Question about HP Officejet J3680 Multifunction Printer InkJet
How do I turn the ringer off for the phone? - HP Officejet J3680 Multifunction Printer InkJet
    Sergeant:
  • 191 Answers
Depending on what kind of phone you have, on the base of the phone there may be a switch to turn the phone's ringer on or off, or look on the handset if it's a cordless and on one side of the phone (left or right) you may find the switch to turn the ringer down, on, or off.
Posted on Aug 02, 2010
Phone ringer off
It a little bit older cordless phone, I CAN'T find the model number, there's a menu/elect button on the face but I can't turn the ringer off. The base has a ringer that I turned off but the phone still rings. There are no switches on the phone or base for turning it off.
Nov 14, 2013 | Northwestern Bell 36028-2 2.4 GHz Twin...
Ringer turned off. how do you turn it back on
Press either line 1 or line 2 on the face of the phone then slide the volume button up or down, for example, press line 1 and slide volume up to turn on ringer, and press line 2 and slide down to turn ringer off
Mar 06, 2012 | AT&T 972 Two-Line Memory phone
HOW DO I TURN THE RINGER ON. HAND SET READ RINGER OFF
Temporary ringer off While the handset is ringing for an outside call, you can turn the ringer off temporarily by pressing {OFF}.Adjusting the base unit ringer volume Press {^} or {V} repeatedly to select the desired volume.To turn the ringer off, press and hold {v} until the unit beeps 2 times
Sep 22, 2011 | Panasonic KX-TG5632 Phone
Can i turn down the base ringer (or turn off) on my vtech dect 6.0?
Welcome to FixYa!
The base ringer is dependent to your handset ringer. If you lower the volume or turn off the handset ringer, the base ringer will follow.
Thank you for using FixYa.
Have a great day.
Jas247
May 17, 2011 | Vtech Cordless 6041 Phone
CAN THIS PHONE RINGER BE CUT OFF
To cutoff ringer volume in Vtech cordless phones,you have to turn off the base ringer.
Handset:
program button->up/down" key to cycle until you see the Ringer selection->up/down" key(s) to cycle until the OFF selection
Base Ringer:
Menu->press menu until you hear "Base Ringer, to change base ringer press change"->PLAY/STOP button to save
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Jul 25, 2010 | Vtech IA5854 5.8 GHz Cordless Phone
Ringer off displayed on base. How do I turn it back on? Just called myself from my cell phone and phone actually did ring.
Thanks for giving me the opportunity to help with your problem.
The "ringer off' message on the base display is referring to the ringer on the "base" unit not the phone ringers. Your phone handset(s) will still ring even when the base ringer turned off.
To turn the ringer on the base back on press and hold push the ^ symbol on the base until it beeps two times, To turn the base ringer off, press and hold the v symbol until the unit beeps.
If my information has proven to be of help, please give me good rating. Thanks for using FixYa!
Jan 27, 2009 | Panasonic KX-TG5632 Phone
Panasonic cordless phone,
press menu,scroll down to ringer settings,hit select,scroll to ringer volume and hit select then press up the round button in the middle until you hear it make a "ring" sound. adjust your preferred volume and hit save.
Oct 16, 2008 | Panasonic KX-TG5632 Phone
Uniden Phone
goto the name and hit store it will restore the name and when going threw the store process it should show you old parameters
or goto phonebook find name and edit its preferences for that name phone ringers are set ringers so when you pick one for gereral use thats going to be the general use ringer but special ringers is what i descriped in first part
menu handset setup then ringers for a general ringer you can change to a more pleasing ringer but over all cant turn off
May 10, 2008 | Uniden Cordless Phone
Turn the ringer off
To turn off the ringer on my Vtech cordless phones, I have had to turn off the base ringer & all handsets.
Base Ringer:
Press Menu and listen carefully, continue to press menu until you hear "Base Ringer, to change base ringer press change", hit change and it will say "Off", then you must hit the PLAY/STOP button to save your change.
Handset:
Press the program button and use your "up/down" key to cycle until you see the Ringer selection. Press SELECT and then use your "up/down" key(s) to cycle until the OFF selection is see on the handset screen. Press select.
Jan 17, 2008 | Lands Phones
Ringer off, need to re-install ringer. volume control does not put ringer back on
To turn your ringer back on, you do the following. For your handset, you push Menu, scroll to ringer settings, then push select, Press select again for ringer volume, then scroll up to turn on and increase the ringer volume. Then press Save once its at the desired volume. To change your base ringer, while it is not in use, push the ringer up button until you hear the desired setting. That should fix your problems.
Dec 31, 2007 | Panasonic KX-TG2357 Cordless Phone
HP Officejet J3680 Multifunction Printer InkJet Logo
mukhtar21 shaikh
mukhtar21 shaikh
