Question about Yahoo Messenger
Yahoo messenger will not install, says that the application failed.
    Sergeant:
  • 191 Answers
Download another version and try installing. If it gives the same error then i suggest you get ebuddy
Posted on Aug 02, 2010
SOURCE: installation failure of yahoo messenger
my yahoo is not working good
Posted on Oct 15, 2008
SOURCE: yahoo messenger is not working
i wish i knew how to do it but my daughter does when she gets home ill have her contact you, okay.
Posted on Feb 15, 2009
SOURCE: failed application configuration for yahoo messenger
Hello, i have a fix for this issue. make sure that the default browser is installed and running correctly on your pc. if you know its installed go into internet options and select make default browser and click apply.
This is a fix only if you have installed a new web browsing application but did not select it to be your default browser.
Posted on May 05, 2009
srijag87
  • 239 Answers
SOURCE: yahoo messenger.exe. the application failed to start because the application configuration is incorect. reinstalling the application may fix the problem
first uninstall from your system and reinstall
Posted on May 07, 2009
SOURCE: On installing yahoo messenger, the
can view web cam on both hotmail and yahoo
Posted on Sep 09, 2009
C:/Program Files/Yahoo!/Messenger/Yahoo Messenger.exe This application has failed to start because the application configuration is incorrect. i want to uninstall this new application and go to my old one.
Definitely. you can uninstall this version.
To do so. go to Start>>Control Panel>> Add & Remove Programs>> Select yahoo messenger and click on remove.
after removing yahoo. restart your computer.
then install the previous version of yahoo, which you want to use.
Jul 11, 2011 | Yahoo Messenger
"C:\PROGRAM 1\Yahoo\Messenger\YahooMessenger.exe The application has failed
Hello!!!
You can reinstall it easily by following below Steps :
1. Download this installer : http://www.filehippo.com/download_yahoo_messenger/download/120679041d997dc3e015bd0898f8041d/
2. Run the Setup and Install it.
3. Start Yahoo messenger from Desktop.
4. Enjoy..!!!
Hope this Helps..!!!
Jul 08, 2011 | Yahoo Messenger
Dear Sir I installed yahoo messenger 11, but at last moment of installation i am getting the yahoomessenger.exe-application error"the application failed to initialize...
1. Reboot your computer.
2. Press Ctrl+Alt+Del on your keyboard. This will bring up the Windows Security window. Click the "Task Manager" button and then click the "Task Manager" tab.
3. You will see a list of files/applications. These are the applications running in the background on your system, whether they show on your taskbar or not. Any one of these applications could be causing a conflict with the Yahoo! Messenger installation.
4. Click the top item on the list to highlight it. Then hold the "Shift" key down and click the last item on the list. This should highlight the whole list.
5. Click the "End Task" button. This will temporarily close all background applications on your system.
6. Click the "X" in the upper right corner to close the Task Manager window.
7. Install Yahoo! Messenger. You should not experience the same issue that you had before.
8. After Yahoo! Messenger is installed,run registry cleaner reginout also reboot your system. All other background applications will return to their original configurations.
Jan 03, 2011 | Yahoo Messenger
I have been trying to install yahoo messenger 9 and 10 several times on my laptop after formating it. But before completing the installation i get a message '' application failed to start because the...
try to install a newer version Windows Installer , allow the yahoo installer on your firewall or temporarily disable your security features and try to install yahoo messenger again.
Sep 16, 2010 | Yahoo Messenger
The application failed to initialize properly (0xc0150002). click ok to terminate the application. yahoomessenger.exe - application error. the application failed to initialize properly(0xc0150002). click...
I'm having the same problem, not quite sure whether it is happending due to upgrade to IE 8 or Windows Installer 4.5 installation. Cleanup and re-install of Yahoo Messenger 10 won't help. The YahooMessenger.exe fails to initialize right during the installation process.
May 14, 2010 | Yahoo Messenger
Installation of yahoo messenger error
I think you will need to upgrade your windows installer version.....download it from Here run it and now try ...hope it will work...Good Luck
Sep 25, 2009 | Yahoo Messenger
I can't install yahoo messenger
go to google and put msn, there you can get all the messenger's you can get
Jan 24, 2009 | Yahoo Messenger
Yahoo messenger 9.0
did you uninstall the previous ym first before installing beta 9 of ym?
uninstall the old ym first then.
download a clean copy,
http://messenger.yahoo.com/win
before starting to install, try to disable momentarily your firewall.
see if there are many memory resident in your computer that's consuming the resources of your computer. tune up utilities 2007 should do the trick
http://www.download.com/3150-2094_4-0.html?tag=404
Oct 17, 2008 | Yahoo Messenger
Yahoo Messenger Logo
59 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
Sunday Ojelabi
Sunday Ojelabi
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
