is cable related. I have Charter Cable. Playing a DVD, I have to readjust the tint back to normal. Hope this info gives clues.
Jun 27, 2010 | Panasonic TC-P42U1 42 in. Plasma HDTV
The screen has a reddish tint to it. Seems like a color issue and not sure what to replace. The picture works fine but everyone is red. Not sure if there is a bulb to replace or what? Any suggestions? This...
You need a simple color adjustment. (Color Calibration)
You don't need to spend money on this. Try it for yourself.
Your main problem is that your color temperature is set to warm.
You need to change temperature to COOL or 6500K depending, on how it is labeled.
You will see improvement, but there is a little more...
Move "Color" DOWN from it's current position (probably at 50) to somewhere between 30 and 40. (Just a couple of clicks above where the color rapidly washes out.)
At this point there will still be slightly unnatural color to skin tones, but all the artificial "sunburn" and blaring red will be gone.
Last (as far as color goes) move the tint 2 to 4 clicks toward green. This added green tint balances the color so that the flesh tones become completely accurate and realistic.
For even better detail, continue your home calibration here:
http://www.wowvision.tv/main.htm
Jun 13, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
My hp monitor's colors are messed up.
Did you already try it on another PC?
Try new VGA cable?
Otherwise you may have to open it up and look inside for failed components.
http://s807.photobucket.com/home/budm/allalbums
Mar 29, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Not able to get red tones on TV
the problem is at the crt base .there r three red,blue n green o/put.verify if there is dry in the soldering n check the red cathode voltage it must b around 150 .if not then check the resistor that feeds the red o/put.it could b 12 to 15k. all crt have 3 driver color red blue n green,whenever one driver not working the color changes.that wat happened to ur tv now i do not know wat model u have.the drivers may b transistors or now its ic that r being used like tda 6103q.best of luck
Jan 03, 2010 | Toshiba 27AF45 27" TV
Samsung DLP Facial Colors off after changing color wheel
Do you mean that red and blue are reversed? If so, you may need to remove a jumper, see end of linked article. Pinkish-yellow or orange sounds like a good description of skin tone, but perhaps too intense. If the color is too intense, can you just lower the color level with the color control? Or can you just change the tint with the tint control? Otherwise, see http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/ including the comments at the end.
Oct 11, 2009 | Samsung HLN4365W 43" Rear Projection...
Color is a problem. Screen picture has greenish
well it seems you have an issue with one of your video boards, it could be that the Analog Video Board (the one with the inputs and outputs) is partially damaged, but it can also be your Digital Video Board, which is the one that projects the image
Jul 22, 2009 | Panasonic Televison & Video
Green tinted people
The only time I have had issues like this was because of the Component Cables not being in the right position (the Red and Blue connections switched), or a bad Component Cable where the Blue Connection is not receiving a signal. Swap out the cable to be sure and double check that it is properly installed. Green to Green, Red to Red , Blue to Blue.
Hope this helps,
skyassoc
Jul 18, 2009 | Samsung HLN5065W 50" Rear Projection...
Mitsubishi cs-40503 tint problem
internal codes are good, but when the is like what you post then a tech is what you need.it seems that one of the problem is the flyback transformer or the CRT cap.have a tech check you unit.
Sep 08, 2008 | Mitsubishi CS-40503 TV
Color on my Protron television makes people's skin BLUE
Hello JoanSaly:
It sounds like your small signal board is causing that issue.
Aug 11, 2008 | Protron PLTV-32 Television
Optimal Settings
Picture +13
Bright +9
Color -3
Tint -1
Sharpness -10
Temp Normal
I think this provides the best color to my eye, by everyone will be a bit different. For instance, I think factory Vivid is too saturated (like most LCDs) and the whites in Cinema are too blue. It's personal choice really.
Dec 04, 2007 | Panasonic TH-50PX75U Plasma HDTV
Toshiba 36HF71 36" TV Logo
155 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
