My Netbook will not connect to the internet on the first try using my home wireless router, it can take several tries and 20 minutes to get a connection. The Netbook connects immediately onto other wi-fi routers (e.g. Starbucks, etc.). My desktop uses the same wi-fi router at home without any problems, it connects to the router and internet immediately. How can I fix my Netbook to connect properly to my wi-fi router and to the internet connection on the first try?
    President:
  • 2,559 Answers
Go into the internet connection settings a disable the local area connection device.(not the wireless)
Posted on Aug 02, 2010
  • 2 more comments
  • delwynng Aug 02, 2010
    Hmmm..your recommendation doesn't seem to have worked. What I did was this:
    - went to Internet Options - Connections - LAN settings
    - unchecked "Automatically detect settings". Everything else was unchecked already.
    - opened IE but failed to connect to the internet
    Was I in the wrong setting?
    What else can I try?
    Wanted to let you know that I checked in the Network Connections settings and LAN is 'disabled' and Wireless Connection is 'connected'. Not sure if that helps or not but wanted to pass it on to you.
  • Randy Hough
    Randy Hough Aug 03, 2010
    NOT internet options but network and internet connections(you will find this in the control panel) It will show a wireless and a lan connection
  • delwynng Aug 03, 2010
    The LAN setting in Network Connections was already set to 'disabled' so I'm still having the original problem of not being able to connect to the internet.
    What's next?
Slow wifi on Sony Pcg-21313l
So, If you have internet connection speed problem with your wireless try with the following steps,
1.) Reset the wireless router by using the power switch on it or by unplugging it and plugging it back in.
2.)Place the wireless router in an ideal location. The higher it is, the better, but don't put it near metal objects.
3.)Get as close as possible to the router with whatever device you're trying to connect.
4.)Keep the router and your connecting device away from other electronics. You should especially keep away from phones, fax machines and microwaves. etc.,
5.)Adjust the Wifi antenna if it has one.
6.)Change the router's channel, especially if other wireless routers are nearby.
Following these steps would give you stable internet connection and also increased speed in connection. You can check your internet speed from www.ScanMySpeed.Com before and after following these steps.
Nov 15, 2012 | Sony Vaio Netbook 1gb 60gb Windows 7 Home...
My netbook is connected through my wireless network but will not go on internet. How do i fix this problem
One of the most common things is the router needs to be reset. Before going through anything complicated, try unplugging your router. Give it 30 seconds or so, then plug it back in. Your netbook should discover your wireless signal after about 20 seconds or so, then try connecting to a webpage to see if it worked.
Mar 27, 2011 | Sylvania G-Netbook
Can not connect to internet
People often get confused about how to connect their netbooks (or laptops) to the internet. It's the same for cheap netbooks or expensive netbooks - you can connect pretty much all netbooks to the internet in four ways.... And it's really easy once you get past the jargon.
1 - Wired netbook connection using your home ISP
The first way, and one I use a lot, is just plug your netbook into your router at home, using the netbook's Ethernet port and the cable supplied with your router.
This way works every time, gives a fast and secure connection, but means that you need to use your netbook within cable distance of your router. Any internet usage will be part of your normal broadband usage with your home ISP, but isn't the point of netbooks that you can be mobile with them? Who wants to have nice new netbooks tied up by a cable?
2 - Wireless netbook connection using your home ISP
Another way to get online with netbooks if you're at home is to connect wirelessly to your home router.
It's a very easy process - just turn the netbook on and it will seek out your router. You get a fast connection, good security (if you tell your router to use WPA encryption) and it will usually work anywhere in your house or garden. Several netbooks, laptops or other computers can use your internet connection this way from the same router, so your family and friends can use their netbooks at the same time.
3 - wifi netbook connection out and about
A really cheap way to get online when you're out and about is wifi. Many busy locations - pubs, hotels, shopping malls - have "wifi hotspots" which are simply powerful wireless routers that you can use to connect your netbooks wirelessly to the net.
Some are free and can be used by any computers that are nearby. Others are owned by telecomms operators like BT Openzone or mycloud and you need to pay to use them. Monthly subscriptions or pay as you go are available. So are these free and cheap choices ideal for using with cheap netboks?
For anything other than general browsing on netbooks, beware of wifi. The free ones have no security at all, and the others have password protection, but the data you send and receive is not encrypted. This means anyone in the vicinity could snoop and listen in on what you were doing. I don't bother with wifi for this reason.
See our separate feature on wifi for more about this.
4 - Your 3G netbook connection - at home or away.
netbooks.org.uk/wp-content/uploads/g3-dongle-300x164.jpg" width=240 height=131>
netbook dongle for 3G wireless internet
The final way to connect netbooks to the net - (and yes there are only four ways - I told you it was easy) is using the latest mobile phone network - 3G short for Third Generation. Just like a mobile phone, you can pay as you go or take out a monthly subscription with one of the phone companies to suit your needs. Then, using a little device like a USB stick called a USB modem, or a "dongle" plugged into your netbook, you can connect quickly and securely to the net in most of the UK and lots of places overseas. Some netbooks even have a slot to put your SIM card straight in
If you can use a mobile phone where you are, you can probably connect to the internet using 3G. Many people use 3G to connect netbooks to the net even at home and don't bother with a normal ISP.
Your pc could have a phone line input for built in modem DO NOT use that.
Use the lan inlet connector.When you connect the lan cable it should gain access at once.
Unless your connection is protected by a code.
If you have a wire less connection its probably protected with a code when you set the router up.
You have to enter the code to gain access to your network.
Here is a link that shows you how to repair the connection:
http://www.microsoft.com/windowsxp/using/networking/maintain/repair.mspx
And if you have wire less:
http://compnetworking.about.com/od/windowsxpnetworking/a/automaticwifixp.htm
Good luck.
Mar 11, 2011 | Sylvania G-Netbook
I am trying to connect my netbook to the internet and it won't connect because it can't find an ip address i have looked and tried everything what do i need to do?
netbook router ethernet or wireless
3 - Wifi netbook connection out and about
A really cheap way to get online when you're out and about is Wifi. Many busy locations - pubs, hotels, shopping malls - have "wifi hotspots" which are simply powerful wireless routers that you can use to connect your netbooks wirelessly to the net.
If you have a wireless router you must know the password you made when you set the router up.
Try also to look in your controlpanel network and shareringcenter.
Hope this was helpfull.
Mar 10, 2011 | Computers & Internet
My acer aspire one wont connect to internet. it says it is connected to wireless, and i have wired it to modem but the problem still persists. please help.
Based on your description, the following is assumed.
1. The service to your Internet Service Provider is through a cable or DSL modem.
2. Internet service was initially set-up with your netbook directly connected to the modem.
3. A wireless router was since added and is using the direct wired connection to the modem.
4. The netbook is connected to the wireless access point being provided by the router.
5. The netbook says it is connected to the wireless access point but still no internet access.
The problem is likely due to the modem capturing the MAC address of the netbook when access to the internet servce was initially set up using the netbook directly connected to the modem and now the modem will only allow access with the netbook directly connected to it. You can check this out by reconnecting the netbook directly to the modem. It may be possible to "flush" the captured MAC by unplugging the AC power to the modem, waiting a few minutes and then powering back up with the router connected in place of the netbook. To make it easier, you may want connect your netbook directly to the router's LAN side to check if you now have internet access through the router. If you still don't have internet access, you will need to use your netbook to log onto the router to clone your netbook's MAC address for the router's WAN connection. The router's user guide/manual has directions on logging in and doing the MAC address clone. It will also have an explanation as to what is a MAC address.
Jan 30, 2011 | Acer Aspire One Netbook 8.9" Notebook
I have a Sylvania Netbook Model SYNET07526- I am able toget a wireless connection, but when I try to go to a website, it says the page is unavailable. This happens at every website I try to go to. How can...
you are only connected to the router not the internet--the router did not assign the netbook an IP Address
If your trying to get on the internet with a wireless connection and running WINDOWS, (many problems with LINUX).F
First try this - try resetting the router (unplug for a few minutes) next --be sure the wifi switch is enabled on the netbook---(TRY IT NOW) if still no luck then---go to CONTROL PANEL>NETWORK CONNECTIONS--right click on your wifi card and choose properties--highlight Internet PROTOCOL and choose properties and be sure "OPTAIN IP ADDRESS AUTOMATICALLY" is checked--Does the laptop "SEE" the router?
You will need your SSID to logon to the router
If this was helpful, please indicate so, if not -comment back so we can dig further to resolve this.
Dec 29, 2010 | Sylvania G-Netbook
Unable to connect on wf using a sylvania 7" notebook wf is shown connected.internet explorer does not connect ??? Basil
If your trying to get on the internet with a wireless connection.and running WINDOWS(many problems with LINUX), .and I am assuming you DO have a wireless router all set up and configured to broadcast the signal (not hidden) ....first we have to determine if the problem is at the router or at the laptop AND at what point its getting stuck ... so first try this
try resetting the router (unplug for a few minutes) try --be sure the wifi switch is enabled on the netbook---try---go to CONTROL PANEL>NETWORK CONNECTIONS--right click oin your wifi card and choose properties--highlight INTERNET PROTOCOL and choose properties and be sure "OPTAIN IP ADDRESS AUTOMATICALLY" is checked--Does the laptop "SEE" the router?
You will need your SSID to logon to the router(internet)
this is a link to a troubleshooting flow-chart
http://www.daileyint.com/hmdpc/laptop/wireless.gif
Dec 28, 2010 | Sylvania G-Netbook
I can not connect to the wireless internet at home
If your trying to get on the internet with a wireless connection.and running WINDOWS, .and I am assuming you DO have a wireless router all set up and configured to broadcast the signal (not hidden) ....first we have to determine if the problem is at the router or at the laptop AND at what point its getting stuck ... so first try this
Hi i have two portable computers in the house. One laptop. One Netbook. I have a belkin router for the wireless. altho my laptop connects to the router fine and the internet works perfectly. the...
You have to go in the setup ( in router ) for the wireless and see what security you are using, are you using WEP; WEP/PSK; WEP/802,1x and then you have to use the same in the computer.
Nov 14, 2010 | Computers & Internet
Acer Netbook is "Connected" but can't use internet
You first need to establish that you have internet available to your router via cable modem, dsl, etc. Unless your modem is also your wireless router. Take your ethernet connection or cable that resembles a large phone cable and plug in your Acer One directly into the router. You should then be able to get internet. If not, you may have a problem with your internet in general and need to contact your Internet Service Provider. Also if possible try another pc, see if it has internet. Lastly try reinstalling wireless diver in device manager.
Mar 10, 2009 | Acer Aspire One Netbook 8.9" Notebook
Computers & Internet Logo
118 people viewed this question
Alun Cox
David Payne
David Payne
