If there is no yellow socket (terminal) on the TV, as in most recent year's VIERAs:
Connect the Yellow male plug from your gaming device into the TV's GREEN female socket (terminal).
Press INPUT on the Panasonic TV remote and select the Video input. In some VIERA models, you need to press INPUT, go down and select the Comp. option and then press >right to select Video.
To get audio (sound), make sure to connect the Red and White plugs from the gaming device into the TV's Red and White sockets (terminals) that are labeled AUDIO.
Cable box have HDMI port,hook it up on a HDMI cable to the tv,will improve picture quality greatly.Tries HDMI cable to hook up the PS3 system and go in setup changes to HDMI setup will get HD format picture,will be very clear no more grainy and inconsistanty.
Hi, take out the dvd player from port 1 and try the Wii in port 2 or 3 if the picture is good on the wii then you will need to get a 1 way scart lead for the DVD, not a fully populated one as these can cause interference between video inputs.
This is a common problem for the 5-8 years old LG LCD TV, the problem is a defective main board, due to the new part dried out sources, the only way to do is to re-flow the soldering on the main board yourself by using your kitchen oven, this is the procedure:
Re-Flow Soldering Procedure for LG Main Board
1.Pre-heat your kitchen oven to 385 degree (No more than 400 degree);
2.Put the main board on a card board (like a pizza box board) in the oven;
3.Heat it for 10 minutes (No more than 10 minutes);
4.Turn the oven off & leave the door open, at this moment, do not touch or move the board until it colds down to the room temperature.
Yeah no color coz its black and white. Color coding commonly yellow wire for video, red and white wire for audio. It should also be from DVD to TV, video out and audio out going to video in and audio in. And switch the TV to play video and the audio inputted. Maybe TV/Video Switch or button.
i assume your using either a yellow/white/red or yellow/green/blue/white/red rca lead to plug in to your telly, make sure they are all going to the same input ie, input 1 or input 2 and the correct colours
I bought a wii a few days ago and like everybody else mine too was in black and white with a grainy picture. I have a Panasonic lcd flat screen and thought I had connected it corrected, I got somebody out to have a look at it and found out there are some connections on the side of the TV which I hadn't even noticed before, once I put the red white and yellow leads in these and set the TV to AV3 everything is in perfect colour. Hope this works for some of you.
Check the video connections on the back of the Bose unit. I have a Lifestyle 38 and had an issue with video only playing in black & white. Turned out to be a loose connection.
