Question about Baby Lock Imagine
My stitch looks great on top, but is very loose or messy on the bottom . I am trying to do a simple zigzag. The stitch on the bottom looks almost like a Y instead of a zigzag or even a straight line under the zigzag.
  • 821 Answers
Hello,please kindly follow the instructions below to make a zigzag on your sewing machine,
1.Place the appropriate presser foot on the sewing machine. The zigzag stitch requires a presser foot that has a wide slot to allow the needle to go from side to side
2.Choose the length of the zigzag stitch needed for the proper coverage. If you are using it for appliqué, you need greater coverage than if you are mending or finishing the edge of a seam. The length is the distance between each penetration of the needle into the fabric. A short length (lower number) makes a dense zigzag and longer stitch (higher number) produces a zigzag spaced further apart. Most sewing machines have a pre-programmed zigzag setting you can adjust to suit your needs
3.Determine the width of the zigzag you want to use. The zero width setting gives you an almost straight stitch, and the higher setting makes a much wider zigzag. The determining factor when deciding on the size of your zigzag stitch is how much coverage you want. An appliqué requires a wider zigzag so the edges are fully enclosed, but a seam finish may not need such a wide setting. A buttonhole requires a narrow, short stitch to make it sturdy and to prevent it from fraying.
4.Adjust your sewing machine tension if necessary for a balanced zigzag stitch. Adjust the tension the same way you would for a straight stitch. The upper thread and bobbin thread should meet so there are no loops on the top or the bottom of the seam, and there should be no puckering of the fabric. This is usually more of a problem when sewing lightweight or sheer fabrics
5.Practice adjusting your stitch width, length and tensions and sewing them on a scrap piece of fabric the same weight and thickness that your project is. This way, you can perfect your zigzag stitch before you use it on the real thing.
wish you good luck,
take care.
Posted on Aug 02, 2010
Bottom thread is still loose even if i try to balance the tension, how do i balance the thread tension?
You bobbin tension CAN be adjusted. First, thread your machine with different colors in the top and bobbin, set your top tension at its default, and run a line of straight, and then a line of zigzag stitches, and compare the results at the top and bottom. You will be adjusting your bobbin to your top tension. If the top tension looks like a straight line instead of stitching and the zigzag looks like "chicken tracks" instead of a zigzag, but the bottom looks like a zigzag, your bobbin tension is too loose.
Remove the bobbin case, and locate the straight-slot screw. There are generally two; one is a Phillips and one is straight--you want the straight one. Leave the other alone.
The rule is "lefty-loosy, righty-tighty." If your stitching displays the above symptoms, it needs to be tightened, so turn 1/4 turn to the right--no more--then test again. You will need patience, but don't turn more than that. It is easy to do, but if you don't do it systematically, you can make things worse, and very slight adjustments can alter the stitching significantly.
Apr 15, 2015 | Singer Sewing Machines
Top stich perfict but bottom stich too loose on vivo singer machine 1004
Your bobbin tension needs adjusting, and although it is not hard to do and doesn't require that you take the machine apart, you MUST do it systematically. If you don't, you'll make things worse.
First, download the user's manual from the Singer site if you don't have one. On page 20, you'll see a discussion regarding tensions, and what improper tension looks like. Tension is a balance between the top and bobbin.
Then, using scrap fabric, set your top tension on Auto and make sure your needle is all the way up in the clamp. Run a line of straight stitches, and next to it, run a line of zigzag stitches, maybe four inches, and examine it. The illustration on that page will show you what your straight stitches SHOULD look like. If your zigzag stitches show one side that looks like "chicken tracks" but the other side looks like it should, the chicken tracks side is too tight. In your case, if the bobbin is too loose, the top will look like chicken tracks. It helps a lot to use two different thread colors, as well as a third for the fabric.
To adjust the bobbin tension, you will need a tiny straight blade screwdriver. If you have an indication that the bobbin side stitches are too loose, take the bobbin case out of the machine and locate two screws on the side. One is a Phillips--don't touch it. The one on the left of the Phillips is a straight-slot screw--that's the one you want. The saying is "lefty loosey, righty tighty." If your test indicates the bobbin tension is indeed too loose (which can happen over time), you need to tighten it by turning the screw 1/4 (ONLY) turn to the right (righty-tighty). Test again. You should see at least some improvement to indicate you're on the right track, and repeat--turning ONLY 1/4 turn--until your top and bottom tension are balanced. Don't forget to also test with a zigzag; I have adjusted bobbin tensions in the past that looked OK on the straight stitch, but the zigzag indicated I wasn't quite there yet.
Jun 25, 2014 | Singer 2638 Mechanical Sewing Machine
Stitch length for zig zag satin binding 8mm equals what number?
Neat zigzag stitches are usually achieved at "2.5" or below.
Closed up zigzag stitches (close together) are referred to as a
satin stitch its likely you will want to set for 1.5 or at most 2. http://www.searspartsdirect.com/partsdirect/user-manuals/3116-singer-parts-SEWING+MACHINE-manual Look for page 40 in the owners book or scroll down and if you see numbers not on the page but on the scroll bar look for 47. It has some great pitures that can help you out.
May 13, 2014 | Singer 3116 Simple
How hat do to adjust the tension on my Singer 3201 - the under thread is real loose
If the bottom stitches are messy it usually means the top thread isn't threaded correctly.
May 10, 2014 | Singer Sewing Machines
Not stitching correctly after using pattern selectors - zigzag very messy stitch
Describe in more detail a messy stitch. It may be the cam follower that creates the patterns is not aligned and is contacting two different cams at the same time. The machine then sews both patterns at the same time. The solution may require an expert.
Apr 03, 2014 | New Home Sewing Machines
Not stitch zigzag
Have you tried a needle change? It could be blunt or the wrong size. Have you cleaned under the needle plate as the ridges get full of lint there. A toothpick will clean them out.
Nov 22, 2013 | Singer 1120 Mechanical Sewing Machine
I altered the stitch to zigzag and now it wont stitch straight or anything!
try changing the needle
rethread the machine top & bobbin
make sure the bobbin is not warped or damaged
adjust the top tension one number or letter higher till the stitch looks normal
if these suggestion don't help then the machine needs to be serviced
May 11, 2012 | Necchi Sewing Machines
Zigzag stitch pulling tight, looks wrong
Try adusting the bobbin thread instead of the top. Always make sure to insert the bobbin so the thread is pulling in a clock wise direction. Both threads top and bobbin should have about the same resitance when pulled.
May 08, 2009 | Euro-Pro Shark 60 - 384
Sewing Machines Logo
527 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Jon Piercy
Jim Goldsmith
Jim Goldsmith
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
