Question about Sony Cyber-Shot DSC-H1 Digital Camera
My camera gets horizontal coloured lines on the lcd screen sometimes and at the same time it appears on the photograph as well.what to do?
  • 6,826 Answers
Two things can cause this problem.
1. shooting into sunlight
2. dirty connector at the memory card (memory stick pro duo or equivalent).- remove memory card and blow out with compressed air and inspect metallic connections on the card.
Posted on Aug 02, 2010
Horizontal lines have appeared on the screen what has caused this and can I get rid of the lines.
The LCD in the viewfinder likely has connection problems or broken circuits. Did you drop it recently? Was it subject to extreme temperature etc recently? You may find the lines shift around or even go away for some time. That would imply bad connections. If your technical enough to disassemble it, there is often a rubberised connector use between the LCD and circuit board that can be cleaned. It's delicate work tho.
May 08, 2016 | Nikon COOLPIX S52 Digital Camera
Olympus u820 image distortions colour and form
One answer time for a new camera the cost to repair is about the same as new.
Mar 15, 2017 | Olympus Stylus Stylus 820 µ Digital 820...
Captured photos have horizontal lines on them but doesnt appear while capturing
A multicolor horizontal line may display on the camera LCD screen if there is glare on the subject being photographed. Avoid photographing very shiny surfaces that reflect excessive amount of light into the camera lens.
Follow each step below until the issue is resolved:
  1. Change the position of the camera by shooting at a different angle.
  2. Shoot in an environment with different lighting.
  3. Adjust the zoom level.
  4. If the issue still occurs, try resetting the Camera back to factory settings.
To reset the Camera, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK. (Menu-->Setup-->Setup 1-->Initialize-->OK)
If the issue persists, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally. Please make sure that you turn ON the Camera before you reset it.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required.
Jul 26, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Horizontal pale blue lines on LCD screen and even on picture
Hey Ma-ya,
Most of the time horizontal lines are a result of taking photographs in very bright situations. If you are seeing horizontal lines on the LCD screen and in your images in low light situations this is most likely digital noise. Two ways that could fix this problem are turning the noise reduction on, and/or making sure your flash is turned on and your subject is within the range of your flash. Another cause of digital noise is having your iso set too high (I never shoot over 400 iso). I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 16, 2008 | Sony Cyber-Shot DSC-H1 Digital Camera
LCD screen shows weird colours
Gimbo again. Think LCD damaged will need to repair. Pics. as normal when viewed or printed.
Why has nobody commented?
How much to replace screen? Any ideas?
Feb 16, 2008 | Cameras
Faulty Lens?
Dear Swetnam
This is a internal circuit problem/defect and cannot be done on our own, so u should take it to SONY service centre. Avoid keeping the camera near hot temperatures zone. Sony is not tolerant to many physical factors.
Feb 07, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Faulty Lens?
this is ccd problum u replace ur ccd
Feb 07, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Lines appearing on pictures even though lens is clean
yes it can repairable,and it is ccd problem or internal flexible pcb.
this actually referred to aperture system.
Jan 25, 2008 | Panasonic Lumix DMC-LX1 Digital Camera
Coloured lines on picture screen
I have the same issue, Although My camera is a samsung N46, It was working perfectly the night before, then my friend switched it on and it came up with a black backround and pink + purple vertical lines going through it.
Nov 12, 2007 | Olympus FE-120 Digital Camera
Sony Cyber-Shot DSC-H1 Digital Camera Logo
69 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
