Question about Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW)
I cannot find the location to add freon to my frigidare uprifgt freezer model number-ffu16f9cw1
  • Frigidaire Master
  • 43,501 Answers
Most freezers do not have a tap from the factory to add aditional freon...you will need specialized equipment to be able to do that...
As the weather is getting warmer for many people their freezeri cannot find the location - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 03, 2010
What size is a frigidare 297080400 upright freezer
Hello friend, thank you for your post!
In order to provide you accurate information could you provide me with your model number please? Normally you can locate the serial tag (which lists your model number) on the inside wall of your freezer. With that information I can provide you with the cubic ft. of your freezer. I look forward to helping you further. -Matt
Oct 04, 2014 | Frigidaire Freezers
How do i add freon to system
Get a saddle valve like THIS ONE. Sand down the suction line or compressor ear and attach the valve. Connect hoses to the valve and add some freon. The low side pressure should be around
5 PSI.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 30, 2010 | Magic Chef Chest Freezer MCCF5WBX
Frigidaire stand up frost proof w/ temp alarm / 98' model. Compressor running, no power problem. Removed interior panel and found that evaporator coils not getting cool. When switch for alarm is pushed on...
If your compressor is running with no freon, It should be very hot. Check if it is. And if it is and the freon has leaked out. Then you must find the leak in the system before you add more freon. If you dont this will be an ongoing problem. The freon will leak out after any length of time. This is a very hard task to find the leak, and you will be money ahead to buy another if you dont find the leak than to re charge every year or so.
Jun 29, 2009 | Frigidaire Freezer Refrigeration White...
Frigidare refrigerator not cooling
Clean the condenser , low freon plugging up cap tube (freon line). Tom
Jun 18, 2009 | Freezers
Frigidaire Chest Freezer Model LffC1466DW4. Inside coils are frozen and copper pipes underneath are frozen. I have let set unplugged for 2 days and tried again. Ice forms within a few hours. How do you...
you dont want to add any more freon to it to start with
it either has to much in it or the thermostat is not turning it off and making it run to long, you need to see what temperature you are getting in the freezer and what suction pressure the unit is running on to determine if it is over charged
Apr 29, 2009 | Frigidaire Freezers
Need to add freon
  • if you are tapping into a sealed system, then you use the larger of the two copper lines coming out of the side of the compressor (this is the low pressure line, the compressor pulls from this side).
  • clean off the copper tubing with some fine sandpaper before installing your tap.
  • it is very easy to over fill a system with freon, so i would recommend pulling down the system to -30 psi and holding for at least 20 minutes. then add a known amount of freon to the system.
  • let it run for a while, it will take a little time to get the temperatures down.
Jul 02, 2008 | Whirlpool 15.2 cu. ft. / 430 liter Upright...
UNIT NOT COOLING(IS RUNNING WHEN PLUGGED)
only reason refrigerent may be needed is that there is a leak so adding more will achieve nothing. unlikely to be needed. i assume compressor is running. probable causes of no cooling are compressor fault or a blockage in the pipe sysyem. not diy
Jun 30, 2007 | Avanti 1.4 cu. ft. Chest Freezer...
Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW) Logo
276 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
