Question about Whirlpool AD40USL Dehumidifier
My dehumidifier makes squeaking noises when running. How do I stop this?
  • 6,993 Answers
With the unit unplugged, open the cover and check the alignment of the fan. If the fan is stuck or rubbing against the fan cowling, adjust the fan motor's mounting hardware so that the fan turns freely.
Take care.
Posted on Aug 02, 2010
GE dehumidifer fan making loud knocking noise
possibly have to take motor and fan out as a unit to get fan off .
Sep 19, 2015 | General Electric AHH40LH Dehumidifier
Dehumidifier squeaks when running
Disconnect it, (DO NOT REPAIR WHILE CONNECTED), remove outer plastic casing (screws), lubricate moving parts with a little WD40 or similar. Re-assemble.
If you can get to the part that's squeaking with a long tube you could try spraying silicone lubricant spray on it without disassembling.
Apr 03, 2014 | Dehumidifiers
The unit still makes a running noise but seems to collect no water. this unit is about 4 years old but stopped collecting water about 2 years after purchase
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 30, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
I have a Kenmore Dehumidifier the fan will run for a while and then stops. I greased the fan motor it ran for a while and then stopped. My feeling is the fan motor bearing has loosened and as the motor...
does the motor feel extremely hot? how free are the bearings? Is there any squeaking when the fan turns? any resistance at all? If you have a problem with the bearings then change them that would cause the thermal overload to trip in the motor to unsure it doesn't burn out.
Aug 14, 2011 | Kenmore 54351 Dehumidifier
The dehumidifier is making a loud noise. The noise gets louder when the fan speed is increased. What is the problem?
your fan is possibly hitting something didyou drop it or bang into it you should have some one like a tech. to checkit out and PLease stop using it till you do this you could be damaging this unit even more than it allready is
Aug 19, 2010 | Maytag M7DH65B2A Dehumidifier
When running load noise coming from black cylinder
That part you identified is the compressor of the dehumidifier. Compressor is probably bad or going bad. When compressor go bad the valves start making noise and they lose alot of there efficiency.
Dec 10, 2009 | LG LHD65EBL Dehumidifier
I HAVE 4 EA NEW LHD659EBK DEHUMIDIFIER and they make lots of noise and vibrate a bit, this is normal in these Dehumidifiers ..
These can be noisy.
Does the noise only happen when the compressor runs? These compressors float on rubber bushings to isolate the vibrations and maybe one of the three nuts on the mounting studs may be loose.
The fan bearings can also wear out.
Nov 21, 2009 | LG LHD45EL Dehumidifier
My fedder dehumidifier m7dh45b2a makes an annoying noise
This noise is the vibration from the compressor...sometimes things can come loose and magnify the noise...check for loose parts and tighten as needed...
The compressor may also be going bad...
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Oct 06, 2009 | Maytag M7DH45B2A Dehumidifier
Fan motor making squeaking noise; sounds like bushing failure.
PLEAS IF SOUND REALY FROM THE MOTOR SOME OF THE MOTORS HAVE BEARING CAN BE REPLACED BUT IF IS BUSHING BETTER TO CHANGE THE MOTOR.
Sep 17, 2009 | Maytag M7DH45B2A Dehumidifier
Whirlpool AD40USL Dehumidifier Logo
946 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike Squire
Mike
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
