Question about Nokia Unlock N70 N71 N72 N90 6630 6680 6681 6682 Unlock Smartphone
When opening the code wants kikit - Nokia Unlock N70 N71 N72 N90 6630 6680 6681 6682 Unlock Smartphone
How to 6630 unlock security code ?
Posted on Aug 13, 2010
Zynga poker.CODE CA3 please open my poker i have message resent code CA3 CA3 pls...open my zygna...
CODE CA3 please open my poker i have message resent code CA3 pls...open my zygna poker CA3 from.
Jan 12, 2013 | Zynga Texas HoldEm Poker
I have a nokia 1200 cellphone and i want keyguard lock by my personal password so how can i do?
Hello Ashish..!! its very easy to set the keyguard code. all u have to do is follow the following steps
  • go to menu
  • select "settings"
  • now select "Security settings"
  • open "change access codes"
  • now open "keyguard code"
  • open "change security code"
  • enter the default security code for Nokia i.e., 12345
  • now enter your desired 5 digit code n confirm it again. your code will be changed
to activate the keyguard code, open phone settings n then select keyguard settings. open "keyguard code". enter the code and select "on" Hope this info was useful to you.
Jun 24, 2011 | Computers & Internet
The gauge in my yamaha fz6 2006 is blinking, the manual says there is a electrical circuit problem. I check all the ligths nad fuses and they seem in order, what else could it be?
I believe you count the amount of blinks to read the codes. First blinks are first number, and second set of blinks are second number. Chaz Moto DC
Fault Code: 12
Symptom: No normal signals are received from the crankshaft position sensor.
Fault Code: 13
Symptom: Intake air pressure sensor-open or short circuit detected.
Fault Code: 14
Diagnostic Code: 03
Symptom: Faulty intake air pressure sensor pipe system
Fault Code: 15
Diagnostic Code: 01
Symptom: Throttle position sensor-open or short circuit detected.
Fault Code: 16
Diagnostic Code: 01
Symptom: A stuck throttle position sensor is detected.
Fault Code: 19
Diagnostic Code: 20
Symptom: Open circuit in the input line of ECU No4 terminal is detected when the start switch is pressed.
Fault Code: 21
Diagnostic Code: 06
Symptom: Coolant temperature sensor-open or short circuit detected.
Probable cause of malfunction: Open or short circuit in wiring harness.
Defective coolant temperature sensor.
Malfunction in ECU.
Improperly installed sensor.
Fault Code: 22
Diagnostic Code: 05
Symptom: Intake air temperature sensor-open or short circuit detected.
Defective intake temperature sensor.
Malfunction in ECU.
Fault Code: 30
Diagnostic Code: 08
Symptom: The motorcycle has overturned. Probable cause of malfunction:
Overturned.
Malfunction in ECU.
Fault Code: 33
Diagnostic Code: 30
Symptom: Open circuit is detected in the primary lead of the ignition coil (# 1, #4).
Probable cause of malfunction: Open circuit in wiring harness.
Malfunction in ignition coil.
Malfunction in ECU.
Malfunction in a component of ignition cut-off circuit system.
Fault Code: 34
Diagnostic Code: 31
Symptom: Open circuit is detected in the primary lead of the ignition coil (# 2, #3).
Malfunction in ECU.
Fault Code: 41
Diagnostic Code: 08
Symptom: Lean angle cut-off switch-open or short circuit detected.
Defective lean angle cut-off switch.
Malfunction in ECU.
Fault Code: 42
Diagnostic Code: 07, 21
Symptom: No normal signals are received from the speed sensor; or, an open or
short circuit is detected in the neutral switch.
Defective speed sensor.
Malfunction in vehicle speed sensor detected unit.
Defective neutral switch.
Malfunction in the engine side of the neutral switch.
Malfunction in ECU.
Fault Code: 43
Diagnostic Code: 09
Symptom: Supply power to the injector and fuel pump is not normal
Probable cause of malfunction: Open circuit in wiring harness. (red/blue line or blue/yellow line)
Malfunction in ECU.
Fault Code: 44
Diagnostic Code: 60
Symptom: An error is detected while reading or writing on EEPROM.
Probable cause of malfunction: Malfunction in ECU. (The CO adjustment value is not properly written on or read from the internal memory).
Fault Code: 46
Diagnostic Code: --
Symptom: Power supply to the FI system is not normal. Probable cause of malfunction:
Malfunction in "CHARGING SYSTEM".
Fault code: 50
Diagnostic Code: --
Symptom: Faulty ECU memory. When this malfunction is detected, the code
number might not appear on the meter.
Probable cause of malfunction: Malfunction in ECU. (The program and data are not
properly written on or read from the internal memory.)
Fault code: Er-1
Diagnostic Code: --
Symptom: No signals are received from the ECU.
Probable cause of malfunction: Open or short circuit in wiring sub lead.
Malfunction in meter.
Malfunction in ECU.
Fault code: Er-2
Diagnostic Code: --
Symptom: No signals are received from the ECU within the specified duration.
Probable cause of malfunction: Improper connection in wiring sub lead.
Malfunction in ECU.
Fault code: Er-3
Diagnostic Code: --
Symptom: Data from the ECU cannot be received correctly.
Malfunction in ECU.
Fault code: Er-4
Diagnostic Code: --
Symptom: Non-registered data has been received from the meter.
Malfunction in ECU.
Feb 23, 2010 | 2005 Yamaha FZ6
Our craftsman garage door opener's wireless keypad is broken
It sounds like the default no code is still there.
Reset the unitat the opener itself and reload your code from the remote.
Sep 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
My DKE is acting up and now opens 2 of my doors with one code
If you press and hold the smart/learn button for 6 seconds on opener number 1 it will erase the memory and neither code will open it. Now just program it for button number one and you should be set. If you have remotes for door number 1 you will have to reprogram them also.
Jun 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
Mar 22, 2009 | Sentry Fireproof Safe
Can u help us m8
contact the dealer of where you bought your stereo...or maybe the sony company...:)
Dec 13, 2007 | Sony CDX-M610 CD Player
I pluged the radio in me car an it says code in before itl work i got it off a friend an he had it workin in his car before i tuck it ou an he said e lost the code he only used the code once an didn n
You need to enter the code using the remote. Try these codes.
You need to press reset after each attempt.
CODE 1: MODE SOUND OPEN ATT
CODE 2: ENTER OPEN meNU 6
CODE 3: OPEN DISC+ 1 LIST
CODE 4: SEEK- SEEK+ 3 OPEN
CODE 5: OFF 4 OPEN SOURCE
CODE 6: 2 OPEN DSPL SOUND
CODE 7: OPEN 5 ATT SEEK+
CODE 8: DISC- DSPL OFF OPEN
CODE 9: SEEK+ SOUND OPEN ENTER
CODE 10: DISC- LIST SEEK- OPEN
CODE 11: OPEN 4 LIST OFF
CODE 12: DSPL SOURCE OPEN 1
CODE 13: MENU 2 MODE OPEN
CODE 14: 5 DISC+ OPEN ATT
CODE 15: 3 MENU SEEK- OPEN
Oct 18, 2007 | Sony CDX-M630 CD Player
Sony model #CDX-M630 car stereo reciever
you need to use the original remote to enter the code. Try these codes one of them should work...
CODE 2: ENTER OPEN MENU 6
Sep 13, 2007 | Sony CDX-M630 CD Player
Nokia Unlock N70 N71 N72 N90 6630 6680 6681 6682 Unlock Smartphone Logo
26 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
