Question about Garden
I need a diagram on routing a cub cadet pto belt. Mine came off and now not sure where it goes back on at. Thanks
  • 252 Answers
Here is website for parts and diagram
http://www.partstree.com/parts/?lc=cub_cadet
click on lawn and garden tractors ,
then find your model from the list and click on it
let it open and save a copy
make sure you get the model of your cub cadet rider mower 1st
cheers hope it helps
paul
Posted on Aug 03, 2010
Cub cadet ltx1042kw the blades will not engage
Either the pto is not engaging or you missed routed the deck belt. Google your model number and you should get a link where you can see the correct belt routing.
Jul 27, 2016 | Cub Cadet Garden
How do i replace v belt on ltx 1040 cub cadet.
Nolan, Check the attached links,instruction and guides for belt replacement on Cub Cadet. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Change the Deck Belt on Cub Cadet Riding Lawn Mower Using Model...
How To Install or Replace Drive Belt on Lawn Mower Cub Cadet
How to Change the PTO Belt on Cub Cadet Riding Lawn Mower
cub cadet belt replacement diagram Google Search
Jun 30, 2016 | Garden
Need diagram to replace belt on cub cadet mower
Hi there r photos on how to fit the belt. Type in Google. cub cadet mower photo of belt. There r also movies on YouTube how to fit belt. Type in how to change the PTO belt on ? cub cadet , good luck
Apr 20, 2016 | Cub Cadet Street Sign- tractor lawn riding...
Belt routing for cub cadet 1641
Easiest way is to remember; flat side of belt goes onto flat pulleys and small V shape goes into V shaped pulleys.
Oct 08, 2014 | Garden
Cub cadet wiring diagram
My Cub Cadet has an override feature so the PTO will continue to run even in reverse. If yours is like mine after you turn on the PTO turn the key back toward off about a quarter of a turn and push the button above and slightly right of the key. A light in the button should turn on to show the override is active.
Aug 10, 2014 | Cub Cadet Garden
I need abelt routing diagram
This is a Parts diagram website. Find your model then work through it until you find what you need
http://www.cubcadet.com/webapp/wcs/stores/servlet/ARIPartFinderView?storeId=10051&catalogId=14101&langId=-1#/s/CUT/782/
Aug 06, 2014 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
Belt diagram cub cadet 3184
Pages 41-43 might help:
http://www.manualslib.com/manual/33969/Cub-Cadet-3184.html?page=41#manual
Jul 25, 2014 | Cub Cadet 46" Deck Drive Belt for Lawn...
Dar n PTO Clutch
Most likely low tension. first, double and triple check the routing of the belt against the manual. then make sure you have the correct belt.
May 04, 2014 | Cub Cadet Garden
I have a 2011 cub cadet ltx1040 with 42 inch mower deck. replaced belt, pto cable and spindle brake pads. Belt is still loose when pto engaged and cannot find any adjustment to tighten belt. All parts...
If all the parts are correct then you need to check the belt routing diagram. Sometimes you can find it on the mower deck and in the owners manual. Look carefully at the spring locations on the deck to be sure there correct. George
Aug 31, 2013 | Garden
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
May 10, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
Garden Logo
261 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
