Question about HP Creative Sound Blaster Audigy 5.1
Sound Card Seems to be AWOL
Greetings:
I had to do a " system recover " and after all was completed, I now find that my speakers don't work, I have no sound in my headphones and the mic I use is not responding at all. Can anyone lend a hand ?
Joe
  • mr radio Apr 26, 2008
    HP PAVILION a818n....I have a Behringer 4 channel sound board and the entire set up is plugged in to the tower using a USB codex....times like these that I wonder why I didn't take those tech courses....
    thankshttp://www.fixya.com/users/hellanice for you continued support. once we get this resolved, I 'll have you on the air with me here ( www.tgamm.com )
    All the best
    joe
    Champion:
  • 230 Answers
Please provide make and model of computer. Also look in your device manager to see if the driver is installed for the "Audio" section.
Posted on Apr 25, 2008
The display is showing "PROTECT" and nothing (no sound) seems to work. What might be the problem?
It's possible that some of your speaker wring has either become loose, damaged, or is shorting. Perhaps even a faulty speaker. Check everything before you turn it on again.
May 29, 2016 | Onkyo TX-SV414Pro Receiver
Cant get sound
This can often be as simple as the speakers being unplugged, plugged into the wrong jacks, or powered off, so don't overlook the obvious and check to be sure. Also check the volume controls in Windows or your application to see that they are turned up and not muted. When you are sure the volume is turned up, the speakers have power and are plugged in, and the speaker configuration is correctly identified in Windows (some audio hardware uses a proprietary mixer control for this job), you need to verify whether the problem is with the speakers or the sound card. Connect different known-good speakers and see whether they work. If they don't, the issue is in the sound card-possibly the configuration of the card is incorrect or the card itself is defective. The first thing to try is clearing the ESCD in the BIOS Setup. This essentially forces the plug-and-play routines to reconfigure the system, which can resolve any conflicts. If this doesn't help, try removing and reinstalling the sound card drivers. Finally, if that doesn't help, physically remove and replace the card from the system. You might try replacing it first in the same slot and then in a different slot because timing issues can sometimes exist from one slot to the next. If that doesn't work, you must try replacing the card. If the sound "card" really isn't a card but is integrated into the motherboard, first try the ESCD reset and driver re installation. Then, if that doesn't work, you have to try disabling the integrated sound and perhaps installing a replacement card.
I hope one of these solutions help.
Sep 05, 2011 | Systemax AOL Optimized PC (100607) PC...
I just reistalled Windows XP and my speakers do not work. They were working fine b4 I reinstalled
you will need to set up your sound card and drivers again if your computer came with a motherboard disk the sound drivers could be on it
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or
click start control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
if you dont have a motherboard disk you will need to download the sound drivers
hope this helps
Jul 26, 2011 | Altec Lansing Multimedia Computer Speakers
No sound
no sound mean:
1- speaker is bad
2- entrance sound is bad
3- driver is bad ( re-nstall)
4-windows had a damged files (re- install)
5- sound ic control is damaged ( need out pci/ usb sound card )
6- tow jumper in mother board are take off
if you see these answer helpful please don't forget to vote me
best regards
Apr 25, 2011 | Computers & Internet
I have a acer aspire 4520 and the speaker drivers doesnt show up on device manager and the sound doesnt work at all do i have to replace my speakers completely?
Well, I would try to 'restore' to an earlier time when the speakers did work, or 'recover' to factory settings so the computer can install the appropriate driver for your built in sound card on the laptop.
Aug 09, 2010 | Acer Aspire 4520 Notebook PC
I had a system crash and have just recovered xp
CHECK YOUR SOUND CARD DRIVER FROM THE DEVICE MANAGER
IN THE COMPUTER PROPERTIES, IF DRIVER IS INSTALLED
CORRECTLY.
if the driver is not installed buy a universal xp driver cd and install your drivers.
IF THE SOUND DEVICE IS NOT AVAILABLE THEN UNPLUG YOUR SOUND CARD AND REPLUG IT
WELL.
Dec 28, 2009 | Altec Lansing AVS 500 Computer Speakers
Need cable to connect computer to BA7800 speaker system
YES, WHERE CAN I GET THE 3 PRONGED CABLE TO CONNECT MY SOUND CARD TO THE INPUTSON THE BACK OF MY BA7800 SPEAKER SYSTEM, OR JUST MAKE MY OWN WITH 3 GOLD TIPPED 1/8" CONNECTOR WIRES?
Jun 14, 2009 | Boston Acoustics (BA7800) Computer...
SOUND PROBLEM
Seems windows lost your drivers or another software package broke the drivers. Have you tried to re-install the drivers?
Nov 10, 2007 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
My hp speakers wont work
Sample testing is usually a firmware built into the monitor amplifier ie the monitor is testing itself. you problem possibly lies with the computer sound system. Tell me more about this. Is it an 'On-board' sound card or separate PCI card. You can determine this by looking at the back of the computer- if all the connectors - sound- PS2 and USB are in the same panel - then it is an on-board system. If the sound is separate in one of the card position then it is a PCI card. The possibility is the sound system needs setting up- check your computer paperwork/manual and utilities disk for Audio drivers. Come back with some answers
Jun 23, 2007 | HP P5302M Computer Speakers
Computer stopped recognizing the speakers
Check the sound card system Can your hear through headphones for example?
Nov 15, 2006 | Logitech X-230 Computer Speakers
HP Creative Sound Blaster Audigy 5.1 Logo
37 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
