Question about Homelite Mighty Lite Lawn Trimmer
Trimmer starts, but stall's out, and is sluggish
Trimmer starts, but stall's out in low choke and run positions, and when depressing the throttle trigger egine is sluggish and ultimately stall's out
  • 10,865 Answers
Get a can of starter fluid and an assistant. Start it up and spray some starter fluid into the air intake to make it run long enough to clear up the sluggishness. J.
Posted on Aug 02, 2010
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Why Tiller cranks but will not run when you need it to till?
    If you don't have a manual, could can read/download it at this link.
    If the engine stalls under load, the mixture may be too lean. There should be a mixture screw on the carburetor. Note its position, and turn it counter-clockwise 1/8 of a turn to see if there is any improvement in engine performance. Repeat this but don't exceed about a half turn.
    The tank has a vent and this should be kept vertical under the cylinder cover in the small "pocket" in the cylinder cover.
    Lack of power can be caused by a dirty air filter or blocked muffler screen.
    See the article below for troubleshooting 2-cycle engines
    String Trimmer Won Work 2 Stroke Engine and Carburetor Troubleshooting
    May 30, 2014 | Mantis 2-Cycle Tiller
    Manual for a craftsman weedwacker model 31679108
    Trimmer Starts but stall out as soon as throttle is used and choke turns off. if I hold the throttle and pull the choke it runs but will stall as soon as choke is let go.
    Jan 31, 2011 | Craftsman 27cc 2 Cycle Crank Straight...
    I have trouble initially starting my MTD Yardbug mower. Once going, the engine runs great, but it seems like when the throttle lever is set to choke, it doesn't actually choke. I usually have to either...
    Sounds like your throttle cable is out of adjustment (i.e. when you put the carb in choke position is doesn't actually go into choke).
    Aug 24, 2009 | Garden
    Stalling out
    Generally with two cycle engine as soon as the engine starts the choke needs to be moved to the off or open position. Some chokes have a middle position that lets the motor run until it is warm enough to move the choke into the open position. In other words weather it is a two or four cycle engine the choke is used only to start the engine. If you unit is newer and still does not run well with the choke in the open position, you may need to adjust the hi-speed circuit to a richer one.
    Jul 13, 2009 | Troy Bilt Tb70ss Gas Trimmer
    Ryobi 720r trimmer starts ok but stalls when the
    The carburator needs to be adjusted a little, thin our your mixture screw when the trimmer is warmed up and idling. Well how do you get it to idle? I usually have to play with the choke lever with the throttle wide open going from choke to partial choke as needed to keep it running. Adjusting can be tricky, you need a small screwdriver. Screw all the way in then back out 3 to 3.5 turns. this should get you close. Adjust idle as needed.
    Jul 05, 2009 | Garden
    Ryobi SS30 trimmer starts fine and runs at when in full choke position to about half choke position. But when I put the choke lever to the full run position, it stalls out. Ryobi ss30 same problem of...
    You need to rebuild the carburetor. You will need to go to an outdoor power & equipment store of some kind to get a carburetor kit for your specific trimmer. It will come with various gaskets, (some of which you won't use), a needle valve, and a small screen that goes in the carb. Replace all old parts with new. New primer bulb is sold seperately. When you have the carb. apart, you will also need to clean the small ports with a Den Tek Brush (used for cleaning teeth). Use carb. cleaner when cleaning.
    Jim
    May 29, 2009 | Ryobi Garden
    It acts like it is flooded, starts with choke off and throttle depressed. runs until carb runs out of gas then dies
    Yes, Your carburetor sounds like it needs cleaned. Or you may possibly need to purchase a carb. kit for your trimmer if the cleaning doesn't do any good. When cleaning the carb. use a Den Tek Brush, (teeth cleaning brush), to clean the small ports. Also, check the small screen in carb. Can get clogged easily.
    Jim
    May 28, 2009 | Garden
    Stops when given full throttle
    Most likely carburetor needs adjustment.
    May 15, 2009 | Garden
    Homelite Mighty Lite Lawn Trimmer  Logo
    952 people viewed this question
    Top Homelite Garden Experts
    Jim Parker
    Jim Parker
    roeb
    Mike Squire
    Are you a Homelite Garden Expert? Answer questions, earn points and help others
