Question about Proform Crosswalk 500 Treadmill
THE BELT MOVES FINE BUT WHEN I STEP ON THE MACHINE THE BELT STOPS
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 218 Answers
The drive belt is slipping under the motor hood and most likely needs replaced
Posted on Aug 11, 2010
My treadmill belt moves smoothly but when i steps on it it stops why
Probably the belt is not tight enough. there are adjustments to set it up. ours is on the open end of machine where you step on. and takes an Allen wrench to adjust it.
Jan 23, 2017 | Exercise & Fitness
Every time i step on the foot control the needle goes down to sew amd stays stuck and all the lights are bleenking it wonr sew!! Some one Please Help Me
1. If the machine will move smoothly by turning the hand wheel this means your machine is free.
2. When the machine is on it's way down does the needle hit the side of the hole in the throat plate? If yes you will need to adjust it so it doesn't do this. There are a lot of "how to's" over the internet.
3. Take the bobbin assembly out and try the machine without it. If it moves freely then the assembly needs to be adjusted or the machine needs to be timed. The assembly on most top bobbin load machines must be set so it doesn't move around. There are screws there (two). If it is set so tight to not move this is a problem also. So give it a little slack that a thread can go through with ease.
4. If your belt is out of alignment this could be a real problem with power of the motor being used. Uncover the belt that goes to the motor. Once you have done this so you see the belt try the foot pedal so the motor moves slowly. Loosen the bolts on the motor. Step on the foot control slowly and move the motor around until it moves with the most speed easily. This will adjust the belt in just the right point. Be careful though!
Jun 26, 2015 | Sewing Machines
I get an error message E1 on my Athlon model Simplicity treadmill. Belt stops. Any ideas on what this means?
Step 1:
ERR 1 - Motor Movement
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.
Clean the s.speed , test for open or faulty-see the diagram for adjust. tight the connector very well.
God bless you
Step 2:
Feb 08, 2013 | Exercise & Fitness
Washer won't spin, what do I do
Check the lid or door switch this is the usuall issue with a washer that won't spin. The other is a blocked pump or clogged pump filter.
Apr 30, 2011 | Maytag Washing Machines
Walking surface will only move very slowly. The belt seems tight enough, tried to tighten 1/4 turn, still not moving properly. Treadmill is a Weslo Cadence 450, bought a few years ago. Thanks
lift the sides of the w/belt the hieght should be 2-3 inches. if more to loose,tighten it up. still have a issue take hood off and check the motor belt. if you find a bunch of black dust. your belt is worn or on its way out.PS you can find the belt on the web.
Mar 09, 2011 | Cadence Exercise & Fitness
I have a NordicTrack c2200. I find that the tread belt is not running smoothly while running on it. As I run, the belt temporarily stops during each running step, causing me to trip up. I tried to lube,...
There are a couple possibilities.
Remove the motor cover and run the machine.
Check the tension of the motor belt. It may need to be tightened. 2manyhobbies.jpg
Check that the pulley has not broken free from the front roller by stopping the walking belt when the machine is running. If the belt stops, but the motor and pulley keep turning, the pulley has broken free from the front roller.
If this is the case, with a drill and small drill bit, drill a hole through the pulley and roller on the inside edge of the pulley, between the ribs (not where the motor belt travels) and put a screw through the plastic into the metal roller.
Otherwise, change the roller.
Good Luck.
Dec 30, 2010 | Nordic Track Exercise & Fitness
Control dial moves along fine but drain,spin, rinse never happen
replace the water pump. about 46 dollars and a 20 minute job.
Jun 24, 2009 | Maytag Washing Machines
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine won't spin or agitate
Hi.
Sounds to me that you have a faulty motor from the symptons.
Does it work without the belt on?
Nov 23, 2008 | Washing Machines
Indesit w11
does it have a manual programme knob?if it does ,probably the internal contacts do not mesh so it stops at next step (programme)but the water pump keeps on making the noise.
try turning the knob by hand when machine stops before entering next programme cycle.if machine starts ,programme knob is the problem.
Mar 21, 2008 | Washing Machines
Proform Crosswalk 500 Treadmill Logo
150 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
