Question about Dishwashers
Hi, I have not use my GE dishwasher for over six months now. I just turned it on yesterday and discovered that the dishwasher will fill the water but then it does not go to the next step. I tried different dial cycle and nothing happens. I suspect there is an issue with the timer? What should I do to fix this problem? Thank you
    Problem Solver:
  • 13 Answers
The heating element has gone more than likely, check condition £25 to replace
Posted on Aug 04, 2010
Our 3 month old ge adora dishwasher stopped working properly yesterday. Made funny noise and later I started smelling something burning. Opened it and noticed no water was in it. Restarted and still n
Sounds like the water inlet valve isn't working. Check your house water pressure and make sure it's not above 80 psi. If it isn't, then call a repair company that handles GE warranty work.
Dec 02, 2014 | GE Adora Dishwasher. Built-In Tall Tub...
Washer makes grinding noise but isn't doing anything else
Remove the cap off the agitator, flip back the top of the console, remove any nuts keeping the tub in the console. There will be a clutch ring that needs to be replaced. I have an older top load washing machine. I agitates, fills, and drains, but it won't spin. It sounds like it is spinning, but it doesn't. It might be the coupling. That is a 3 piece kit that goes between the transmission and the motor. I found the directions how to do it over the internet, got the part and fixed it myself.
https://www.structuredsettlement-quotes.com/
Nov 08, 2013 | GE GSM1800NWW Spacemaker 18" Built-In...
I noticed dishwashing detergent residue on my dishes and then I discovered the dishes were not being rinsed. I've discovered it will not fill in the normal or rinse modes. It only fills in the auto clean...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101';;;;;;;;;;;;
Apr 22, 2011 | Maytag MDB7100AWB Dishwasher
We have a ge dishwasher and it stopped draining yesterday and when we took out the filter it was filled with mold. The machine also makes sounds during the cycle
If theres mold it will also be in the pipes use a strong bleach with boiling water this should help to unbloke Very careful with bleach and boiling water they do react (bubbling).
May 17, 2010 | Dishwashers
Problem draining became problem with filling
Hi I would look at the water valve. Located left front . Remove the front panel , the bottom panel. check the water valve
Dec 23, 2008 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus Dishwasher.
the pump/motor is froze up because the water has evaporated out of it. turn the motor using the fins and you should feel it free up. unplug ac first
Nov 14, 2008 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Nautilus Dishwasher No water when i turn it on
You need to prime the dishwasher by placing two large cups of water into the bottom.
Mar 19, 2008 | GE Nautilus 24" Built-in Dishwasher
Diswasher Leaked, now Won't Work
if you see a float inside of the dishwasher make sure its cleaned well.that float tells the control board when to drain and to fill with water.the symptom you descibe tells me its trying to drain,make sure the float moves freely.if you dont have a float you will see a metal probe clean that up as well.try this and if it doesnt fix the sensor may be part of the drain body and it has failed(leaking).
Aug 27, 2007 | Bosch SHU9915UC Dishwasher
Dishwashers Logo
22 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
