Question about Dewalt DW744S 10" Portable Table Saw with Stand
I have a Dewalt model 7730 radial arm saw. When the on button is pushed the motor starts off real slow as if it is under a bind or load but after a few seconds it picks up speed and seems to turn at full speed. What is the most likly cause and best course of action. THANKS Jim Adams
  • 700 Answers
Most probably it is bit of timber on the bottom of the saw assembly...
1. switch off the saw
2. remove power plug
3. remove screw and clear protector assembly
4. remove centre panel (as to changing the blade)
5. remove blade and clean dust furrow below it from all debris
6. re-assemble in reverse order
7. mount safety protector assembly
7, connect power cord
8. start in shor burst and switch immediatelly off, after blade stop spinning, check blade assembly if not wobbly.
this should solve your problem.
if you find this advice useful, please do not hesitate to leave comment and give me your vote4 fo rme, thanx!
Posted on Aug 03, 2010
Need a manual for old DeWalt radial arm saw. Serial:60022464. NO model # on the plate.
check this out
http://www.fixya.com/support/t26033757-dewalt_radial_arm_saw_gw1_single_phase
20 Most Recent Dewalt 10" Radial Arm Saw 2 Hp Questions ...
www.fixya.com/support/p3534275-dewalt_10_radial_arm_saw_2_hp_403044_ma
Recent Dewalt 10" Radial Arm Saw 2 Hp 403044-made In Usa - Miter Capacity: 45° R 9.25" questions, problems & answers. Free expert DIY ... Serial:60022464.
Dec 11, 2016 | Dewalt Saws
While ripping 1x4's my 10 inch craftmens saw stopped running. Pushing in on the reset button doesn't help. After 2-3 minites saw will start up again. I'm not forcing the boards and overwor
the thermal motor relay is shutting it down,,motor to hot,
insure that all the air vents or saw housing are not full of saw dust. blow it out with air from a reversed hose on a shop vac if you don't have a compressor.
hope this helps.
Jan 03, 2018 | Craftsman 10" Table Saw
Hi my name is Pat I need the rewiring diagram. So I can rewire my dewalt radial arm saw motor, it is a single phase capicitor motor with built in brake.It`s 120/208-240 volts, 11/5.5 amp, 3450 rpm, 236...
Here's a Google search on the subject:
https://www.google.com/search?q=dewalt+radial+arm+saw+wiring&ie=utf-8&oe=utf-8&client=firefox-b-1
Feb 04, 2018 | Saws
Dewalt Radial arm saw switch
try to find someone on craigs list or ebay selling one for spare parts.
Mar 23, 2010 | Saws
Need replacement parts - accessories
If the kickback arm you seek is the type that is a round bar with pointed fingers on the bottom, I had the same problem. (different model DeWalt) I gave up trying to find one, and finally just made one. It was pretty easy, and works very weill I bought a piece of steel rod (1/2 inch I think) a steel repair plate (from which I cut a pair of tear-drop shapes with a hacksaw and file) a 1/4 inch hex-head bolt (which had about 1 inch not threaded) and a 1/8 inch roll pin. I looked at various pictures on the web to determine the shape of the teardrops. I drilled a 1/4 hole in the 1/2 rod. I cut the threads off of the 1/4 bolt so it was still long enough to accept the 1/2 rod, the two teardrops, 2 washers and the 1/8 roll pin. Then I put an 1/8 hole in the bolt allowing enough clearance so that the teardrops would swing freely. It works like a champ. One minor flaw is that with only two of the teardrops (instead of several) and being separated by 1/2 inch, it would be possible to make a skinny enough rip that only one teardrop would contact the board being ripped, leaving the other peice unguarded.
Jan 23, 2010 | Delta Machinery 10" Professional Radial...
Trying to get the manual for the DeWalt 7730 radial arm saw.
go to Dewaltservicenet.com and in the middle of the page type in your model number and you can download a manual for this tool. It is 27 pages long, If I have answered your request would you please rate this response accordingly and thank you..
Jan 22, 2010 | Saws
I have a dewalt 740 radial arm saw and i was cutting wood (logs, small ones) with my radial arm saw and it jammed a few times, you could hear the motorand the the blade would start. the last time it...
Look for a reset switch/button on the motor. It may be popped out or it may just need pushing. If no reset, I would suspect the start capacitor has been damaged.
The start capacitor is usually under a tube-like cover on the outside of the motor. Disconnect the leads to this and test for its rated capacitance with a multimeter. If it fails the test with the meter, replace it.
Charlie
Aug 29, 2009 | Saws
Cannot find specs for my DeWalt Radial Arm saw
Here you go.hope this is what you wanted and Please rate this a fixya
Feb 09, 2009 | Dewalt DW746X 10" woodworker's table saw...
Dewalt 7749 radial arm saw
According to the service manual this saw has a 120VAC single phase 2.5 Hp motor with a 5/8" x 1.5"long arbor. It has a maximum vertical cutting depth of 2 and 15/16". It has a maximum cutting depth at 45 degrees of 2.125" (2 and 1/8") without the lower guards. The maximum cutting depth at 45 degrees with the lower guards in place is 1.625" (1 and 5/8"
The service manuals (approximately 24 megabytes each) are available on line at Dewalt.com After creating an account. Then you should go here:
http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=18624&typeId=1495&documentId=574
for the manuals.
Jun 25, 2008 | Dewalt DW746X 10" woodworker's table saw...
Dewalt DW744S 10" Portable Table Saw with Stand Logo
594 people viewed this question
Top Dewalt Saws Experts
Craig Butler
Craig Butler
JOHN LAPIER
Tim Venetis
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
