Question about Kenmore 64683 Microwave Oven
My Kenmore UltraWave 721.64683 stopped heating last night. Everything else seems to be operating fine. This morning I thought I would try again and got the same result but an F-9 showed up in the window. Flipped the breaker for a couple of minutes, which corrected the F-9 but still no heating. Any thoughts? Microwave is 7 years old and I just replaced the inverter board 6 months ago! Toss or repair?
SOURCE: F-9 Error on Kenmore Ultrawave Microwave Model 721.64682300
From everything I have read it is a 1100w inverter, I am having the same problem.
Posted on Jun 09, 2009
SOURCE: I have an error code
I would like to repair the kenmore mocrowave myself, it has the error code f-9. Do I need to let the micrwave sit for a wile so the hi voltage can disipate from the inverter or magetron
Posted on Aug 07, 2009
fathitkf
  • 1871 Answers
SOURCE: My Kenmore Elite will not heat has F-9 on display
Hello :
F-9 error code indicates a defective control board, inverter module or line voltage too high You can try unplugging or disconnecting the electrical power to the unit for at least 50 seconds to see if this solves the problem, if not then I recommend to replace the inverter module, if this does not solve the problem then the control board will have to be replaced. If that didn't solve the problem , then call for repair .
I hope this will help .
Please rate !
Posted on Mar 28, 2010
fathitkf
  • 1871 Answers
SOURCE: F-9 pops up - microwave stops after 5 seconds.
Hello :
The F-9 error code indicates a defective control board, inverter or line voltage too high .
WARNING : A microwave is capable to give you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
good luck .
please don't forget to rate !
Posted on Apr 04, 2010
blueextc3221
  • 15935 Answers
SOURCE: What does an error code of F-9 mean on a Kenmore
The F9 error code indicates a failed inverter. If resetting the unit does not help you will need to have the inverter & harness checked.
http://media.fotki.com/1_p,wbgdfgsrsttwqwbxgtqsskgwtqkq,vi/kgdfkfrkkxkfdtftrfb/1/1303472/5961857/image45625img-or.jpg
This can sometimes by caused by a power surge or glitch through the electrical lines.
You can sometimes clear this fault by completely unplugging the microwave for 1 minute.
Plug it back in and see if the fault code returns.
If it does, then you have an internal component failure that will need to be serviced by a technician.
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances.
Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged.
A microwave radiation leakage test must be performed on the unit following any internal component repair.
It does not ALWAYS indicate a inverter control board problem however in other brands/models.
LG's service manual (for an example) suggests the f-9 code could be due to line voltage, magnetron, inverter module, "Relay2", or a loose connection between door/magnetron/control pcb.
Other indications might help narrow down these choices before having to pull out your multimeter and crack open the microwave case.
For example, if the microwave works, but heats slowly, then the troubleshooting manual narrows your choices down to magnetron or line voltage problems, and pretty much rules out the other possibilities.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
Microwive not heatin
Ufortunately the magnetron is the most likely problem, "heats food" and is the heart of the microwave oven. If the device is five years old or more cheaper to replace the item.
Mar 04, 2012 | Sharp Microwave Ovens
Our Kenmore microwave oven recently stopped heating. The lights, turning plate and controls all work but with no cooking is occurring. The last time I attempted to heat something up I heard a cracking...
The most likely cause is a bad magnetron, "heats food" the other two possibilities are the high voltage capacitor and diode. The cost to repair will a approach a new microwave oven.
Apr 08, 2011 | Kenmore 80412 Microwave Oven
Our kenmore microwave stop heating.. Everything works well but it just stop heating last night after l cleaned it.. did I do anything to it??
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
78g
May 15, 2010 | Kenmore 63792 Microwave Oven
Kenmore built in microwave displaying "D" and wont heat.
"d" may mean demo mode. The first thing to try is a "hard reset". Unplug it from the power outlet for 10 minutes, plug it back in, set the clock, then try again.
Jun 06, 2009 | Kenmore 62622 Microwave Oven
Mar 12, 2009 | Kenmore Microwave Ovens
Kenmore elite ultrawave microhood combination error code F9
F9 is normally a bad door switch or door switch mount.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Aug 22, 2008 | Kenmore Microwave Ovens
Kenmore microwave
Since it's under warranty, they will replace or repair it at their choice, and if they replace it, it will be the same model or a "like model".
I'd ask them about it.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 04, 2008 | Kenmore 63663 Microwave Oven
Kenmore ultra elite microwave hood combination
F9 code can mean something different depending upon the particular model.....
1.) IF your Microwave uses "UltraWave technology"/"SmartWave technology"...Then either the Magnetron has failed or the Inverter board has failed OR maybe the control board has failed (HUH?).
2.) IF your Microwave does NOT use "UltraWave technology"/"SmartWave technology" then one or more of the door switches has failed.
** "UltraWave technology"/"SmartWave technology" **
I'll explain a few things about this wonderful technology...
The control board (accepts the pushbutton commands) has to talk to the inverter board to tell it how much power should be applied to the magnetron. The inverter board will then power the magnetron and inform the control board if the magnetron is working OK.
If there is something wrong with the magnetron or inverter board or a there is a communication breakdown between the control board and the inverter board...WA-LA-----F9----
A pretty reliable test for the Magnetron is to operate the oven and listen for a ticking sound 5-6 times about a second apart. If you can hear the ticking....The magnetron has failed..if no ticking, the control or inverter board failed.
Note: This 'technology' may come in other flavors as well
Jan 19, 2008 | Kenmore 62622 Microwave Oven
Danby micro: turns, lights, doesn't heat
Heating for that long may have damaged the magnetron.
I would suggest you contact Danb for assistance:
http://www.danby.com/page.asp?code=2
Dec 05, 2007 | Kenmore 80412 Microwave Oven
Kenmore Microwave Hood Combination: over the stove Model #721.80602500
Disclaimer: I'm a DIYer, not a technician.
Our GE over-the-range microwave stopped producing heat yesterday while warming part of the T-giving feast. Everything else (fan, control panel, light) works fine.
After disassembly and testing last night, I discovered a defective "secondary door switch." Your Kenmore uses a similar switch (~$19 on-line), and that might be the problem. But it also could be other things, such as a bad thermal cut-out.
If you know anyone who's handy with a multimeter, most of the basic diagnostics seem to be pretty straightforward.
Nov 23, 2007 | Kenmore 62622 Microwave Oven
Kenmore 64683 Microwave Oven Logo
78 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
