Question about Canon imageRUNNER 2200
It is net work printer work and it has stopped printing. The light on the side indicating that the intenet is connected is not on
    Problem Solver:
  • 10 Answers
Remove the driver from pc and then re-install it check the ip address
Posted on Aug 20, 2010
When press print, the status light flashing orange. It print for a while then the paper light flash yellow, then it stop. The printer print up to half a page the it stop. Check printer and turn printer...
the flashing amber status light is normal indicating data going from computer to printer.the flashing paper light indicates a paper jam or out of paper. A sensor maybe not working properly or sticking. If your model number ends in a D check
Jul 16, 2014 | Brother HL 5140 Laser Printer
Printer will not print the ink packages are new but the indicator on print que shows (?) on both black and color indicators. the que shows printer 1 to 3 % progress then stops. thank you for your help
It could be that the print spooler service on your computer has stopped. - Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
- type in "NET START SPOOLER" (this will restart the print spooler service)
Try to print again.
May 23, 2011 | Lexmark X4650 InkJet Printer
Canon Color Bubble Jet Printer i550 wiil not print - (greenlight then orange light blinks 8x - then green light) When attempting to print receive "Printer not responding" - "Paper thickness lever...
try this. It is the reset for the waste ink error (8 flashes)
1) With the printer power OFF, while pressing the Resume button, press the Power button. (Do not release the
power button.)
2) While pressing the Power button, release the Resume button, press the Resume button again twice, and then
release the Resume button and Power button.
3) The green indicator flashes during initialization.
When the indicator stops flashing and remains on, press the Resume button 4 times to clear waste ink message.
(The indicator toggles between orange and green each time the Resume button is pressed.)
4) Next, press the Power button, and the green indicator will light, and the function will be executed.
5) Turn off the printer then back on and error should clear.
Aug 04, 2010 | Office Equipment & Supplies
It doesn' t work, only I turned on and tryed to print a doc. and nothing happens what can I do?
Any error messages/ red or blinking lights? Is the printer connected? Try a new data cable and a direct connection if using a print server or USB hub. Make sure that the USB ports work for a known working device. What does the printer status indicate on the computer? Are any files stuck in the queue (spooler)? Sometimes items stuck in the spooler will be cleared if you reboot or disable and then restart the spooler. (In Windows, you can do this at the command prompt (Run as Administrator on Vista or Win7). Type "net stop spooler" without the quotes and then hit Enter. At the next prompt, type "net start spooler" again without the quotes followed by Enter. When the command completes, reboot the computer. Try printing after the restart.)
I hope this helps.
(blinking lights and error messages will depend on the actual message; one issue can be "waste ink tank full". This is noted by a usage counter not when the tank is actually full. You can actually rinse the pads and blot up the waste ink and reassemble the printer then do a counter reset. However, it isn't always worth it. The counter is based on the estimated life expectancy of the printer and additional failures may occur soon. The Epson reset utility that I'm aware of is downloaded from Epson.com after entering your printer's serial number and other information to prove it is your printer.)
Jul 23, 2010 | Epson Stylus CX5700F All-In-One InkJet...
Printer is not working. There is no error light on and the ready symbol light is on. Nothing willnot print
Have you checked if there are any Documents Stuck in Queue to print ? ( under Control panel - Printer and faxes folder )
Click on Start button
Click on Run
Type SERVICES.MSC and click ok
look for Print Spooler in the list
highlight Print Spooler,
Click on STOP button then click on START
close the window and check if the print queue is gone. ( Refresh the Printers and Faxes folder )
If this does not fix the issue :
Alternate method,
Click STart
Click RUN
Type Cmd ( or COMMAND ) and hit enter
In the black window type
NET STOP SPOOLER ( hit enter button )
Type
NET START SPOOLER ( hit enter button )
Repeat the Stop and START Command 4-5 times
End the Command with NET START SPOOLER
Open Printers and faxes folder - Refresh the Window - the printer will show Status ready with 0 document
Jul 03, 2010 | HP LaserJet P2015dn Printer
Red light on and i can't print
Open command prompt and then type command "net stop spooler" and then type "net start spooler" followed by restarting your printer.
Jul 13, 2009 | Samsung CLP 300 Laser Printer
Printer stops in process of duplex printing
Duplex solenoid not working. It's worth getting it fixed.
Jan 02, 2009 | HP LaserJet 1320 Printer
Printer does not respond, and we restarted it and it still does the same thing
Whats the brand and make of the printer and are there any error lights being displayed ?
also try this solution it may solve your problem:
Click start > click run
in the Run window type cmd
hit enter
now a black DOS window will appear
now type
net stop spooler
wait 10 seconds
now type
net start spooler
it should look like this :
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\NCR>net spool stop
The syntax of this command is:
NET [ ACCOUNTS | COMPUTER | CONFIG | CONTINUE | FILE | GROUP | HELP |
HELPMSG | LOCALGROUP | NAME | PAUSE | PRINT | SEND | SESSION |
SHARE | START | STATISTICS | STOP | TIME | USE | USER | VIEW ]
C:\Documents and Settings\NCR>print spool stop
Can't find file spool
Can't find file stop
C:\Documents and Settings\NCR>net print spool stop
NET PRINT
\\computername\sharename
[\\computername] job# [/HOLD | /RELEASE | /DELETE]
C:\Documents and Settings\NCR>net stop spooler
The Print Spooler service was stopped successfully.
C:\Documents and Settings\NCR>net start spooler
The Print Spooler service is starting.
The Print Spooler service was started successfully.
Anymore information would be great
Thanks
Aug 18, 2008 | Office Equipment & Supplies
Won't print
I've been helping someone with a similar problem on a Deskjet (but it might be a different model and connected via a print server (on his router).). Did you reboot the printer or just the computer? Also did you close all of the printer sections after searching for the paper jam? In my experience the continued flashing lights indicate the document is still in the queue. The solution I've found for other Deskjets is to unplug the USB cable from both the printer and computer (or print server) and wait five minutes. Plug in the USB cables and go back to the computer. For Microsoft Windows OS (2000 and up), in the command prompt window, type "net stop spooler" <enter> without the quotes. When the command prompt returns, type "net start spooler" <enter> (again lose the quotes). Alternately you can use the Run command and type "Net Stop Spooler" <enter> (again without the quotes), reboot the computer, then wait a while.
These directions were adapted from Tutor-tips http://www.computer-2tr.com/tips/05/20050815.html
May 31, 2008 | HP DeskJet 825c InkJet Printer
This worked perfectly for my printer:
Waste Ink Counter Reset
Power off printer and covers closed
Hold down the Resume button then press and hold POWER, the Green Indicator will light. While holding down POWER , release RESUME
Double click (2 clicks) RESUME then release BOTH POWER and RESUME and wait still the printer stops blinking.
When the indicator lights steady, press RESUME three(3) times. The indicator should be ORANGE.
Press Power to set data
I got the solution from the Internet at the following link:
http://www.fixyourownprinter.com/forums/inkjet/15620
Hope this helps.
Mar 05, 2007 | Canon BJC 3000 InkJet Printer
Canon imageRUNNER 2200 Logo
old marine
old marine
