Question about Intex Pool & Spa
Which salt water test kit(s) would you suggest for my 18'x52'' steel sided pool. i have a Krystal Clear system model CS8110 . what do you think of the salt strip readers?
  • Intex Master
  • 8,404 Answers
Have the salt tested free where you purchase chemicals. While there, get a Taylor test kit to test for CL, pH, Alk, CA and Cyanuric Acid.
Salt is persistent in the water - translation - once in the water, it stays there, it doesn't go away except through splash out or back wash. Your salt should be around 3200 ppm. Get rid of the metals in the water before you do anything ... get the Alk around 100 then adjust the pH and introduce your CL. Cyanuric Acid protests the CL you are making. Some places call this 'stabilizer' and the reading should be around 60 to 100 ppm. Calcium is like salt ... persistent in the water ... lost under the same circumstances.
I hope this information helps you.
Thanks for your interest in FixYa.com. If this was helpful ... plese remember to vote and leave a comment.
Thanks
Posted on Aug 04, 2010
Testimonial: "thank you for your very helpful information."
  • A Miller Aug 05, 2010
    My pleasure ... thanks for the great 4 thumbs up vote.
  • A Miller Aug 13, 2010
    dad-burn spell checker ... wish it worked! I meant to say cyanuric acid "protects" your CL.
    thanks
Is the saltwater system better then regular filter system
consider this
if the pool construction is concrete with steel re-enforcement, the salt will corrode the steel and after a while ,cracks will appear in the cement ( cement is not water proof and will over time allow the salt into contact with the steel which rusts , expands and cracks the cement
next salt pool operations have a chlorinator inbuilt into the system that produces chlorine that is used to disinfect the water and those units are subject to expensive repairs
you will need a filter ( sand or paper) to remove objects from the pool during the cleaning processes
now add the cost of salt , possible repair costs to the unit and compare to just sand or filters and you have a decision to be made
Really the best advice is to go to several different pool shops and ask questions about what I have suggested--- rust , corrosion, salt cost on going, parts and repairs and power costs- sand or filter costs.get a balanced information base then make a decision that is comfortable for you
Mar 23, 2016 | Intex Krystal Clear Model 635 Pool Filter...
Why is my saltwater pool turning green?
balance the water with chlorine super shock it once in balance your chlorinator should maintain a chlorine reading if you have a heavy bather load you must shock manually
Jul 29, 2014 | Intex Krystal Clear Saltwater System Pool...
Help with low flow on intext krystal clear saltwater system.
You can check the inlet line where it comes from the pool... Their is a little sreening/filtering system in the the parts that screw together and connect the valve to the pool... When I unscrewed mine, it was jammed with bugs, leaves, green algea... That did the trick for me... I am sure you already changed/cleaned the filter in the filter/pump that comes before the Salt water system... That will cause low flow as well...
Jun 04, 2014 | Intex Automatic Salt Water System for ...
Can i use a sand filter with the intex krystal clear saltwater system?
Yes you can.
The saltwater chlorinator is connect to the outlet water pipe from the sand filter before the water returns to the pool.
Depending upon the model of the saltwater chlorinator It may need to be mounted horizontally or vertically, check with the installation instructions..
Apr 11, 2012 | Pool & Spa
Free Chlorine won't register in pool?? I have done everything the manual suggests and cannot get a reading on chlorine from my pool. If you check the water coming directly out of the generator it...
if getting reading from unit and losing by the time it gets to pool water chlorine is locked need to add non chlorine shock to oxidize and super shock pool
Sep 02, 2017 | Intex Automatic Salt Water System for ...
I've been reading the blogs and have ascertained that the intex filter is too small to properly circulate pool water for optimum salt chlorination. i have a Krystal Clear system model CS8110 and would like...
You have about 8588 gallons of water in your pool ... One inch of water contains about 159 gallons in your pool. You should consider a 6 hour turn over rate. I recommend a high rate sand filter with at a minimum 1.5 sq feet of filter area. You need to move about 24 gallons a minute to achieve the 6 hour turn over rate.
Continue your research with these figures at hand.
Thanks for your interest in FixYa.com. If you found this information helpful, please vote ...
Aug 02, 2010 | Intex Pool & Spa
Constant code 91! after only 1 week my first chlorinator was replaced due to this code. Have been using my replacement for approx 2.5 weeks and got my first code 91 - added 1 bag of high purity pool salt...
A few things to do or you will create your own problems.
First and for most you must filter for at least 12 hours after adding salt to distribute the salt completly
You can not just blindly ad salt like you said you added a bag.
Although the manuals have an amount of salt for different size pools it is just a starting point. It is up to you tp fine tune
you must get a salt test kit
the kind that reads #'s not color
Get your salt as close to 3000ppm as possible
any lower than 2700 and you will get a low salt alarm and you will also not be producing enough chlorine
any higher than 3500 and you can go cloudy, trigger high alarm, and the water will taste nasty
you can even trigger low salt with too much salt content
So remember 3000ppm
If you are higher than the 3500 then drain 20% water and fill with fresh
continue this until you get to close to 3000
If low follow directions for low salt either on the test directions or bag of salt
I have had my system for this being the 4th season and have never cleaned the cells
any way, when you get the pool to around 3000 filter only for about 12 hours then turn on your generator
It should work fine
Aug 01, 2010 | Intex Automatic Salt Water System for ...
Pool & Spa Logo
299 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
