Question about Midland Radio Communications
How do you get the back off to change the batteries?
  • 3 Answers
To change the battery, you must first remove the belt clip. Depress (by pushing up) the small tab in the middle of the three slots at the top of the belt clip, then slide the belt clip down. Once you've removed the belt clip, press down on the top center of the battery pack cover and slide it down. If this fails, insert a thin blade between the top of the cover and the body of the radio. Twist the blade until you can pry the cover down, then remove it.
Posted on Jan 29, 2012
    President:
  • 2,761 Answers
You didn't specify a model, byt nearly all of the current/recent Midland models are the same.
On the back of the radio, near the bottom, you should see a small tab with an indent above it. Place your finger tip or a coin in the indent and push the tab downward. Once that's done, just lift the battery cover from the bottom and remove it.
I hope this helps.
Bill B.
Posted on Aug 03, 2010
How to change battery shark 88 freestyle
  • Remove back
  • Locate battery and identify type. Note battery mounting arrangement for later reference
  • Obtain replacement battery
  • Remove old battery and install new
  • Check operation
  • Install back
  • Set time, etc.
Sep 05, 2016 | Freestyle Shark 88 Watches
Changing battery in Michael Kors watch
back off, remove old battery, install new battery, back on
Sep 21, 2012 | Michael Kors Chronograph MK5198 Watch for...
Walkman NWZ-S615F How do you change the battery on this walkman? We've had it 3 years, but hardly used. Will work when plugged in to pc, but will not charge battery. I see on ebay I can purchase new...
Yes.
You can change the batteries easily.
First, remove the screws at the backside, near the bottom.
Then flap open the front, starting from the top.
battery is glued to the back cover.
Remove the connector, remove the battery.
Stick new battery to the back cover, connect the connector.
Fit both the covers together. Power on the player.
If there is no problem, put back the screws.
thats it.
Jan 22, 2011 | Sony Walkman Video NWZS615F MP3 Player
I need to change the battery on the tI30-xa calculator. I need to know the size and how to change it.
Remove slide cover. Place calculator face down. Using a small Phillips screwdriver, remove screws from back case. Remove back case. Remove discharged batteries. Caution: Avoid contact with other calculator
components while changing batteries. Install new batteries positive side up, as shown on diagram inside case. Replace back case, and then replace screws.
May 19, 2010 | Texas Instruments TI-30XA Calculator
How do I change the battery in my 2000 Buick Lesabre
The battery for the 2000 Buick Lesabre is under the back seat. I stand inside the car at about the middle of the back seat. Using both hands I pull up sharply on the back seat until it comes up. Remove the seat and you'll see the battery. Changing the battery is the same procedure as any battery. Remove the negative battery clamp first, then the positive, unbolt the battery, and lift it out.
Nov 19, 2009 | 2000 Buick LeSabre
Battery back up problem in lg ku990 viewty
don't use a case that has a magnet..... it will drain the battery ...the back is made of metal
from theone33
Dec 02, 2008 | LG KU990 Viewty
I have a fossil blue watch. How do i change the battery? thanks
to change the battery of fossil blue watch,just open the case back and remove the old battery,look the number size on the battery and put a new battery that same number size ,after replacing battery press the case back tight to avoid water damage !good luck
Aug 23, 2008 | Fossil Watches
APC back UPS 400 fails to give back up
I have the same problem with an apc smart-ups VS 650.
New batteries - charge in batteries is good (also tested under load).
When AC power fails, no power is supplied to PC connectors by the UPS.
UPS self test works fine. UPS does not report any problems via software - Power Management under Windows XP.
Oct 12, 2007 | APC Back-UPS 400VA (BK400) UPS System
Radio Communications Logo
311 people viewed this question
Top Midland Radio Communications Experts
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
