Question about JVC HD-52G786 52" Rear Projection HDTV
The red and blue light on the front keep flashing when we try and turn the TV on...it was working earlier today.
  • 10,594 Answers
If Power and Lamp lights blinking 'alternately' it shows problem of temperature arise abnormal and reason could be blocked fan or air flow in tv is insufficient to keep it cool.
If Power and Lamp lights blinking simultaneously then it shows problem with lamp installation, need to inspect lamp cover is fixed in its position securely.
Let me know both lights are blinking at same time on your tv?
Thanks.
Posted on Aug 03, 2010
  • 2,272 Answers
The internal lamp for the tv needs replacement.It has to be replaced. to get this lamp click on this link directly http://www.amazon.com/HD-52G786-HD52G786-Bare-Lamp-TS-CL110UAA/dp/B002Y0MTD0 ------- If you have any other source to get the lamp then you can try that also.This lamp is easily available. Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Aug 02, 2010
Hitachi p50h401 the power light keeps flashing
If you have a flashing red light, try this first: The flashing red light is, according to the Hitachi service manual, an indication of exactly one problem. It is that the fan (internal, blows air over the power supply heat sinks) has failed. In my case, it failed by continuing to spin (very confusing), but put out a signal (3V on the white wire of the fan harness) that it has failed (I had to look up the data sheet on the fan to figure this out). A new fan from Arrow $10 fixed the problem. If you suspect your fan, spinning or not, you can safely short the white to the black wire to see if your TV remains on after being turned on (solid red light), and then try turning your TV on (blue light) to see if it works.
Oct 17, 2011 | Hitachi P50H401 50 in. Plasma HDTV
I was playing my PS3 and moved it from my tv upstairs to my tv downstairs. After plugging my PS3 in my tv downstairs, on which it had worked just 1 week previously, my tv picked up no signal from my PS3....
Try this.
Plug your PS3 on either TV. Turn on the backswitch. When the red light in front is on, put your finger on the on/off button in front AND KEEP IT THERE. You will hear some beeps; don't worry about that. Keep your finger on the button until the front power light goes red again. This resets the PS3 video settings. Turn the PS3 on and the TV should pick up the signal.
Hope this helps. Keep us posted.
Jul 04, 2011 | Sony Playstation 3 (PS3) Console
I have a 2001 sony kp61hs30 that has always worked great. turned it on today, the blue and red do not match up. the flash focus button on the TV will not align the blue and red plus signs. Got any...
I have a 2002 sony KP61HS30 and the blue and red do not match up. I use the flash focus button and it does not align the red and blue plus sign. Have any suggestions?
Dec 11, 2010 | Sony KP-61HS30 TV
Screen went dark
Ur video ic inverter board is dead.
U need a new one.
Aug 25, 2009 | Televison & Video
I have a PT50LC13 HDTV and it quit working today. The little red light on the front where it says lamp started flashing red and every time I tried to turn on my TV it made a noise. I just wanted to ma
From the info you gave, it does sound like the lamp is bad. The sound you hear is the ballast trying to ignite what used to be a lamp. The lamp is assessable throught a 6x6 cover usually in the rear of the set held on by usually two screws. After the cover is off ( with a flashlight ) locate the screws(2) that hold the lamp housing in, remove those and it should slide out. Make sure you unplug the set first and remember to reset the lamp timer witch is located in your owners booklet after your done with the set on.
Apr 15, 2009 | Panasonic PT-50LC13 50" Rear Projection...
JVC HD-52G786 52" Rear Projection HDTV Logo
701 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
